Question about Garden
I have a Ariens 1028 riding mower. The clutch slips or doesn't seem to engage. I've adjusted the clutch but to no avail. Any solutions?
  • 109 Answers
SOURCE: lawn tractor won't stay running if clutch is released.
There is an operator presence switch under the seat...it is more than likely faulty and must be replaced in order for the mower to run right.
Posted on May 03, 2009
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
  • 19 Answers
SOURCE: Older model Ariens ride around lawn mower - drive belt slips off
it could be the belt has streched
check tensioner if has one and check all nuts and bolts tight
Posted on Jun 23, 2009
  • 61 Answers
SOURCE: pto clutch will not engage
ck fuses, and switch, for 12 volts
Posted on Sep 07, 2009
  • 299 Answers
SOURCE: Craftsman riding mower won't move.
yes it is a bad belt unless it is a hydro-stat(no clutch) you need to look under the mower and see if the belt is on correctly
Posted on Sep 30, 2009
Blades will not engage on Ariens A22A46
Some Ariens mowers have electric clutches. You can check for it and wiring to it. Maybe a wire is disconnected, wore thru etc. It sounds like it's not engaging.
Oct 14, 2016 | Ariens Garden
Why won't the blades engage on my Ariens 911403
Chances are the deck drive belt has been knocked off one of the pulleys or the drive clutch won't engage properly. With the spark plug wire removed, rotate the blades by hand and make sure they both move together. This verifies the blade linking belt is OK. Now engage the blade operating control and feel for resistance as you rotate the blades. If you feel no change in resistance, remove the belt cover and reinstall the drive belt over the pulleys and tensioner/clutch mechanism.
May 31, 2014 | Ariens 34 In. Zoom Series Riding Mower
Ariens 19.5 hp drive belt slip
Question how old is the mower? Drive belt may need to be replaced due to being streched . Also is the clutch fully engaging , are there any worn pulleys?
Nov 10, 2013 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Why won't my blades engage on my ariens zoom 1534?
take a look at the wires going to the clutch and make sure the wires where routed the right way and not rubbed against the belt and damage the wires
May 22, 2012 | Ariens 34 In. Zoom Series Riding Mower
Poulan 42 parking brake slips
look at sears parts online
Mar 31, 2012 | Garden
Blade clutch on model 915101 does not disengage. switch is good, but cltch does not stop.
I would disconnect the wires from the switch and see if the stay engaged, if they do then something is wrong on the clutch, if they do not stay engaged then it is the switch/connection. Hope this helps Tim
Oct 29, 2010 | Ariens 34 In. Zoom Series Riding Mower
Snowblower wheels wont engage when they are on the ground they move slowly when I lift it
1) Traction drive belt slipping or worn
a) idler pulley not fully engaging
b) cable/lever adjustment
c) spring missing or broken
2) Friction drive disc slipping or worn
a) rust on hexagon shaft not allowing friction disc to move
b) missing or broken engagement spring
3) clevis pins missing or broken on wheels
4) roll pin on drive shaft missing or broken
inside the cover for the gearing mechanisms, chain drives, gears ect.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Dec 06, 2009 | Ariens Garden
Ariens ezr1742 mower blades do not engage....noticed after went over a stump.
The common cause of this problem is that one of the safty switches has come dis-connected or has failed since most every newer mower has a electric clutch controlling the mower deck PTO there are safties bilt in under the seat and in other locations to make sure everything is ok before the blades engage, easiest way to test this is to run a jumper from the positive post of the battery to the input wire on the electric clutch assembly making sure all other wires ade dis-connected from the clutch and see if the blades engage if so then usint a continuity tester check all the wires and switches to this item to check for a faulty switch or broken wire. Thanks Don
Nov 09, 2009 | Ariens 34 In. Zoom Series Riding Mower
Arien524 when clutch is engaged the wheels donot pull right away
Sorry I should have posted this as a solution.
You might want to check the friction wheel to see if it is either worn down and needs adjusting or if it needs replacing.It could very well be just an adjusting. The friction wheel is located inside the panel under the engine. When looking inside the panel and you pull on the handle to engage the wheels you will see the round disc pull towards the friction wheel if it doesn't pull in tight enough you will have problems.Also check the belt and the idler pulley for the drive make sure the idler pulley moves easy and that it puts enough tension on the belt.
Dec 13, 2008 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
131 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
