Question about Palm Zire 21 Handheld
What is the polarity for the battery and what is the charger rating
Lead acid Car battery was charged with polarity reversed. Can it be re-charged correctly? It blows the charger fuses??
a lead acid will not charge with the polarity reversed
What happens is that in dead shorts and can destroy the battery
it can blow up the battery , blow the charger fuses and destroy the charger
Depending on the damage to the battery cell plates it may be recoverable
Mar 30, 2018 | Cars & Trucks
Need a charger for a Kawasaki power wheels 4 wheeler model: new ninja. What kind do i need for a charger 12 volt for this?
I suggest you refer to the instructions for the specification.
The first requirement is fitting the charger socket and the next is having the correct polarity.
The type of battery is important and the required charge rate/time is also important. A lead/acid battery should ideally use a constant voltage charger. Ni-cads and similar should ideally use a constant current charger.
The vehicle might have it's own intelligent charging circuitry and just need a power supply but if this is not so then the more sophisticated the charger you buy, the longer life the batteries will have.
Apr 29, 2016 | kawasaki Toys
Comes with SBC HB700 batteries
All ways use the charger that comes with the unit only. the voltage of the charger is matched to the unit, one or two volts above the unit rating can shorten battery life by a large amount. Also battery polarity must be taken into consideration.
Aug 02, 2015 | Audio Players & Recorders
The charger will not charge battery
How old is the DVD player? Either the player battery is beyond its use or the charger has a problem. Be SURE you are using the correct charger. Can you or a friend test the charger with a meter? The VOLTAGE, CURRENT rating AND POLARITY must ALL be correct!
Feb 09, 2012 | Curtis DVD7026 7 in. Portable DVD Player
Hi, I have lost the ac power cord for my NC-E2 Canon battery charger. Is there a similar cord I can buy from Best Buy or Circuit City that will fit? Thanks in advance. JD
You need a UNIVERSAL POWER CORD, NON-POLARIZED
you can buy at
http://www.allelectronics.com/make-a-store/item/LCAC-400/2-CONDUCTOR-POLARIZED-CHEATER-CORD/1.html
see these cables has round and square ends.(click Zoom and Look the picture)
If the hole in charger have two round corner buy
http://www.allelectronics.com/make-a-store/item/LCAC-390/6-2-COND.-UNIVERSAL-POWER-CORD-NON-POLARIZED/1.html
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 21, 2011 | Canon NCE2 NIMH Charger Battery Charger
Looking for a 120V to 12V charger for a Professional"s Favorite 17.5 million cp spotlight.
You should be able to use any AC adaptor that puts out a 12 volt DC current and has correct polarity. Based on the estimated size of the battery powering your spotlight, you probably will want a charger that provides at least 1000 mA of power--the charger that came with my ThorX 10 million cp spotlight puts out 1500 mA to charge the two batteries in that light. A lower amperage rating will increase the amount of time it takes to charge your light, but it should still work.
You can find a replacement charger at Radio Shack, which sells chargers that can be fitted with a variety of different tips. However, you might be able to find a cheaper universal charger with a tip that works at a discount store like a Walmart, or you might get lucky at a thrift shop or second-hand store and find a 12v charger that will work with your light. 12 volts is a common output for a lot of different devices, so it shouldn't be hard to track a replacement down. Just make sure you have the adaptor tip polarity correct, or else you could make your battery explode if you try to charge it with reversed poles.
May 25, 2011 | Camping, Backpacking & Hiking
What tip polarity do I use to connect an after market charger?
The short answer is "The tip should be set to positive (+).
I found an old Vector VEC127Y Spotlight. It appeared to be in perfect condition but the battery was dead and there was no charger. I was able to buy a replacement battery at BatteriesPlus for $21 USD. Here is the link for the battery
REPLACEMENT VECTOR VEC127Y BATTERY
I also purchased a Universal A/C adapter to use as a charger at BatteriesPlus for $17 USD. Their site does not list it yet but here is the manufacturers link. Please note the original battery was rated 6Ah. The replacement is only rated for 5Ah. Which means one less Amp hour (Ah). Which means a shorter run time, after charging, than the original battery had. Otherwise they are equal.
UNIVERSAL AC ADAPTER
I installed the new battery. I set the AC Adapter to 6V and installed the largest of the seven adapter tips that came with the charger, with TIP set to be positive (+). I opened the battery compartment of the spotlight and disconnected both the red (positive +) and black (negative -) battery leads from the battery. I then plugged the adapter tip of the Universal AC Adapter into the spotlight and plugged the AC Adapter plug to a power outlet. With a multimeter I tested the polarity of the spotlight battery leads while charging. I was able to confirm that the Adapter TIP should be set to positive (+). After reconnecting the spotlight battery leads and setting the AC Adapter to charge, I have a perfectly great spotlight in full working order.
Dec 02, 2010 | Vector Spotlight - 1 Million Candles...
I am trying to find a battery charger for a black/decker handdrill no kc12xc 12v
Here is just 1 of several sites that sell the charger.
http://www.mtmc.co.uk/Black--Decker-12-volt-3-hour-Battery-Charger---418338-02__p-409.aspx
according to the site this is the charger you need (12V 3 hour charger # 418338-02)
i searched for that number and found several places that sell the charger, including ebay
Nov 13, 2010 | Black & Decker Hand Tools
Charger
next to the jack on the camcorder it should have a diagram that shows polarity (a + and - sign) for the plug, the tip should be one sign and barrel or outside of the plug should show the other polarity. you have to have your plug with the correct polarity, and you have to have the correct voltage( it should say 9v or 12v or something like that) and the supply you use should be as high or higher of a current rateing as recommended in your users manual or printed on the supple that came with it.
Dec 27, 2008 | Universal Battery Charger Charges Multiple...
Black and Decker Battery Charger
Fault Codes Meaning of Fault Code F01 Internal Shorted Cell Battery - Cannot be charged. Have battery checked by certified auto service center.
Excessive Load on Battery While Charging - Check load. F02 Bad Battery Connection - Check battery connection.
Battery Voltage Tool Low to Accept Charge - Have battery checked by certified auto service repair. F03 Internal Open Cell - Have battery checked by certified auto service center.
Sulfated Condition - Battery needs to be reconditioned. See manual. F04 Overtime Condition - Battery will not accept a charge after 18 hours of continous charging. Battery may have internal
damage. Have battery checked by certified auto center.
Battery Charge Rate is Set Too Low - Set charger to higher charge rate. See manual. F05 Overheated Condition - Disconnect charger and allow to cool for 30 minutes. Check for ample ventilation. F06 Reverse Polarity F07 Alternator Output is Out of Typical Operation Range
Operation Codes I=I=I=I Battery Reconditioning - (The letters DES will display for the first three seconds) I-I-I-I Alternator Voltage Check OOO Charger Standby FUL Battery Fully Charged
Sep 21, 2008 | Electronics - Others
Palm Zire 21 Handheld Logo
147 people viewed this question
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
