Question about Novation Dicer (Pair)
My Dicers aren't working right, only when connected with the usb it lights up & works on ether side & I already tried using a different jack cable. When I 1st plug 1 in it lights up orange instead of red too
My spider III amp has no sound.. lights on but no sound
No, probably NOT a fuse issue here (still lights up, etc.). Are you using the foot-pedal accessory? If so, then unplug it and go direct into amp. Try some headphone via the output jack (sound?) Yes -> GOOD. NO? -> Not so good. May require servicing. Also, check the guitar cord you're using. While unlikely, somehow it might have gotten damaged. Good luck!
Jan 10, 2013 | Line 6 Spider Iii 30
When I turn amp on there is a loud humming that does not stop.
try plugging into a different socket if that doesnt solve problem you may need to replace cord. sounds like a loose neutral in socket though.
Dec 01, 2012 | Fender Frontman 212R 100W 2x12 Guitar...
MARSHALL FOOTSWITCH FOR DSL100 TROUBLES
Does your M foot switch work on the Fender? If you know how to use a multimeter you could check continuity by putting meter leads on plug of M foot switch(1 on tip, 1 on sleeve ) You should see a change in the multi meter when you depress switch. If so switch is good. Another easy test is with cap off a spare 1/4 plug -plug it in to foot switch jack.put a alligator or some such metal clip or wire and join(called short or shorting) the two inputs . If connecting and unconnecting results in switching then the foot switch is suspect. One fairly common thing is that foot switch and input jack are often sautered straight to a circuit board to save $ on production cost. Used to be all point to point where a wire was attached to 1/4" input and then wire went to circuit board or tubes. The wire has give, but not so with direct wiring to board. So the nut holding the 1/4" amp input gets loose(doesn't have to be loose for the following to happen) and a pull on the chord causes a break in the soldier and thus a break in the sound chain. Sometimes it will work intermittingly by putting a little pressure left, right, up or down on the plugged in plug. If so, it's the input jacks connection to the amp. If not it still could be that because putting pressure on plug may not be sufficient to affect a temporary reconnection. Since switch(the new one you made)works on Fender, but not Marshall I suspect the jack or foot switch circuitry past the input jack. If using some of the above the above tests leads you that direction,remove housing(unplug a/c power 1st ) inspect jack,wiggle it slightly see or feel a break then resodier from back side. You should be able to use the soldier already present without adding extra.
Sep 27, 2017 | Music
Danelectro Hodad Mini Guitar Amplifier - no sound output
Do the cables have the right length plug/jack ends? There are 5 different lengths in use. Some will short the inputs completely.
Do you get noise floor from the amp when turned full volume? if so, it is an input/mute issue. The switches these days are rather cheaply made and prone to dirt or corrosion. Try cycling the switches repeatedly. The same with the jacks.
If there is no warranty left- pull the chassis out and under a regular flourescent light, noise test each part of the amp with an insulated screwdriver- just make a contact on discrete transistors, or on the inputs of the IC's and work back towards the input. If it is clean all the way back-it has to be the cable, cable ends or the guitar.
Jan 30, 2012 | Danelectro Hodad Mini Guitar Amplifier
I have an opportunity to buy a cfx20 mixer from a guy for a really good price, but both the XLR and 1/4" jacks aren't working on one of the main outputs. I suspect it's the master slider, and...
If headphones have both sides working, it is NOT the main fader. It would most likey be the driver chip for the failed side that has been blown. This is common problem when people fail to power the mixer from the same receptacle or power conditioner that amps and other connected equipment are powered from. Ground bounce damages the circuits. The balanced outputs are driven by NJM4560 op amps which are likely surface mounted 8pin chips... .
Here is service manual:
http://elektrotanya.com/mackie_cfx20_sm.pdf/download.html
Scroll down to "get manual" and click on it to download. Ignore other download links for viewers.
Jul 12, 2011 | Mackie cfx20 mkII compact mixer
Berhinger acx 1000, power on, no sound amp not working, everything lights up on display but no sound or amplification
Just had the baby brother (ACX450) with this problem...opened the amp... screws from sides and or top (including 2 hidden under handle covers).
The power cable from the power transformer had come off the connector on the circuit board in spite of goo they had put on it. Put connector back on and secured the cable and works perfect,
Since your display lights, yours is likely a different problem. I have also seen similar ones that the cable to the speaker had been pulled off its connection on the circuit board, rendering no sound. See if you have sound at headphone jack. and if none, how about the preamp output jack? Note you will only hear the left side using earphones as these jacks are monaural.
Feb 06, 2011 | Behringer Ultracoustic Acx900 Acoustic...
My deville has just stopped producing any sound what soever. All the tubes glow and the red power light is on but no sound. I have tapped the sides of all the tubes and they all register a sound except the...
The first thing i would do is not leave it on in this way for too long. You could blow out a very expensive Transformer if its a faulty speaker. The worst thing you could do to a TUBE amp is run it without a speaker . I would test the speaker first. Just remove the wires going to it. And connect the speaker to either a car stereo or house system at low volume very low. And see what you get. if it works ? Good! Now check your guitar chord/wire. Try different ones try different guitars. If that doesn't work . Look into the input jack on the instrument input hack on the amp.. They do come loose off the board.Either get a new input jack or resolder the old one. if you only have one guitar look at the guitar output jack. Loose wiring on the guitar could cause this also. Dirty In and out put jacks could cause this. A pencil with Very fine sand paper wrapped around it will clean a dirty input/output jack. Try these things. Just remember poking around your amp is Dangerous. The electrical components hold a charge even unplugged that can kill you. No joke..
Dec 26, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Marshall MG50 DFX amp line out/headphones not working
Contrary to what's posted above, the Marshall MG series does not pass the speaker power output through the headphone jack, and inserting the headphones into the jack does not disable the speaker. The headphone amp is a separate circuit and it's input is taken before the master volume. So Jan's post is exactly right. Turn off the master volume and turn up all the other gain/volumes as high as they will go. The other issue is that the headphone jack's output does not drive low efficiency headphones well, so you need some headphones similar to Sony's MDR-V700s to hear it well. Earbuds just don't cut it.
Mar 07, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Peavey 115 Low hum Low volume from input
The preamp section has a problem. It could be anything in the preamp but is OFTEN the input jack itself. They take a lot of abuse.
Also the insert jack contacts that forward the preamp to the power amp if no external FX are used can go bad.
Additional things are circuit board cracks caused by rough handling and also controls that have had the knobs mashed in which can destroy the potentiometers they are connected to.
Sep 19, 2009 | Peavey Music
Headphones arent working with keyboard
yes its in the keyboard jack.
Aug 14, 2009 | Music
Novation Dicer (Pair) Logo
29 people viewed this question
Top Novation Music Experts
Michial Gueffroy
Are you a Novation Music Expert? Answer questions, earn points and help others
