Question about Fender ® Frontman 10G Electric Guitar Amplifier
If I turn up the volume on my Frontman 10g more than 4-5,the amp starts buzzing every time I play the thick strings. Thank you!
  • Fender Master
  • 5,603 Answers
You MAY be overdriving the amp. This is a tiny amp and should NOT be played louder than a typical BoomBox or the speaker may be driven too hard, going non-linear and then buzzing.
Posted on Mar 19, 2011
After 2 days of use i am getting no pick up off my guitar...the amp lights up but all I am getting is a humming noise.
If it's humming when something is plugged into the input, but not when nothing is plugged in, it's most likely the cable. If it hums when nothing is plugged in, the amp is defective and you need to return/exchange it.
Dec 30, 2015 | Fender ® Frontman 10G Electric Guitar...
High action martin java mahogany 00x1
To lower the action on an acoustic guitar:
Usually just the saddle needs reducing.
1. Remove strings (or you may be able to just loosen them). Remove saddle, sand down the bottom a little at a time. Restring and check action.
The action can be set as low as poss without any fret buzzing or note choking on all strings and on all frets.
2. Repeat 1
If the action remains too high then there are other techniques.
Later ...
Jan 09, 2014 | Martin Guitars 00X1 Java Mahogany Guitar...
Play mac through Fender Frontman amp
Simple: connect the headphones out (3.5mm jack) to the input jack of your fender (6.3 jack). By doing this you will loose one channel so you better generate a mono signal inside your computer before. Electrically this is no problem, nothing will be damaged. Turn the gain and volume knobs down and apply a signal from your Mac. Gently increase gain and volume. Et voila wonderful mono sound through a guitar amp
May 24, 2012 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Hello! I was recently playing and found out then whenever I play specific notes on any of my guitars, my Fender Frontman 212R will buzz. The notes that always buzz are drop C, drop C#, any A note, and...
There is something resonating with that note frquency. Often the grille or wiring inside will rattle at certain frequencies. You need a sustained source of these frequencies to find what is causing the noise.
Aug 25, 2011 | Fender Frontman 212R 100W 2x12 Guitar...
I have a fender 10g schematics can you helpme ? My E mail is alvape@hotmail.com
The schematic will be VERY close to this:
http://elektrotanya.com/fender_frontman-15b_sch.pdf/download.html
Scroll down to "Get Manual" on the web page and click on it to download.
The 10G may use a lesser power output chip but rest should be the same.
Apr 09, 2011 | Fender ® Frontman 10G Electric Guitar...
There is a noticeable ringing sound only when I strum any note on the E string , any other string sounds fine.
If the ringing only occurs with a specific range of notes it may be something rattling in the amp loose or speaker enclosure.
It could also be feedback occurring at certain frequencies - does the ringing stop if you turn the volume down a bit or stand in a different position in relation to the amp?
Could be a problem with your guitar? Maybe the pick up height needs adjusting in relation to the E string or is it the string buzzing against a fret - indicating a need for adjusting the bridge height or trussrod settings?
Feb 27, 2011 | Fender Rumble 75 75watt Bass Guitar Combo...
If I strum harder on my guitar a buzzing noise comes out of the amp. Also every sound I try on the amp sounds very twangy and painful to the ears. I use an overdrive pedal with it, but every setting is...
If you don't want distortion, get rid of the overdrive pedal... Twangy USUALLY comes from the GUITAR and NOT the amp... test it on a different amp to decide... Buzzing CAN be caused by "fret buzz" which is due to IMPROPER guitar setup such as neck bend and string height.
Start using ONLY clean channel on the amp and NO reverb. If you verify that the guitar sounds bad on a different amp, take it in to have it setup properly.
Feb 10, 2011 | Fender Frontman 212R 100W 2x12 Guitar...
I have a Fender Frontman 212r amp. The problem seems to be when I put the volume upto past 4/10 [40%] The amp gives out an awful crackling sound and power light etc flickers on and off. I have had the map...
When i turn on my 212R it turns on in drive channel. if footswith is plugged in, then it turns on in the clean channel, but after switching in drive it is impossible to switch it back in clean channel. What could be wrong? Swith position doesnt change anything and it seems like switch is OK.
Nov 27, 2010 | Fender Frontman 212R 100W 2x12 Guitar...
Fender ® Frontman 10G Electric Guitar Amplifier Logo
192 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Are you a Fender Music Expert? Answer questions, earn points and help others
