Question about NEC VT670 Multimedia Projector
NEC vt 670 projector. Light will not go on. I get a green power light, then it appears that the projector is coming on, but then the machine beeps and the lights start blinking. The power light turns orange and then the status light starts blinking red in a 6-cycle ( manual says wait a minute and restart) (according to the manual). I tried resetting the lamp hours. The manual said to hold down the help button on the remote for 10 seconds. I tried this. I can not find any fuse areas blown. I got a new bulb, same thing happens.
5 Suggested Answers
  • 259 Answers
SOURCE: Status light blinking red
If it is a lamp error try this:
When the lamp exceeds 2100 hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
Posted on Feb 27, 2008
  • 3 Answers
SOURCE: NEC VT670 Blown Fuse
Try replacing main power supply it should take care of your fuse problem.... Not the ballest power supply the main one.
Posted on May 29, 2008
SOURCE: NEC VT 595 wont turn on. Just red blinking light
I had this same problem with 2 NEC VT595 projectors. My problem was that there was a broken "tab" on the lamp cover (the plastic cover that slides in place over the lamp) that is supposed to depress a switch which insures the lamp cover is in place before operating the projector. The tab was broken in half and not making the connection there for causing the blinking status light (.5 sec on, 2.5 sec off) indicating a lamp housing or cover error.
Posted on Aug 26, 2009
  • 2237 Answers
SOURCE: NEC VT 47 projector, status lamp flashes red x 6
the "try again after one minute" is a trial. if the new lamp doesn't work, the problem lies with the ballast.
Posted on Sep 03, 2009
Testimonial: "I guess I will find a repair shop that can check &/or replace the ballast. Thanks!"
The projector turns on but won't project any light through the lens.
If this is a NEC VT series projector, Change the lamp. When if it continues to blink amber and not project and image after installing a new lamp check the lamp cover to see if the micro switch tab on the lamp cover broke off. Some models have a built in lens cover. If the cover is not slid over to open completely the light may not turn on.
May 19, 2014 | NEC VT800 LCD Projector
Nec VT 670 It overheats after 30 minutes of use. This is when the fan is on auto. Appears to be OK on man full fan speed. The room temperature is OK and the bulb life has 96% left. Any solutions. The...
Check the lamp cooling fan of your projector one more time. may be its has some problem. its not running at the correct RPM. Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now you can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector. power ON the projector and watch.
Mar 27, 2011 | NEC VT670 LCD Projector
HELP! I changed the bulb already. My NEC VT 470 won't turn the bulb on. The green power light comes on, then the status light blinks green about 12 times, several rotations. Then the fan comes on, the...
Sounds like you lamp ballast has gone bad. I good way to verify this is, when you press power on the projector look inside the lens. If you see a small amount of light, then the ballast is good, and the lamp is bad. If there is no light then chances are the ballast is bad.
Apr 14, 2010 | NEC VT470 Multimedia Projector
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
250V T6.3AH Slow Blo Fuse
Depending upon the way in which the lamp finally smoked, it is not unusual for the feeder fuse to blow. Replace the fuse and try the projector. As long as you haev a new lamp, it should work OK.
Sep 11, 2008 | NEC VT670 Multimedia Projector
Lamp not lighting
Reset the lamp and try it.
Mar 28, 2008 | NEC VT660 Multimedia Projector
NEC VT 470 projector won't work at all
Try pressing the HELP button. Don't release and press the power button. The LED lights should blink. Release then try to power on again.
Jan 11, 2008 | NEC Replacment Lamp Projector Lamp for...
No Picture on my nec VT676 model
Hi there
I'm shocked that NEC can't answer this guys.
The NEC's & Acer's make use of teh status lights and beeps to warn you that your lamp needs replacement.
Nov 13, 2007 | Office Equipment & Supplies
Hey SithPitt,
sorry I can't help you, but maybe you can tell me where to find the fuse. I opened the projector and have problems to find a fuse on a first view. The suspected place near ON/OFF is well shielded.
Jul 03, 2007 | NEC VT670 Multimedia Projector
NEC VT670 Multimedia Projector Logo
96 people viewed this question
Top NEC Office Equipment & Supplies Experts
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
