Where is the PCI slot for a PCI adapter on a Toshiba?
    Guru:
  • 1,342 Answers
It is on the motherboard. You will have to open up the case to access it.
Posted on Aug 02, 2008
Where do you plug in the adaptor on the e machine for wifi
Depends on what kind of Wireless Adapter you are using
There's the Wireless Adapter Card
Comes in three styles of connection,
1) PCI Wireless Adapter Card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4389486&CatId=2701
2) And PCI-Express x1 Wireless Adapter Card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1068811&CatId=2688
PCI-Express x4 style may be out there too.
(I've never bothered to look. I use the USB style)
A Wireless Adapter Card based on the PCI technology, goes in a PCI slot. Generally White in color, but NOT always,
http://en.wikipedia.org/wiki/PCI_local_bus
http://en.wikipedia.org/wiki/File:PCI_Slots_Digon3.JPG
A Wireless Adapter Card based on the PCI Express technology, is used in a PCI-Express x1 slot,
http://en.wikipedia.org/wiki/PCI_Express
http://en.wikipedia.org/wiki/File:PCIExpress.jpg
Top example is a PCI-Express x4 slot.
Moving down, next is a PCI-E x16 slot
Next, PCI-E x1 slot
Next is a PCI-E x16 slot,
and the last one at the bottom is a PCI slot.
Notice they are all Yellow.
Color of connector does NOT matter.
What the expansion slot is, does........
Also there is a USB Wireless Adapter,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3970955&CatId=2704
This type of Wireless Adapter, plugs into any available USB port on the computer.
Front or back of an eMachines desktop computer, in any available USB port.
Any available open USB port, on an eMachines laptop.
(Or any computer manufacturer)
What is the model number of the eMachines Desktop PC?
Examples, T1090, T2460, W4685, D2246, etc.
I should be able to tell you what motherboard is used inside, and may have access to a link, to the Motherboard Manual.
Post back in a Comment.
Regards,
joecoolvette
Apr 14, 2013 | E-Machines eMachines Desktop PC
Where can i buy a onchip usb2?
FIC FR33E motherboard?
http://www.ebay.com/itm/FIC-FR33E-L-MOTHERBOARD-CPU-LOT-10-/170633274365
Reference: Photo
To the far left side of the motherboard, is actually the Bottom of the motherboard, when installed in your computer case.
The two White long expansion slots you see, are PCI expansion slots.
If one is available, (Open), you can use a PCI USB adapter card.
This is but one example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4143850&CatId=511
Seem cheap? Nope. Good quality also. (You can also check the reviews)
Need guidance in installing?
1) Follow Anti-Static Precautions
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware components inside the computer.
Computer on a table, computer unplugged from power, computer case open.
[Note* Always unplug the power to a computer AT the surge protector. NOT at the back of the computer. (Power Supply)
You can cause a power surge ]
2) TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
Should you leave your computer in the middle of working on it, be SURE to Touch the metal frame again, upon your return.
3) Finding an open PCI slot look at the back of the computer. In the metal frame you will see slots going horizontally.
These are Expansion Slots.
You may have an add-on adapter card already installed, in one of the PCI slots.
The expansion slot cover for it is removed.
You should see expansion slot covers however, in the remaining expansion slots on the back of the computer metal framework.
Remove the one that corresponds with the PCI slot you wish to use.
Be aware that the PCI slot will not be directly in line, with the expansion slot.
When installing an add-on adapter card, you will see when the card is inserted in the PCI slot, the metal bracket on the add-on card, lines up with an adjacent expansion slot.
This will make more sense to you once you go to install the card.
[PCI USB adapter card is an add-on adapter card ]
Line the card up in the PCI slot. Note that there is a Locating Lug in the PCI slot, and a matching Locating Notch, on the PCI USB adapter card.
Also, at the same time line up the metal bracket of the PCI USB adapter card, with the metal framework of the computer case at the back.
Gently push the PCI USB adapter card down into the PCI slot.
