Question about Ridgid Saws
I moved my table saw from one location to another and disconnected the motor in the process. Now I can't get the belt to stay on.
    Problem Solver:
  • 5 Answers
Chances are that the motor is mis-aligned with the saw pully. Make sure the power is off and remove the access panel so you can see both pullys at the same time. Take a straight edge and place it alongside the saw pully and then check the motor pully to see if it is aligned with the saw pully. If not then some shimming of the motor mounting points may be necessary to achieve alignment. Then check the belt tension by grasping the drive belt halfway between the two pullys and squeezing the belt together. It should have no more than 1/2 to 3/4 inches of play. If it is more than that adjust the motor mounting points to remove the slack.
Posted on Mar 20, 2011
I have a Delta 36-979 table saw. In a recent move, it seems I lost the drive belt when I took the motor off for ease of moving. Can I get a replacement at a local auto parts store or do I need to order...
I can't find any specs for this belt, You can buy it online from them the part number is 643928 and the cost is around 7.22, Sorry but this is the only information I can find for you.
Apr 17, 2011 | Delta 36-979 10" Left-Tilt Contractor's...
Belt jumps off on start up..no problems until it was transported to another location..what should I check
Look for adjustment for tensioning belt. The motor is probably mounted on a sliding bracket arrangement which came loose during transport slackening the belt.
Nov 30, 2010 | Ridgid Heavy Duty 10" Portable Table Saw...
Table saw stopped when cutting a dense piece of wood. Now just hums when turn it on. Not locked up, the pully will move by hand. Do you think replacing the capacitor will work. No restart button. ...
One thing you might try is to raise blade to highest setting possible and spin blade as rapidly as you can by hand and turn on while blade is still moving. see If motor will go ahead and come up to speed or try to I would replace start capactor. Also check brushes and make sure motor is clean and free from saw dust. Lube motor if equipped with oil ports. I would just use 3-4 drops and wipe off excess. Blow out with compressed air and also make sure belt is not to tight. I hopes this helps you, Thanks
Nov 17, 2010 | Craftsman 10" Table Saw
I have a Delta 10" Series 2000 Contractor Table Saw and my motor will not stay in position when I'm using it. The motor falls over or downward and causes my belt to rub against the belt guard. What...
Gravity holds the motor in place and the weight of the motor keeps the belt taut. If your belt is rubbing because the motor is too low, your belt may be too long. Have you replaced it recently? Also check that the bolts holding the motor to the motor mounting plate are tight. If the motor is shifting in use, that's not good...
Assuming this is a Delta 36-444, the manual is here. See pages 10-14 for motor setup instructions to make sure yours is setup properly.
Safety note: as with any power tool, unplug it before you start working on it.
If you need more help, please ask. If this answer was useful, give it a thumbs up.
Jun 13, 2010 | Saws
Motor base needed for 10" table saw
My 10" Craftsman saw started life with a 1 hp motor. I'm on number 3 motor which is 1 1/2 or 2 hp. 1 hp seems to weak. The pulley diameter is about 2". The motor needs to rotate as the blade is moved from vertical. Mine is mounted to back of the blade arbor. The mounts needs to be adjustable for adjusting tension to the belt. McMaster Carr would have the start of a motor and base.
Sep 11, 2009 | Craftsman 10" Table Saw
Blade and motor not stable after replace belts
If you mean there is vibration that moves the unit, check thaat the bllade is PROPERLY indexed on the mandrel. Sometimes they can get off center.
Sep 06, 2009 | Saws
Working fine and now it wont come on
Check to see if there's a reset button on the motor, usually on the end a small thermal switch you push in until it clicks...
Otherwise, check to make sure the switch hasn't shorted out somehow...disconnect the drive belt and make sure you have power to the motor when the switch is on, etc...
Aug 08, 2009 | Craftsman 10" Table Saw
I have a 10' Craftsman table saw model 315-218290. I ordered new belts I removed the motor how do you attach the belts, I tried to stretch it won't work
Jun 20, 2009 | Craftsman 10" Table Saw
My Skil Saw 10 will not start now.
depends wether the saw is belt driven or gear. just because you cant hear the motor doesnt mean its not running.
Apr 25, 2009 | Skil 10" Table Saw 3400
Saws Logo
150 people viewed this question
Top Ridgid Saws Experts
John Trevino
Jim Thurston
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Ridgid Saw Expert? Answer questions, earn points and help others
