Question about Fujitsu AMILO PC Laptops
Hi: I've got a problem with all my network adapters. Error 31 in all of them, i've tried a lot of things, but nothing works...
  • 12 more comments
  • santiagowies Mar 19, 2011
    I can't, too much software installed that I would loose...
    I use Vista Home Basic OS.
    Yes, I did that. Downloaded and used Intel (R) PROSet/Wireless SEStub Setup Program. The first try I got Blue Screen and reboot, the second time it worked. But error 31 is still there. The strange think is that I cant uninstall de adapters and when I try to uninstall Cisco VPN the blue screen appears again.
    TKS anyway
    Tks Ezrahite, but I don't understand step 5.
    There's one entry called Network Adapters, is it the one I have to change?
    Only Tape Drives and Dvd/cd-Rom Drives entries have upper and lower filters.
    I have 23 yellow flags there, six of them look like the entries in the registry. All of them begin with isatap. and many numbers like this { ...................................................................}
    All the Network Adapters are in yellow. I reinstalled Intel Pro Wireless, but it didn't work.
    Fujitsu Siemens AMILO PI 1536
    Excuse me, I'm still trying to install the drivers. Of course ill rate you, don't worry.
    Finished with the updates and the registry, it din't work... Might be a corrupted ndis. sys file?
    I have the restore Cd, but don't want to do it until the end. Too much software.... Are you thinking in a fake (in place) OS Upgrade?
    Well, in the meantime my girlfriend brought a new little Asus Eee. I will continue working without Internet in the old one tomorrow, I have to write a lot. After that i'll probably end up doing what you recommend. I won't do it know, here in Spain it is midnight and i've been trying to fix it all day.... Late tired might be a further pc disaster. Thank you very much, I'll accept your solution.
  • 2,632 Answers
Welcome to Fixya. If you have Error 31 and you already installed the drivers all you need to do is to edit the regsitry entries to fix the issue. Follow the steps below.
1. In the search box (Windows 7 and Windows Vista) or the Run text box (Windows XP) type regedit and click OK or press the ENTER key.
This will open the Registry Editor program.
2. Locate the HKEY_LOCAL_MACHINE folder under Computer/My Computer and click the '> or (+) icon next to the folder name to expand the folder.
3. Continue to expand folders until you reach the HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class registry key.
4. Click on the + icon next to the Class key to expand it. You should see a long list of subkeys open up under Class that look something like this: {4D36E972-E325-11CE-BFC1-08002BE10318}.
5. Click the registry subkey corresponding to the device's Class GUID that you determined in the last step.
6. In the results that appear on the window on the right, locate the UpperFilters and LowerFilters values
7. Right-click on UpperFilters and choose Delete.
8. Choose Yes to the "Deleting certain registry values could cause system instability. Are you sure you want to permanently delete this value?" question.
Repeat Step 7 with the LowerFilters value.
Note: You might also see an UpperFilters.bak or LowerFilters.bak value but you do not need to delete either of these. Deleting them probably won't hurt anything but neither one is causing the Device Manager error code you're seeing.
9. Close Registry Editor.
10. Restart the computer
If you have questions please let me know. Thanks for using Fixya
Posted on Mar 19, 2011
  • 10 more comments
  • Rofel Lantican
    Rofel Lantican Mar 19, 2011
    Just skip step 5 i already change the GUID class on step 4.
  • Rofel Lantican
    Not that one. Can you see UpperFilters and LowerFilter Value? IF upper and lower filters is there you need to delete it
  • Rofel Lantican
    Can you verify to your device manager which device has a yellow exclamation
  • Rofel Lantican
    I need you to name the device that have exclamation mark - exmaple network adapters, Other Devices etc. Did you already installed the driver for the laptop that is for windows Vista?
  • Rofel Lantican
    Please provide the make and the model of the computer so that i can provide you the download link for that. Thanks
  • Rofel Lantican
    Did you already download the driver at the fujitsu website?
  • Rofel Lantican
    I've provided the link below for you to download the driver for your computer. You can use the image as a guide.
    Fujitsu Driver Download
    Select your Operating System
    Download the Chipset and WLAN
    Install the driver and restart the computer. Thanks
  • Rofel Lantican
    Keep me posted and i was able to help you out dont forget to rate me so i can help others. Thanks
  • Rofel Lantican
    No problem. Just use the guide above and hopefully the problem will be fixed as you can see you can update the other drivers aswell.
  • Rofel Lantican
    It should fix after installing the driver. Hmm you have the Installer for the Windows Vista Operating System? Possible to resinstall?