Fasten the card's metal bracket to the computer's metal framework.
Post the computer manufacturer name, and model number, if you need guidance in opening the computer case. Post in a Comment.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 13, 2012 | FIC Computers & Internet
How to add usb ports to Dell 530
Suggest use a USB adapter card.
More specifically a PCI USB adapter card.
Dell Support > Inspiron 530 Series Desktop PC > Owner's Manual,
http://support.dell.com/support/edocs/systems/inspd530/en/OM/HTML/index.htm
In the list click on - Removing and Installing parts
1) Unplug the computer from power.
[Unplug FROM the surge protector, not the back of the computer. (Power Supply)
Unplugging from the back could lead to a power surge ]
2) Computer on a table open the computer case,
Click on - Removing the Computer Cover - in the list.
3) FOLLOW Anti-Static Precautions
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware inside the computer.
4) http://support.dell.com/support/edocs/systems/inspd530/en/OM/HTML/parts.htm#wp1184332
Here you see an illustration of your motherboard. Oriented as it is in your computer case. (Just no hardware components, nor cables are attached)
At the bottom of the motherboard are 2 White long expansion slots.
In the illustration they are labeled by the numbers 21 and 22.
If one of these slots is open, and not being used, you can install a PCI USB adapter card.
This is one example of a PCI USB adapter card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5606148&Sku=S262-2744
At the back of the computer, located towards the bottom, are the Expansion Slots.
Four horizontal slots.
If there isn't some sort of add-on adapter card already installed, all of the expansion slots will be covered with an Expansion Slot Cover.
If there is an add-on adapter card installed of course, one of the expansion slot covers will be removed.
Line up the PCI USB adapter card with the open PCI slot, you have chosen.
Now look at the expansion slots at the rear of the computer.
Notice what expansion slot that the PCI USB card's bracket, lines up with.
Go to the back of the computer, and view the small metal bracket on the bottom right. Loosen the Thumbscrew, and swing the bracket out. (Thumbscrew is supposed to just loosen, not come out)
Remove the expansion slot cover for your PCI slot choice.
Install the PCI USB adapter card.
Line them up, then push the PCI USB card straight down into the PCI slot.
Also watch the metal bracket on the back of the PCI USB card.
The 'tang' at the Bottom, slides down in-between the framework.
The top of the bracket has a half-moon notch, that lines up with a small 'dowel' on the computer case framework.
Make sure it is aligned, and the bracket is aligned.
What I am referring to will become readily apparent, as you go to install the PCI USB card.
If there are any other add-on adapter cards, they may try to fall out, when you go to install the new add-on card.
You just have to line them up, so their bracket notches are all on the 'dowels', and hold them in place. Then swing the 'door' closed. Tighten the thumbscrew.
If you have an Add-on card in the way, and by moving it to the other PCI slot, will allow you to install the PCI USB card, go ahead, and move it.
Doesn't matter. BIOS will find it, and assign an Interrupt Request.
There are two other expansion slots above the 2 white PCI slots.
The expansion slot right above the top PCI slot, is a PCI-Express x1 slot.
If this slot is open, OR the only one available, you can use a PCI-Express USB adapter card.
Example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5606149&CatId=511
The last expansion slot you have is above the PCI-Express x1 slot.
This is a PCI-Express x16 slot, and is ONLY used for a graphics card.
Regards,
joecoolvette
Jul 13, 2012 | Dell Inspiron 530 Desktop Computer...
What Wireless card to buy
A version that is Wireless N.
You can install a Wireless N adapter card in any available (Open)
white PCI slot, or use a Wireless N adapter that plugs into any available USB port.
1) Dell Support > Studio XPS 8100 Desktop PC > Service Manual,
http://support.dell.com/support/edocs/systems/studio8100/en/sm/index.htm
I would like you to click on - Technical Overview
Now on System Board Components
The number 23 points to the white PCI slot.
The numbers 24 and 26 point to a PCI-Express x1 slot.
You can buy a Wireless N adapter card to fit either a PCI slot, or a PCI-Express x1 slot.
