Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
2nd use of chainsaw pp3516avx, it won't start, choke lever will not stay extended. I followed the instructions to start and nothing works
  • Poulan Master
  • 2,239 Answers
The choke system is connected to the half throttle position, if you lift the throttle trigger the choke pull will automatically return, whilst trying to start do not lift the throttle trigger, the starting procedure is, pump the primer bulb as many times as it takes to 3/4 fill the bulb, pull the choke pull fully out, this will switch the saw on and engage the half throttle, crank the engine until it fires once, do not continue to pull,it will actually not run on full choke, if you do continue to crank with the choke fully out, you will very quickly flood the engine, now push the choke fully in, now crank the engine until it fires up, lift the throttle trigger once, this will dissengage the half throttle, and it should now come down to idle.
Posted on Mar 19, 2011
Husqvarna 445 start/stop switch won't stay in choke
remove the top cover and see if the pins are broken from the sides of the lever
Sep 05, 2012 | Husqvarna Garden
Pp3516avx -will only stay running with choke on full
Fuel blockage, replace the filter in the tank, check the fuel hoses for leaks and cracks.
Aug 02, 2011 | Poulan Garden
Will start on choke and run 5 seconds. will not start unless on choke when i try to rev up it goes dead.
Clean or replace all fuel components.Change the spark plug or coil.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 22, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Won't start after sitting for a few minutes after use, starts good after sitting for a very short time or a long time.
I have 18 inch poulan,if I stop for a few min.then try to start it I do not choke it and it will start right up
Sep 12, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan saw wont run
Clean the muffler spark arrestor screen and check the cylinder port for carbon build-up at the upper edge. Try presetting both carburetor H and L adjustments (from lightly CW stops) 1-1/2 turns CCW each. Start the engine and allow to warm up. Pull the throttle wide open and adjust H CW until the engine speed increases, but still 4-stroking. Correct setting is when the engine 4-strokes, but immediately 2-strokes when cutting. Allow to idle and adjust L for smoother running, yet allows the engine to 'follow the throttle'. Set idle speed to keep the engine running, but doesn't try to move the chain. You may have to look closer at your carburetor if the above doesn't help. Go to:
http://www.drystacked.com
for an excellent article (but poor pix) on Walbro carburetors, but related to most all 2-stroke carburetors. Hope this helps!
Feb 18, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Choke/start knobs wont pull out to ingage thus not start.saw is only 6monthsold used twice
Should still be warranted. Why void the warranty? Take it back or find an authorized service center.
Poulan.com
http://www.poulanpro.com/node4042.aspx
The site says 1 year warranty. HTH
Lou
Oct 04, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Difficulty starting Poulan 2250 . . .
hey pete
This is easy, prime bulb 5 to 7 times with choke lever full out. Pull string, once engine starts turn off choke and pull string again. ( throughout process do not pull trigger )Engine should start, let it idle 30 seconds, then finally pull trigger to rev up engine.
Jul 03, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
New poulan chainsaw won't start
how manny times do you prime it before you try to start it? you could be flooding it, or not priming it enough also the choke could not be working. if you take off the cover that covers the carb you can see if the choke is working and if the primer is working also check the air filter. you can also hit it with a quick spray if ether before you try to star it and it should fire right up.
Jun 05, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Will not start - brand new
i bought a new dirtbike as a kid n same thing.it turned out ,it needed to be a synthedic oil in the mix.try seeing for spark to begin with by putting sparkplug in the wire n touching diode to the engine block while pulling the cord.thats a good starting point to diagnosing your problem.maybe try warming it up in the house then try starting it with no choke needed.the saws i ve used needed you to give it throttle after you pull,n no throttle with choke.
Mar 12, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
538 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
