Question about KitchenAid Architect® II KWCU405SSS Stainless Steel Kitchen Hood
Our Kitchenaid Range Hood model KWCU405SSS has a code "C" in the display. What does that mean?
  • 3 Answers
I just did this and it works.
1.) Make sure to turn off both the fan and the lights. If you skip this step the next step won't work.
2.) Press and hold the + button for 4 seconds until the "C" disappears.
Repeat in another 100hrs of use.
Posted on Jan 05, 2016
3 Suggested Answers
SOURCE: The range hood display is showing a "C". We had
Press and hold 'H' for 4 seconds - then press '+' which will reset the 'C' until the next cleaning reminder
Posted on Jan 02, 2011
SOURCE: kitchenaid hood wont allow reset of "C"
Hi Folks, does pressing the "+" button resolve the issue?
Posted on Nov 26, 2009
KWCU405SSS fan motor high speed only
Agreed! It totally works. Our fan and lights were stuck on high. Flipped the hood circuit breaker off for 30 seconds then back on again and all controls are working normally again. Thanks!
Jan 15, 2013 | KitchenAid Architect® II KWCU405SSS...
KitchenAid Electric Range KERS807 Oven won't do anything, flashes S3E3 code
Do you mean an F3-E3 code? I've never seen a KitchenAid S3 code.
The F3 code means that the oven temperature sensor is bad. The E3 indicates that the sensor indicated an excessively high temp during the clean cycle.
Please determine the full model number of your range to ensure that you get the correct sensor. The sensor costs between $75-80, depending on the vendor. I used the KERS807SSS02 for a guide. www.searspartsdirect.com and http://www.appliancepartspros.com both have the sensor in stock.
If the range is still under warranty, contact KitchenAid for the repair.
I hope this helps.
Apr 30, 2012 | Kitchen Ranges
I have kitchenaid Kerc700 electric range that had the code F2:E3 show up on the display. What does this mean?
Hello, Thank You for using FixYa. I will be helping you today.Kitchenaid F2-E3 means a button was held down too long if you push cancel and it comes back you would have to replace the glass console. Thats assuming its F2-E3 and not E3-F2
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | KitchenAid KERC700 Electric Kitchen Range
Jan 01, 2011 | KitchenAid Architect® II KWCU405SSS...
Kitchenaid microwave model KHMS155L, starts randomly for 3 minutes with "PAN" flashing on display screen, than locks up with "F-2" message on display screen
"F2" means you have a shorting membrane keypad. The "Pan Heat" key is shorting.
On these models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
You can find helpful exploded view diagrams and order parts by entering your full model number* from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors may have a lock:
* The exact part number you need will depend on your exact model number. Models in that series are shown below:
KHMS155LBL0
KHMS155LBL1
KHMS155LBL2
KHMS155LBL3
KHMS155LBT0
KHMS155LBT1
KHMS155LBT2
KHMS155LBT3
KHMS155LSS0
KHMS155LSS1
KHMS155LSS2
KHMS155LSS3
KHMS155LSS4
KHMS155LWH0
KHMS155LWH1
KHMS155LWH2
KHMS155LWH3
Dec 17, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
How do I clean the filters from your kitchenaid stove hood
To clean the filters on the Kitchenaid KICU265HSS. If this is not your unit can you please give the right make and model #.
The filters should be washed frequently. Place metal filters in dishwasher or hot detergent solution to clean.
If you need the manual for your unit you can download it on link below. Just type in the # code then click on download now.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Good luck
Jun 13, 2010 | KitchenAid KICU265HSS Kitchen Hood
Kitchenaid hood wont allow reset of "C"
Try presing the "+" button for four seconds instead...
Mar 20, 2009 | KitchenAid KICU265HSS Kitchen Hood
Hood fan works but displays the letter "C" ?
wow! finally the solution that works! Holding the '+' sign for 4 seconds. We had our vent replaced by kitchenaid once and were about to call again and complain since our new one did just the same thing without resolution using the 'H' button as indicated in the manual! Thanks for help it's so appreciated!
Feb 22, 2009 | KitchenAid KWCU205HSS Kitchen Hood
Oven door locked
unplug the oven for a few hrs, need a brand and/or model number to look up diag. codes
Jun 02, 2008 | KitchenAid KGST307 Gas Kitchen Range
KitchenAid Architect® II KWCU405SSS Stainless Steel Kitchen Hood Logo
341 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
