Question about Nokia 2626 Mobile Phone
I could n't connect to internet using phone as modem
  • 229 Answers
Did u subscribe for any browsing bundle? If you did, contact your mobile service provider for tje right steps to take. Hope this helps.
Posted on Mar 19, 2011
I am using samsung 3g metro gt-s5350 with MTNL sim. I am able to surf the net on the mobile but not able to use it as modem for using internet for my laptop. It is showing "os error, remote device...
Samsung PC Suite - Internet through mobile modem -Error 619 - Data Cable
Rectifying the error
1. Samsung USB modem driver (Download from Samsung ' Local Link)
2. Connect Your Samsung with a working Internet connection ( via )USB Cable
3. Samsung PC Studio or any other Samsung mobile drivers are not installed
Procedure
1. Connect your Samsung Star 3G to your PC and install the modem drivers that you have downloaded.
2. Goto Control Panel > Phone and Modem Options
3. Select the Modems tab. You will see Samsung mobile modem listed.
4. Select it and click on Properties.
5. Goto the Advanced tab and put the following in the box for Extra Initialization Commands:
+cgdcont=1,"IP","your_apn_name"
( or tye AT+CGDCONT=1, "IP', "apnname")
eg:- +cgdcont=1, "IP", "bsnlnet"
6. Hit OK and exit.
The next step is to create a dialler for your Samsung Star 3G mobile modem.
Error 619 solved
1. To create a dialler, Goto Control Panel>Network Connections
2. Hit Create a New Connection and proceed as follows (each sub-point is for each screen of the wizard):
2.1 Network Connection Type: Connect to the Internet
2.2 How do you want to connect to the Internet: Set up my connection manually
2.3 Select Connect using a dial-up modem
2.4 Select Modem-Samsung Mobile Modem
2.5 Type an ISP name according to your preference (could be anything)
2.6 Type*99# as the phone number ( or type *99*1*1# or *99***1# )
2.7 Leave Username, Password and Confirm Password fields blank
2.8 Hit Finish
That would complete the wizard and make a dial-up connection for you. Dial it and you will be connected to the Internet via your Samsung Star 3G phone modem without using Samsung PC Studio
Nov 08, 2010 | Samsung Modem Configuration Software...
My mobile is nokia 5800 music express. so i want to connect internet through my pc
First of all, install the Noki Pc suite on your computer, connect the phone in Nokia Mode, you'll see that your mobile is a Modem, Open the Internet Connection and set your nokia modem as the default modem, create a dial up connection using the Internet Connection wizard, you'll need the number to dial, this number is to be obtained from the Network Operator. Now you can connect to the internet using your phone. Note that the speed will be slow as compared to normal (wired/wireless) internet connection. Good luck Thanks for using FixYa.
Jun 01, 2010 | Nokia 5800 XpressMusic Smartphone
MOBILE TO PC INTERNET CONNECT.
these r the steps:-
1. download & install pc suit
2. go to control panet/phone and modem
and click on modems select ur phone
click on properties and then change settings click on advanced & fill extra command which is:- AT+CGDCONT=1,"IP","tata.docomo.internet"
in" " u use access point of ur service provider
and exit
use control panel connections and use dial up connect use ur phones modem and dial no. is *99# dial this is connected
May 07, 2010 | Samsung SGH-L700 Cell Phone
Modem
Assuming that Windows has recognized the modem, and has loaded the correct device-drivers, Windows can use the modem.
You'll need to find an Internet Service Provider that provides "dial-up" service.
You'll need to have a land-line telephone (not a cell-phone) with your local telephone-company.
Connect a 4-wire cable (not an 8-wire Ethernet cable) from the "line" port on the modem to the telephone wall-jack.
Then, follow the instructions given you by your Internet Service Provider to configure your modem to connect to their dial-up server. Or, telphone them, and their Technical Support staff will guide you through the necessary configuration steps.