  • Rofel Lantican
    It might be that the registry have been damage due to many software that has been installed. We don't recomment Fake Os here at fixya it might caused you problems in the end. Best thing to do is to reinstall the OS then update the drivers.
  • Rofel Lantican
    Ok no problem. Don't forget to back up the files. Thanks for using Fixya.
  • 314 Answers
Hi santiagowies,
have you tried reinstalling your Operating system to Factory defualt?
  • Tada Phiriyanuphong Mar 19, 2011
    I Understand.
    have you tried reinstalling the network adapters?
    I am sorry i am afraid i have run out of ideas.
    unless you desperately need it fixed my opinion is to back up all your important Data and information and restore to factory defualt.
    i hope this helps, i am unable to assist you further more.
Wireless adapter does not work
there is no driver installed for your adapter. check in device manager click on network adapters.you may have to connect to internet with ethernet cord before you can download a driver for your adapter.
Jun 23, 2012 | Dell Inspiron 4000 Notebook
What is the driver for microsoft 6to4 adapter #8
Hi Friend,
6to4 adapter is a component used for transmitting IPv6 packets trough IPv4 network correctly.
In some scenarios, there will be a code 31 or code 10 error appearing beside this component. A possible reason is, the network adapter doesn't support this feature. You may update the driver for your network adapter or chipset, and then try to Uninstall and reinstall the this component.
To Uninstall the component, right-click the item in Device Manager and select Uninstall.
To reinstall the component, in Device Manager, Action - Add Legacy Hardware - Next - "Install the hardware that I manually select from a list" - Network adapters - Microsoft - Microsoft 6to4 Adapter - Next - Finish the wizard.
If the steps above doesn't solve the problem, your network adapter is not a supportive one for this component. You can completely ignore this error, if there isn't IPv6 network deployed in the environment. The error won't affect your system.
To remove the error message, please right-click the Command Prompt and run as administrator, type the command netsh in 6to4 set state disable, press Enter. The component will be disabled and hidden.
Regards
Chiranjeet
Sep 17, 2010 | Computers & Internet
Hello, i have a hp notebook which code 31 error on
http://support.microsoft.com/kb/932520
Microsoft says to Ignore the problem, and the adapter will continue to work correctly. If the message is really annoying maybe you can try turning off IPv6.
Control Panel\Network and Internet\Network Connections
right click your network card>properties
uncheck the IPv6 box
that'll turn off IPv6-then just disable the adapter driver
Feb 23, 2010 | HP Pavilion dv6000z Notebook
Isatap adapter????error code 31,cant get onto internet,wont find my router or any other devices,really stuck on this one?
Use System Restore to revert device drivers and registry configurations back to a state previous to the Code 31 error. Be sure to choose a restore point from a date and time before you know or suspect that the Code 31 error first appeared. 8. Disable any hardware-based security on the device.
for more help visit CBR Tech Solutions
Jan 22, 2010 | HP Computers & Internet
4to6 adapters 0002/0003 are not working due to
Check out http://acer.com and look for updated device drivers for your computer.
Nov 09, 2009 | Acer AM1610-UD2180A DT E2180 2.0G 2GB...
Toshiba satellite wont connect to internet. Wireless network adapter showing vista error code 31. Any ideas
Try removing the wireless adapter in the device manager and then re-boot computer. Vista should detect the adapter and re-install the drivers. if that does not work you might want to download the latest drivers and software from Toshiba and install them. Another thing you can try is to use windows restore to return the computer to a time when the wirless adapter was working.
Sep 24, 2009 | Computers & Internet
Cannot connect to wireless
Hi, reinstall the latest adapter drives.
Aug 01, 2009 | Computers & Internet
Code 31 cannont load driver 6T04 adapter
To resolve this concern, first thing to do is to uninstall the device from device manager and then after that restart the computer and run the setup cd that came with it to reinstall the software and the device back to your computer....
Jul 29, 2009 | Packard Bell 1580509280 Network Adapter
Error code 31 4 to 6 network adapter
Check these things:
  1. Is you Ethernet adapter Active
  2. Is your Cable the correct one (NOT a cross over)
  3. Refresh your IP Address for your Ethernet Card
  4. Reboot your computer and power down your modem, then power the modem up AFTER your windows is logged on
  5. Verify your modem "really" can connect, use another computer.
  6. Verify the are no network issues with your ISP
Apr 16, 2009 | Acer AM1610-UD2180A DT E2180 2.0G 2GB...
Fujitsu AMILO PC Laptops Logo
845 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
