Question about Grohe Home
My single post Grohe kitchen faucet/ sprayer is "hung up "....cannot pull the handset out more than an inch or so. I looked under sink...the two water lines and flex metal sprayer hose ( has a recoil spring around it) go through a plastic flange/fitting up into the unit. I tried wiggling it....pushing up on it from beneath but it will not budge. Unit was installed new about 12 years ago and has never been a problem. Should I call plumber?? Seems like a simple problem but do not want to damage unit. Thank you.
3 Suggested Answers
  • 74 Answers
SOURCE: Grohe 32 071 K4 spewing water from single vale or tube under sink
There should be an o-ring on the mating surfaces of the hose and the faucet that my be missing.  It could also me that the big washer in side of the faucet (under the cartridge) has been shifted.
I doubt it is the cartridge itself, always try the cheap ideas first.
Posted on Apr 14, 2009
snap101
  • 117 Answers
SOURCE: grohe sprayer faucet will not retract, spring around hose below.
check out the spring on the hose under the sink, sometimes they come loose on one end and they lose their spring back into the faucet
Posted on Aug 01, 2009
Kitchen faucet sprayer I have a Delta classic single kitchen faucet and I have a side sprayer too. When I try to use the side sprayer the water stops at the faucet and barely trickles out the sprayer and...
There could be a clog anywhere between the diverter and the sprayer. Sometimes the line collapses from age and has to be replaced. Look under the sink to check for leaks.
Jan 20, 2014 | Plumbing
Drips from Grohe pull out sprayer
I would say that there is dirt under the sprayer gasket.or diverter. the gasket may be cracked. easiest solution is to go to a plumbing supplier with the sprayer and replace it.
andrew
Mar 19, 2013 | Grohe 32 999 KD0 Alira Pull-Out Spray...
I pulled the sprayer out and it will not go back into place. How can I get it back into place?
The flex hose for the sprayer can be seen under the sink. It may be hung up on a pipe or other object. As long as there is nothing broken on the sprayer you should be able to ease it back into place by gently applying a "pulling" pressure on the sprayer hose under the sink.
Sep 12, 2010 | Delta Faucet Delta 470-BL-DST Signature...
Kitchen Faucet is loose on granite counter
http://www.needplumbingsupplies.com/Grohe-Kitchen-Sink-Faucets.asp?id=13758
This link has a spec sheet that will give you an view of under neath counter top. There should be a nut that you can tighten it up with.
May 22, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
Delta single handle pull-out sprayer loose from base. How to tighten it?
Pull out sprayer has a plastic nut to tighten under countertop. You should be able to reach underneath and hold the top while tighting the bottom.
It designed to be tighten by hand to avoid damaging.
May 19, 2010 | Delta Faucet 470-DST Signature Diamond...
Replace button on pull-out sprayer
With your faucet in the off position pull the sprayer out. Unscrew the hose that connects to the sprayer. This lets you take the sprayer to someplace where you can sit down. The front of the sprayer where the water comes out unscrews as well. You may need to use a nonslip mat or a piece of rubber but you can undo this by hand. Once you have this off a small piece (airator) can come out that helps control water flow into a steady stream instead of the way water comes out of a garden hose with no nozzle. form here you'll be able to see how the old button fits into the sprayer, pop it out and replace with the new one. Assemble in reverse.
Feb 16, 2010 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Grohe sprayer faucet will not retract, spring around hose below.
Jun 19, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Grohe pull out kitchen faucet the inner tube ripped
go to the store you bought it and see if they carry parts. if not , try the internet under grohe.com.
Jun 11, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Mar 28, 2009 | Grohe 32.071.KD0 K4 Main Sink Dual-Spray...
Home Logo
281 people viewed this question
Top Grohe Home Experts
Mike
Oloyede Monsuru
Are you a Grohe Home Expert? Answer questions, earn points and help others
