Question about Gigabyte GA-EP45-UD3P - Motherboard - ATX - iP45 - LGA775 Socket - UDMA133, Serial ATA-300
None of my USB ports work. Please help - Gigabyte GA-EP45-UD3P - Motherboard - ATX - iP45 - LGA775 Socket - UDMA133, Serial ATA-300
  • Gigabyte Master
  • 27,725 Answers
Click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
Posted on Mar 19, 2011
No power in socket for charging phones etc. Is it a fuse problem?
Are you speaking of a USB port (connector) on the laptop?
http://en.wikipedia.org/wiki/USB_connector#Types_of_USB_connector
Scroll down
If so........NO
There is no fuse for any USB ports. Laptop or desktop computer.
That USB port is bad. None of the USB ports work? Then the USB bus is bad, that all USB ports operate off of.
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 28, 2013 | Computers & Internet
My laptop is an HP Pavilion dv 8309us and when none of the 4 USB ports recognizes any device. A message appears "USB DEVICE NOT RECOGNIZE, ONE OF THE USB DEVICES ATTACHED TO THIS COMPUTER HAS...
I think the problem lies in a damaged USB controller on the laptop. The fact that none of the ports work, indicates that either the power to the ports has failed, or more likely the circuitry controlling the USB hub has failed. Sadly You will most likely need to replace the motherboard
Jul 18, 2011 | Pavilion dv8309us dv8310ca dv8310tx...
When i plugg in my camera to the computer it wont chrge it wont even turn on if there is a soultion please contact me asap!!!
Hey Sophia,
Have you checked the battery, as the problem seems to be with battery
First of all checked if the battery is inserted properly
Take it off and re-insert it... make sure the +ve and -ve are set properly
If it still does not work...you got to replace the battery
Thanks
Oct 08, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
USB ports not working?
Check out this link for troubleshooting USB Connections.
Hope that helps,
Regards,
Raspal
For Windows XP Driver Files and How-to Resources, visit XPDrivers.
May 02, 2010 | Acer Aspire 3683WXMi Notebook
None of my usb ports work. Help!
  1. restart the computer
  2. to to bios setup
  3. enable the usb port  or use auto detect settings
  4. save changes
  5. restart the computer
Apr 09, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
USB Ports Not Working
Check Device Manager for bad drivers
Aug 09, 2008 | Computers & Internet
USB port
Have you confirmed that none of them work? Do the USB ports show up in device manager (look for USB Root Hub entries).
If all else fails, you could always buy an internal PCI card that has USB ports on the backplane.
Does your digital camera have an SD card or other memory slot that you could simply plug into your desktop to transfer your pictures?
Mike
Dec 10, 2007 | Compaq Presario 5000 PC Desktop
Check your CMOS settings to ensure that your USB ports are enabled.
Oct 15, 2007 | Toshiba Satellite A135-S2276 Notebook
Gigabyte GA-EP45-UD3P - Motherboard - ATX - iP45 - LGA775 Socket - UDMA133, Serial ATA-300  Logo
154 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
