Question about Plumbing
Had a new boiler fitted yesterday drain off now our pump on the shower will only pump for appox 30 seconds then goes of will come again in about 2mins can you advise please
    Master:
    Sergeant:
  • 381 Answers
Was all system drained?....with relvant bits turned on/off?
Posted on Mar 19, 2011
Trevitherm shower use trips out combi boiler
The boiler may be over gassed or have the incorrect low / high pressures set. Recommend a service by a gas safe registered engineer
Mar 04, 2014 | Samsung Digimax D73 Digital Camera
I have a bristan 8.5kw electric shower, temp fluctuated to very hot, then to very cold. Now only cold. I had a combi boiler fitted now the shower seems broken, does this have any relevance to the flu
Changing the heating system will not affect an electric shower as it is run from the cold water supply,sound like the temp thermostat has blown ,contact bristan or there website to get a replacement thermostat,telling them which model electric showrr you have.
Sep 13, 2017 | Home
Hansgrohe Ecostat (with part 94282000 thermostat). Shower runs fine for a few minutes then boiler shuts down and shower runs goes cold. Boiler starts up again after 30 seconds and runs fine for a few...
Check the 94282000 cartridge for debris on the filters. If your boiler requires a certain flow rate to come on, then you must get enough flow through the cartridge to make that happen. Also, if your boiler is producing very hot water, the cartridge will self regulate and reduce the hot flow accordingly. try lowering the output temperature of the boiler to resolve that possibility.
If you need further assistance, you can call us direct at 800-334-0455
Sep 03, 2011 | Home
Vaillant ecoMAX 828/2boiler goes on & off when running hot water!
water must be set at 3lts a min ,check diaphragm valve move when hot tap is on, check microswitch ,best of luck
Aug 09, 2009 | Water Heaters
Mira thermastatic shower problem,pressure&temprature.
you mixing valve may be going bad,do you have hard water? you may just need too take it apart and clean it
Mar 06, 2009 | Plumbing
WATER RUNS COLD
ITsounds like you still have air in your lines try bleeding lines out some times it takes a while .or your getting air in lines some where try looking at the boiler at fittings .
Jan 23, 2009 | Home
Bosch greenstar 30 CDi - no central heating or hot water!
it sounds like the system was not cleaned properly when the new boiler was fitted. all new boilers need to have the pipework flushed to remove any debris scale sludge and flux from the system. this is now usually done by a power flush which is basically a big pump mounted on a big bucket and it washes the dirt out of the pipework and collects in the bucket. if this is not done the dirt will block up the small passages in the heat exchanger. i suggest the system is cleaned flush and the heat exchanger changed to help protect the boiler a filter should be fitted (for example a magna clean) if the company who installed the boiler is corgi registered then they are liable for the damages. call corgi for advice.
Jan 04, 2009 | Heating & Cooling
I have a 6 year old Halstead Ace High boiler which has many recurring problems due to a bad fitting. It was never flushed out causing the heat exchange needing to replaced TWICE through clogging and then...
Firstly your system needs a power flush to get rid of the grot, then it needs a good inhibitor to slow up the reappearance of the sludge.
Changing the boiler won't help. Any boiler will get clogged up but the halstead DHW heat exchanger is particualrly prone to getting gummed up. You can clean this out and refit without having to buy a new one. - but without a power flush it will happen again.
Jul 31, 2008 | Heating & Cooling
Plumbing Logo
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
