Question about Fellowes Office Equipment & Supplies
Bin pen light is lit and will not extinguish. Bin is fully inserted, but I cannot go any further. Can you help?
    Genius:
  • 1,157 Answers
Hi r_almeida32,
Seems like the bin full light keeps coming on even there is no paper in the basket. This issue happens when machine has a false reading, like bin full light comes on but the shredder basket is empty. To correct the problem, just check the sensor and remove the dirt on it. Please follow the steps below for additional troubleshooting.
1. Locate the sensor. Please locate the sensor on the bottom side of the shredder head.
--> pull the basket from the unit, and remove the shredder head from the cabinet. Pull straight up to remove it. You may need assistance to do this because the shredder head will be heavy.
2. On the bottom side of the shredder head, find the 2 raised plastic housings ( it is like a shamrock or clover ). It has 2 metal screws in each. Now, on each of these casings, facing each other you can locate the sensor which look like "small glass beads" or "marbles". Wipe the sensor with a soft cloth dampened with plain water.
--> these procedure most often solve the problem. I recommend to periodically clean this sensors along with routine maintenance on the machine.
If this does not solve your issue, please contact the manufacturer.
If you need the manufacturer contact information just click the link below.
Fellowes contact information
Hope it helps.
Thank you for using FixYa.
Posted on Mar 19, 2011
Neato stopped working followed manual directions cleaned everything carefully blue light flashing then green light flashes and then turns off when red lite appears
Hello, Diane -
Your question landed in the Fixya.com category of Television & Video. Somehow, I suspect your question is about a robotic vacuum cleaner and not TV or video.
If I am correct, this MAY be the problem:
[From: https://support.neatorobotics.com/hc/en-us/articles/225369047-Why-does-my-Neato-Robot-sometimes-stop-and-start-by-itself- ]
[Quote]
Why does my Neato Robot sometimes stop and start by itself?
Debris around the dirt bin might be causing the bin to dislodge. As a safety feature, the robot turns itself off when the dirt bin is not fully inserted - and continues cleaning when the bin is back in its proper position.
Check to make sure the area is free of dirt and that the dirt bin is properly inserted into your robot.
[End quote]
You can also contact Neato Customer Care and state the problem. This is the Contact Us link:
https://www.neatorobotics.com/contact-us/
Jan 10, 2018 | Televison & Video
Cleaning ladies were here yesterday. Evidently they did something because today when I turned it on both the red and green lights are lit and the expected humming sound is absent.
Check for the trigger wire. On Fellowes it is usually a thin wire in the middle of the unit that triggers the shredding mechanism. Also check to be sure the shredded recepticle is pushed in fully.
Sep 01, 2010 | Fellowes Office Equipment & Supplies
2001 Rodeo 6 cylinder. ABS light comes on when I start car. Have had the brakes check and they tell me there is no problem. Car has about 115,000 miles on original brakes but I am told it still has...
The ABS will come on and stay lit for a couple seconds when you start the car. It should then extinguish. This is normal operation. If it stays lit there is a problem and the ABS will not be available, although the brake system is still fully operational. Leave a message if this is not solved.
Aug 02, 2010 | 2001 Isuzu Rodeo
Having a gearbox fault that lights and i can't shift. When i turn the car off and turn it back on, it extinguishes. Now the gearbox light is lit and the engine light is lit???
Check the fluid level in the gearbox firstly.
Other 2 things it could be are the torque converter or slave cylider for the clutch.
Most likely it is the torque converter as the engine light is on aswell. although these may not be related. you will need to get it on a code reader, diagnostic machine to be sure.
Jan 22, 2010 | 2004 Jaguar X-Type
Power & Resume light stay lit. Cover and rear access panel have been closed repeatedly.
The spring contacts on the rear access cover were not seated fully in place. Over time fatigue meant they failed to touch the contacts at all. Fully inserting the spring contacts solved the problem.
Nov 23, 2009 | HP Officejet Pro K550 InkJet Printer
Pen drive
It seems FAT system on you pen drive is corrupted. I'd advise you to take your pen drive to some other pc connect it over there and whatever pops-up don't do anything simply go to command prompt and format your pen drive from cmd prompt. If you need further assistance plz do comment back.
Jul 25, 2009 | Lexmark X3350 All-In-One InkJet Printer
On inserting the pen drive,its showing that no disk is inserted into H drive.And on seeing the properties of the pen drive,its showing Zero MB free and Zero MB in use.Its not even being formatted or...
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jul 07, 2009 | Pen Drive IVO MP3 Player
Asking insert drive after inserting....
Try the link.It may help.
http://www.recoverdatatools.com/pen-drive-data-recovery.html
Jun 01, 2009 | Transcend T.sonic 612 MP3 Player
1997 Tarus dome light and floor lights will not go out.
This is usually caused by the switches sticking in the door latches. Try spraying some WD40 in the latches and open and close the doors a bunch of times that should take care of it.
Dec 11, 2008 | 1997 Ford Taurus
Moser baer 4 GB pen drive is not working
i have 4gb moserbaer pen drive when i inserted it in to the Xp system it give the message "Insert disk"
plz. solve this problem.
Aug 05, 2008 | Computers & Internet
61 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
