Question about HP Photosmart M22 Digital Camera
While cleaning out my elderly mothers house I found a Hp Photosmart M22. The memory card and batteries were missing. Otherwise it looks OK. I put in new batteries and a Lexar SDHC 4 GB memory card. It will not turn on. Questions; 1. Is it worth working on/ 2. What can Do to get it to work?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • HP Master
  • 102,366 Answers
The M22 won't work with your 4GB SDHC card. It only works with MMC and SD cards up to 1GB in size. Having said that, if after cleaning the battery contacts and putting in new batteries, it still doesn't work, I'd toss it and get a newer camera. Giving its age and (lack of) capabilities, it just isn't worth repairing.
Posted on Mar 19, 2011
How do I reset the camera.
Hi.
1.Turn off the camera.
2.Remove any memory card installed.
3.Remove all power sources (batteries and AC power) from the camera for at least 5 seconds.
4.Reinsert the batteries and close the Battery/Memory card door and/or reconnect the HP AC power adapter to the camera.
5. Verify if the camera works without an optional memory card.
NOTE: Resetting the camera returns all settings to the factory defaults. Any images stored in memory will be retained.
Thank you for using Fixya!
Nov 16, 2010 | HP Photosmart M22 Digital Camera
How do I unlock my Canon Power shot Memory Card Model SD 1100 IS
SD (and SDHC) cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Aug 09, 2010 | HP Photosmart M22 Digital Camera
My camera wont turn on.
ur lens strip is broken by using in out lens dont use zoom it crecks ur belt. now send for service
Jun 18, 2009 | HP Photosmart M22 Digital Camera
I need help how do i get my pics off my e327 photosmart hp camera
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Dec 14, 2008 | HP Photosmart M22 Digital Camera
Error 000000c8-8be7-586-053
Please, perform a camera hard reset. To do so, follow the steps below:
  1. Turn off the camera.
  2. Remove any memory card installed.
  3. Remove all power sources (batteries and AC power) from the camera for at least 5 seconds.
  4. Reinsert the batteries and close the Battery/Memory card door and/or reconnect the HP AC power adapter to the camera.
NOTE: Resetting the camera returns all settings to the factory defaults. Any images stored in memory will be retained. If the error message still appears after performing the camera hard reset, please click contact hp on this page for more support. CAUSE: The issue is caused by the Focus Home Sensor falling out of its position.
Nov 28, 2008 | HP Photosmart M22 Digital Camera
Batteries
You can try switching over to 2500 mAh Nickel Metal Hydride rechargeable batteries and you will see a difference.
Digital cameras with zoom lens need more power than what can be supplied by ordinary batteries.
May 24, 2008 | HP Photosmart M22 Digital Camera
i still can't solve my problem with my camera.
the screen still displays a red color
Feb 21, 2008 | HP Photosmart M22 Digital Camera
Hp photosmart m22 memory card problem
rechargeable batteries voltage actually are lower than normal batteries, but is high when freshly charged or still hot after charging. don't use newly charged or hot battery, wait at least five minutes or let the batt cools down first. some model and brand uses compatible rechargeable batt, it is different from those sold individually which i think you are using. it has special switch activator attachment have you tried to switch back to alkaline? how about formatting the card in pc? try removing then reinserting the card for several times. this will clean the card contact point in camera.
Jan 31, 2007 | HP Photosmart M22 Digital Camera
HP Photosmart M22 Malfuction
use different memory card, most troubles i always encountered in digicam are caused by memory cards, many cards works in pc but not in digicam. hey tapping side by side always takes away the trouble. [;0)
Jun 21, 2006 | HP Photosmart M22 Digital Camera
HP Photosmart M22 Digital Camera Logo
94 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
