Question about Nitro BMW-481 Car Audio Amplifier
I just put my amp back in my car after having it out for 5 months ( had to fix my car got hit head on) and when it turns on it goes str8 in to protecton mode( red light is on) not the green one.. any clue as to what maybe wrong? i moved to dif ground and still did work checked every thing over and all wireing is great it worked b4 i took it out just not now.. any way to reset the amp?
  • Jeffrey Turcotte
    Jeffrey Turcotte Aug 14, 2017
    Have you checked ohms on speaker wires?
SOURCE: was a green light during the day the next red and stays red
look for wires that are touching each other like speaker wires or you may have a blown sub
Posted on Mar 14, 2008
  • 631 Answers
SOURCE: My Amplifier keeps blowing fuses.
It probably has shorted output transistors.If it's like many of the Asian amplifiers, the outputs will be larger than the rest of the devices clamped to the heatsink. If you measure the resistance between the legs of any individual output transistor and read anything near 0 ohms, the transistor or one in parallel with it is likely shorted and will need to be replaced. You'd have to remove it from the board for definitive testing.
The donut is a power transformer. The coil with the black stick is an inductor.
The following page will help acquaint you with the components inside the amplifier.
Amplifier Repair Primer
Posted on Aug 15, 2008
  • 12 Answers
SOURCE: 481 doesn't work
did that to mine. Bat went dead and went to jump the car. What happends is when you attach the jumper cables, it surges the power to the amp. This gets worse with caps. I would say you blew the relay in the amp and needs to be replaced. It is worth fixin but youll have to send it off or take it to a repair shop to have the new relay put in
Posted on Oct 23, 2008
  • 113 Answers
SOURCE: I have a Nitro BMW-483 AMP
if you still get sound it just might be the led
Posted on Jul 05, 2009
  • 37 Answers
SOURCE: I have a nitro 2000w amp and the protection mode
could be blown fuse could be shorted output or to much a load bad ground bad signal or damaged amplifier take it to a professionall installation facility to many things from that description could be the problem
Posted on Mar 17, 2010
18.5 hp Briggs & Stratton putting in rocker arms back, one goes in to far?
turn the crank see if it rises back up you may have droped one of the guides that ride the cam because youll have to tear her back down
Nov 20, 2012 | Briggs & Stratton Briggs Stratton Intek V...
I have a Saab 9-3 and it overheated so I took it to the mechanic, he fixed the head gasket, i got it back for one day and it was rough as guts & kept on stalling, so i took it back he said it was...
My guess would be that the valve timing is off. Did he machine the heads at a machine shop? Have the valves checked/done? New head gasket? New head bolts? What year is it? It sounds like you may have 2 different issues with the starting and it running rough...however, does it smooth out after you let it warm up? Is there an engine light on in the car? What are the codes?
Nov 14, 2010 | Saab 9 3 Cars & Trucks
Rockford p8002 keeps pulseing. (not a ground problem)
for seeing a out of phaze speaker you would have to run like a 10 hz or lower signal to the amp you might be seeing a optical illusion if they were out of phaze or backwards the speaker would have cancled each other out so it would sound like **** as you said.but anyway it sounds like the amps power supply is bad.put it back in you car and see if it still works like it did befor you put it in your friends car.you may have burned it up.find out how much the amp is worth and if can have it fixed for less then 60% of orignal cost then have it fixed
Mar 18, 2010 | Rockford Fosgate Punch P8002 Car Audio...
Repair Tech said the motor was 'frozen".
I would call stanton & make a complaint about there quallity of goods & demand a refund.& theso called repair person in Fresno should back u up & if he doesnt then hes pumping your head full of ****.
At the end of the day mate therse no way that a set of decks thats only been used about
5 times could have a fozen motor, unless they were faulty to start with.
call stanton & take no ****,coz the customers always right....l.o.l
Jul 31, 2009 | Stanton STR8-80 Turntable
Crate amp hums when it is turned but can work at times
has th amp got a valve if so the valve may need replacing or might need reseating..
Jul 31, 2009 | Audio Players & Recorders
Memphis PR300.2 Amp protect light on
If it is not turning on your problem is it is not getting power. Check your fuses. The reason an amp goes into protect mode is usually because the subs are not wired up right. Make sure your fuses are good, you have a good ground, and make sure your amp turn on wire didn't come loose when you were putting the deck back in. As for the amp going into protect you probably wired the subs down to too few ohms and the amp you have can't handle it. Try hooking the subs up straight w/o bridgeing them and turn it up to see if it works. If you don't have problems with it then you wired your subs wrong.
Mar 22, 2009 | Car Audio & Video
Epson 7600pro air in ink line
You can try an Initial Fill of your ink carts. It is the next level after attempting to clean the heads. However, if this only temporarily fixes your problem, you could have a leak in the supply tubes, or the head could have failed.
Turn the epson off. Hold down the buttons [Paper Feed δ]+[Paper Feed ∇]+[Cut/Eject] and turn on the printer. This will take you into a hidden service menu. Hit the [Paper Feed ∇] button until you get to "Cleaning" then hit the [Select] button to enter that submenu. Hit the [Paper Feed ∇] again until you see "Init Fill", and then hit the [enter] button. The display will say "charging". Just wait until it is done, then turn the printer off and back on.
If you do not have enough ink in the in the carts you will be prompted to replace them. The same goes for the maintenance tank. Make sure you put the ink lever back in the lock position if you change the carts. (It will not give you an error about the ink lever being down, it just won't do anything.)
Jan 09, 2009 | Epson Stylus Pro 7600 InkJet Printer
Power issues
It sounds like you are drawing to many amps and you need to go to a higher capacity altinator and a second battery would be a good idea as well. Start your car (do it at night makes it easier to tell) turn on your headlights without your stereo on look at head lights and see how bright they are then slowly turn stereo on and up if headlights dim you are drawing to many amps and need a higher capacity alt to charge and stop you from blowing them, and second battery with and isolator so you don't draw amps from the battery that starts your car.
Jul 23, 2008 | Rockford Fosgate 800.2 Car Audio Amplifier
Amp shutting off going into protection mode
Check this out: http://www.techlore.com/article/14696/
Aug 14, 2006 | Legacy Audio American Legacy II LA690 Car...
Nitro BMW-481 Car Audio Amplifier Logo
51 people viewed this question
Top Nitro Car Audio & Video Experts
Marvin
Marvin
Mark Skinner
Morne Olivier
Are you a Nitro Car Audio and Video Expert? Answer questions, earn points and help others
