Question about U.S. Robotics MAXg USR5461 (738168036790) Wireless Router
My printer (HP LJ 1200), attached to a US Robotics router with USB print server, doesn't work in windows 7; it works regularly in windows xp. Windows 7 seems not to support Internet based printing (the string to connect the printer is http://192.168.1.1:1631/printers/HP_LJ_1200).
  • 3 more comments
  • ladriana Mar 19, 2011
    I disactivated the firewall and the problem is the same: configuring the printer, the system doesn't accept an "internet printer" defined through the connection stringhttp://192.168.1.1:1631/printers/HP_LJ_1...
    Selecting: Add a new printer - Add a network, wireless or Bluetooth printer - The Printer That I Want Isn't Listed - Select a shared printer by name and typing the specified connection string, the system, after a long time with the window "connecting to ...", answers "Impossible to connect to the printer ..." and there is no way to go on.
    Have you other suggestions? Thanks
    The printer is connected to the USB port on the router 192.168.1.1; all the PC's connected via ethernet to the router regularly work (connection in LAN and to internet); the printer works well with the Windows XP PC's, while the windows 7 one cannot be connected.
    the driver for hp lj 1200 is installed but the system doesn't ask for the printer producer/model.
    All the PC's on
    the LAN, both XP and win7, can see each other and shared folders through the router. As the printer is usb connected to the router it is not significant the connection mode of the pc to the router; moreover the win7 pc is a desktop without wireless connection.
  • ladriana Mar 22, 2011
    No, the suggestions where about operations already tried; in the meantime we asked to USRobotics and they answered the print server on our router is not supported on windows 7.
    Thanks
  • 4,924 Answers
Try to get to the Hp ..and download and install the driver for the printer into the windows 7 ...cause this may be the cause for what it isnt seen by the pc ..specially if they are in network ...the others seen it cause they have the xp driver ..but for this one you have to load the w 7 driver..
Also try to make the settings again if this is the only pc connected to the router ..
or ..if the driver is installed ..get to start ..printer and faxes..and run the add new printer wizard ..and look for the printer by name in the network ..(after you install the driver..
Posted on Mar 20, 2011
    Guru:
  • 767 Answers
Have you installed Windows 7 drivers for the printer on the PC that does the printing?
Posted on Mar 19, 2011
  • Jean-Pierre Damstra
    Jean-Pierre Damstra Mar 19, 2011
    If you go here you will see that the router has support for Winows Vista, XP, 200, Me, 98, 95, Linux and Mac OSX. It will not work on a system with Windows 7. That is why the printer is having trouble recognising it. Windows 7 supports network printing just not the router you are trying to use. You will need to make sure that all the PC's on this print server can see each other. If you can view each PC's shared documents folder from each other PC on the network then the network should be fine. I would sugest trying to connect the WIn 7 PC wirelessly to the router.
    President:
  • 1,851 Answers
Have you tried to disable the Windows firewall? Keep in mind that on Windows 7 the firewall is more "tough" than the win xp one. Here is the settings screen:My printer (HP LJ 1200), - technical114_38.jpg
Also take a look at this official link I think it will help you to clarify the point that you loose the handshaking.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct fixya link: http://www.fixya.com/users/technical114
  • Stelios
    Stelios Mar 19, 2011
    Set up a fix ip address for the printer and try to ping at this address. Is the comunication succesfull?
    Try to setup the printer as a local printer and after this installation modify the port for this printer as a TCP/IP with the ip address of the printer.
    Thanks and regards
    Stelios
    direct FixYa link:http://www.fixya.com/users/technical114
US-4A Keyspan USB Server
if urs is a 3 in one u wil have scan and copy functions also included in this sir.
is urs a 3 in one?
Jun 21, 2008 | Keyspan USB Server US-4A (d47710) Print...
What do I need to make my printer wireless?
You need 1) a wireless router with a USB port that supports the HP OfficeJet printer. 2) The software for your router to run a printer on the USB port. Obviously, you will need a USB A/B male end cable.Note: the scan features of the all-in-one may not work unless the printer is directly connected to the computer. Bi-directional communication is required for scanning and the router software may not support this completely.