Apr 09, 2010 | D-Link DFM 562IS (DFM-562IS) Modem
Can I use the Samsung alias 2 is an Internet modem
    Using Alias 2 as Modem
  1. The Alias 2 can, in fact, be used as an external modem to connect your computer to the Internet. To do this, the phone must plug into the computer via USB. The USB data cable specific for the phone is purchased separately and can be found at most any cellular phone store and eBay. Because USB is a powered connection, anytime the phone is plugged into the computer for use as a modem, it will also remain charging, so you don't have to worry about battery life while online.
    In addition to the cable, you must subscribe to a specific service through your cellular provider in order to use the Alias 2 as a modem. This plan will be a "tethering" plan and will have a separate charge each month to use it, similar to a cell phone's data plan. By signing up for this feature, your phone will be able to dial into the data network and utilize the Internet connection as a modem, allowing any connected computer to surf the Internet. Once this feature has been activated on your account the option will become available on the phone itself to enable tethering.
    At this point, you should be able to turn on tethering, connect the phone to your computer via USB cable and select the phone on your computer as an Internet connection source.
    It is important to note, however, that the Alias 2 uses a different and slightly older system on the 3G cellular network. Because of this, using the phone as an external modem will produce a slightly slower Internet connection than a traditional modem or even a newer phone would. However, as a backup solution for Internet connectivity or a travel solution, the Alias 2 will work just fine as a modem for your computer or laptop.
Apr 01, 2010 | Samsung Alias 2 SCH-U750 Cell Phone
Acer aspire 9410, cannot connect to the internet using dial-up
You have two different devices here. A modem and a wireless network adapter. Two totally different devices. It sounds like the modem quit working but the wireless network adapter still functions. I'm assuming that the modem is built it. If you absolutely have to have it you could buy a PCMCIA modem if your laptop has a PCMCIA slot to plug it into. You could also have a corrupted modem driver.
Oct 01, 2009 | Acer Aspire One PC Notebook
Connecting a wireless router to Tiscalli broadband connection
  1. USB modem is connecting a PC USB port with a DSL phone line: CANNOT be connected to a ROUTER LAN (ethernet NOT USB port).
  2. Wireless ROUTER is NOT a modem and it CANNOT connect the Internet (or WAN) LAN port to any "phone line"
  3. Connect the Router Internet (WAN) port to Modem (you need a LAN MODEM = a modem with a LAN/ETHERNET port)
  4. Be sure your internet is running before strting ROUTER configuration with Router Company CD
Jan 05, 2009 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
New computer running slow
if you are using dial up, you shud not have a modem.. modem is just for DSL connection
if you have a modem probably you are using a DSL connection
DEFINITION:
dial up - connection using a phone line with internet connection; cannot use fone while on internet
DSL/modem- connection using a modem plugged in with computer and fone line; able to use fone even when on internet.
Jul 10, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Want to connect motorola w230 to internet with USB
I want to connect motorola w230 mobile to internet by using usb.so how can i connect and from where i can get software(Modem driver) for that.
Jul 01, 2008 | Motorola Mobility W230 Phone US with...
USB external modem
The phone connection would need to go through the blue tooth regardless of if you're using the phone connection or not. Check to see that you have bluetooth turned on and setup first. Then you'll need to use that to create the settings for using the phone as a modem. However, if you are using Windows on your Mac, you will need to make sure that your computer has the drivers installed to be able to both connect to the Internet and to connect to your phone. Once that is set up, you still need to go through the steps to use bluetooth to connect your phone to your computer, establishing a connection. There are quite a few articles about creating connections through your phone as a modem. http://mobileoffice.about.com/od/typesofaccessavailable/ht/bluetoothphone.htm
http://www.theinternetpatrol.com/how-to-connect-your-computer-to-the-internet-using-your-cell-phone-as-a-wireless-internet-connection-or-tethered-modem
Mar 01, 2008 | Apple MacBook Pro Laptop Computer with...
Nokia 2626 Mobile Phone Logo
24 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