{NOTE* Number 27 points to a PCI-Express x16 slot.
This = NO.
This expansion slot is used for a graphics card, ONLY }
Examples of a Wireless N adapter card for a PCI slot, and a PCI-Express x1 slot,
A) PCI: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4389486&CatId=2701
B) PCI-Express x1:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=788312&CatId=2702
C) USB:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5079829&CatId=2688
Why use anything but a USB Wireless N adapter?
I don't know. They allow me to toot the whistle, but not drive the train.
Information on PCI, and PCI-Express;
PCI:
PCI-Express:
Regards,
joecoolvette
Feb 11, 2012 | Dell Studio Xps 8100 Desktop Computer
Are pci and pci-e cards the same
No the cards are not the same. One has 62 pins on each side of the card (minus a cutout for a key with the slot) and the other has 32 pins (PCIe 16x) or fewer. They have different power requirements and won't fit directly in the other slot. There are adapters for PCI-e 1x cards to use them in a PCI slot and adapters to put a PCI card in a PCI-e 1x slot. See any of the component vendors for details.
Make sure to order a card that will fit in your computer's slots. It will save you trying to determine if the card, slot or adapter has failed.
I hope this helps.
Oct 27, 2011 | Lenovo IBM ThinkCentre A30 8199 (8199XX2)...
I purchased an HP A4327C desktop computer and wanted to convert it to wireless. I purchased a Level One11g Wireless PCI card and the card will not fit into the slot inside of the computer. Is it the wrong...
HI,
On your computers motherboard, you have three slots
  • PCI slot
  • 1 PCI express slot 16
  • 2 PCI express slot 1
You would require a PCI express 1 ex wireless card for the system
Thanks
Proton
May 11, 2010 | HP (EA118AA) 802.11a/g/b Wireless Adapter
Computer does not detect new 802.11n pci wireless adapter..also used cd to put drivers on...but main problem is it seems that the computer doesnt even power on the LED light to the adapter.....HELP PLZ!!
try moving the PCI card to another PCI slot in the computer. Sometimes individual PCI slots stop working properly. If you put the card into multiple PCI slots and it never recognizes it or lights up, your card may be defective.
May 14, 2009 | Computers & Internet
Mini PCI WIFI Kepps sytem from booting
Ok, since you posted that it's the same model that your laptop came with, I will assume that the original had a problem and you are replacing it. If that's true, your problem may not have been with the adapter or the newly installed PCI Mini WiFi adapter is defective (this happens more often than one would think). Try another adapter if you can.
Good luck.
Feb 09, 2008 | Toshiba Satellite 5205-S703 Notebook
Reply to my motherboard
It looks like your trying to install a PCI Graphics Adapter. If that is the case, I would try the PCI Graphics Adapter any Slot other than Slot 1 or Slot 2. That is unless, your PCI Graphics Adapter Card is a PCI Express, then that must be installed in Slot 1, if the Board supports it. If the PCI Graphics Adapter is a PCI-I Card then it must be installed in Slot 2.
Check AMD's site, they have or already implemented standards on their support chips. The standard, as I understand it, is Slot 1 - PCI Express, Slot 2 - PCI-I, if you're using those Slot for PCI Graphics Adapter.
It should be possible to use those Slots (1 & 2) for any PCI Cards that is not a PCI Graphics Adapter, be careful, I have not checked that out. Those do not handshake as Video Adapter, so the PCI card should not be thrown or overdriven, the PCI-Express and PCI-I, to my knowledge is only for Grahpics Adapters, should that be different, then Slot 1 for only PCI Express Cards and Slot 2 for only PCI-I Cards.
Me, for now, Slot 1 for Express, Slot 2 for PCI-I, and the rest of the Slot for all else. If your PCI Graphics Adapter is not an Express or PCI-I, install in any Slot other than Slot 1 or Slot 2.
Dec 14, 2007 | EliteGroup (ECS 915PL-A2) Motherboard
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