Check the list of supported printers closely for older routers. I have a Cisco Linksys E4200 v.2. This router supports all the HP printers that I use.
If this is a new installation of the printer, first install the printer on the computer. If you have Windows 7, just connect the printer to the USB port on the laptop. This will install the OS drivers for the printer. (For Windows XP, go to the HP site and get the full software.)
Next install the wireless router between your modem and computer and set that up. (If you have DHCP (dynamic address allocation), it should be automatic. Otherwise follow the directions.) Next install the router software (for my router, it was Cisco Connect).
My next step was to launch the Cisco Connect program and connect the printer directly to the USB port on the router. In Cisco Connect, choose add a printer and find the printer connected to the router. Print a test page. (At times, I've had to reset the port that the printer is on in the Windows Control Panel Printer Properties. (For the Cisco Connect, the printer is on the DOT4 port.)
Other routers will be set up somewhat differently.
Another option is to have the printer connected to a desktop and then make it a shared printer with the wireless router communicating between the laptop and the desktop. This makes the desktop the print server, so it needs to be on when you want to print. If you have several computers with Windows, this can fairly easy to set up. Make sure that the computers are in the same Workgroup (XP) or Homegroup (Win7). Enable sharing and you are done.
I hope this helps.
(who has a OJ 7000 (with ethernet port) and a LJ1320 (USB) connected to the router. Three computers talk to these printers with the laptop on the wireless network. On an older router that didn't support the printers, the laptop was the server for a previous OfficeJet and one of the desktops was the server for the LaserJet.)
Aug 27, 2012 | HP OfficeJet 6110 All-In-One InkJet...
For key span server to work with windows 7 install windows xp mode to windows 7 ( this can be downloaded from microsoft website if you have windows 7 pro and above. if you have windows 7 home then install...
1. instal server utility on Windows 7
2. right click icon choose properties
3. select compatibility tab choose your o/s
now run it and presto......
regards, dean
Jan 08, 2011 | Keyspan USB Server US-4A (d47710) Print...
Is there any hope for a Vista 64 bit HP Laptop with the HP LJ 2840 Printer? I have tried it all, had Invisus Support work on it for two hours today, 10-25-10, and still no printer functionality. I am...
s.gif upd-5_1_1_8232-pcl5_winxp-vista-x64.exe [1/1, 15.21M] System requirements: s.gif Client and server operated systems supported for the most current release of the UPD:
Client operating systems supported:
  • Microsoft Windows 7 Starter, Home Premium, Professional, Enterprise, and Ultimate; x86 and x64
  • Microsoft Windows Vista Business, Enterprise, Home Basic, Home Premium, and Ultimate; x86 and x64
  • Microsoft Windows XP (SP2 and later) Home Edition, and Professional; x86 and x64
    *Note: Microsoft retired mainstream support for Windows XP in April 2009. HP will continue to provide best effort support for the current UPD and tools for the discontinued Windows XP operating system until 2011
Oct 26, 2010 | HP LaserJet 2840 Printer
I have window 7 64bit and the keyspan software installed fine but the server utility does not recognize the print server. I allowed port 3842 tcp and udp through the windows firewall but still no luck.
for key span server to work with windows 7 install windows xp mode to windows 7 ( this can be downloaded from microsoft website if you have windows 7 pro and above. if you have windows 7 home then install windows virtual pc, start it up and insert a windows xp pro install disk. for info on this google 'workaround to install windows xp mode in windows 7 home premium and home basic') Once you have windows xp mode running, install the keyspan server utility int he virtual machine and setup as usuall. then share the printer. go to windows 7 devices and printers and add a printer, chose a network printer, select the new virtual machine and select the shared printer. In order for the printer to work just start up the keyspan program from windows 7 and print....your welcome.
Sep 08, 2010 | Keyspan USB Server US-4A (d47710) Print...
Is wps54g wireless print router compatible with windows 7: how do I get it installed
Contrary to the on-line advice that I have found, the Linksys wireless print server WPS54G is compatible with Windows 7. It is the installation program that is not compatible. While not as bad as the early days of setting hardware dip switches, the print server must be installed manually. Following are the many steps that I took to install my WPS54G to work with Windows 7; lengthy, but worth it.
1. Connect your printer to the PC using a USB cable and USB port. Allow the printer to install. Print a test page. Even though you just installed the printer, check for an updated printer driver at the manufacturer's website. I did this late in the process before I could get the printer to work. It installed an HP universal driver.
2. Set the printer as the default.
3. If you do not know the IP address of your print server, access the router using your browser. See your manual for instructions. For a Linksys, type the default IP router address 192.168.1.1 into the browser address bar. If you have done this in the past, set up your router security. The default user name is left blank and the default password is admin.
4. Connect your print server to the PC using a USB cable and USB port.
5. On the router locate the DHCP Client Table and determine the IP address of the print server. You might have to refresh the table. The default is probably 192.168.1.78.
6. Access the print server using your browser and the IP address of the print server. The default user name is left blank and the default password is admin. Set up security to match the router, SSID, password, type of encryption, etc.
7. Go to "Devices and Printers" (from the start menu), on the default printer icon that you just installed, right click and open "Printer Properties." Click on the "Ports" tab.
8. Click on "Add Port." Select "Standard TCP/IP Port" and click on "New Port." Click "Next." Add the IP address of the print server (probably 192, 168.1.78) and call the port whatever you want. Click "Next."
9. After the port configures and you get the "Port Settings" tab (you can also get there by clicking on "Configure Port), change the protocol to "LPR" and click "LPS byte counting enabled." Use "p1" or P2" etc. for the "queue name."
10. Disconnect the print server from the USB port and let it sit for 30 seconds.
11. Disconnect the printer from the USB port.
Apr 06, 2010 | Linksys Wireless-G WPS54G Print Server
Use of HPJ4680 in a network with Mac & PC connected to router
Ok what you do is, install the printer as a LOCAL one on one of the PC's, Probably the XP, one, would be best. or perhaps the PC; actually "Connected" to the D-link router & Modem, then Now install this printer , as a LOCAL, printer, and set as DEFAULT, enable Printer Sharing. Now, ALL PC's MUST, have a Name, Belong to the same Workgroup, have a Password. On the "Other" PC's Install the Printer as a Network Printer, browse for it and connect. Print a test page from each. Remember the PC with the printer attached, must obviously be ON or the "Others" cannot connect and print.. Make sure all network permissions are set sharing is set, especially on the Win 7. Just make sure they can all "See" each other first, before try all this.. the network MUST be intact and communicatable from each PC to at least the PC with the printer attached. I have included 3 links below, to help
kb.parallels.com/4886 - support.apple.com › Support -
support.microsoft.com/kb/239418
Mar 05, 2010 | HP Officejet J4680 InkJet Printer
HP LJ P1008 can be used as network printer ?
I have one of theses D-Link PD-301U. It does NOT support a printer like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1008 is NOT in the list):
LaserJet
  • 1200
  • 1500 (USB 2.0)
  • 2200
  • 2200D
  • http://support.dlink.com/faq/view.asp?prod_id=2135&question=DP-300U%20/%20DP-301P+%20/%20DP-301U%20/%20DP-311U%20/%20DP-G310%20/%20DP-G321
    Feb 10, 2009 | D-Link DP 301U (DP-301U) Print Server
    Can't connect my Linksys WRT54GS router to zonet zps1000
    The gateway would be the address that your router uses.
    You would plug the print server into the back of the computer using the ethernet line.
    Use this link to get into the support section of the website:
    http://www.zonetusa.com/index.asp
    Dec 30, 2008 | Zonet (ZPS1000) Print Server
    Open Questions:
    U.S. Robotics MAXg USR5461 (738168036790) Wireless Router Logo
    337 people viewed this question
    Top U.S. Robotics Computers & Internet Experts
    Michael Galve
    Michael Galve
    Aris C.
    Aris C.
    Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
