Question about Drills
Can't get the chuck off to replace it with a key less one.
  • 2,176 Answers
Click on my name and go to my area and under the tip section you will find detailed instructions on how to remove the drill chuck. Please let me know if you have trouble or need more assistance, and if I have helped you would you please vote accordingly. Thank you
Posted on Mar 20, 2011
How do you get a drill bit or screw driver bit out of a Cordless Drill? It has been left to me. VPX 1222. I dont know how to use a drill, never had one before.
If it has a key-less chuck, hold the skirt behind the chuck proper and turn the chuck clockwise with the drill point facing away from you. If it has a chick that has a ring of teeth macnined into the outer band, you need a key to release the bit in the chuck. Keys vary greatly and if you do not have one, you will need to take the drill to a hardware shop for them to supply you with the correct size and configuration key. If you do have a key. place it in one of the three holes in the front part of the chuck, engage the gear teeth and turn the key anti-clockwise to loosen off the chuck jaws and remove the bit. If you require any more information, feel free to approach me at any time. Please rate this answer to your question.
Jun 05, 2011 | Drills
I have a 0302-20 1/2 drill how do i remove and replace the chuck ? i have the bolt out of center.
Chuck the handle of the chuck key in the chuck.Find a drill bit that fits in one of holes that the chuck key fits in.Then use a flat screw driver to lever off of the drill bit and the teeth to tighten the chuck .Use a towel and hold the drill motor,be careful not to squeeze to tight just enough to hold the drill from moving.Use a harmer and strike the chuck key and that should loosen the chuck.A 1/4 inch chuck key will work as well.If this is a key less chuck then use a small pipe wrench and hammer on the back part of the chuck with the handle left as you look at the drill.Good Luck & Thank You for choosing FixYa.com.
May 17, 2011 | Milwaukee Garden
Chuck is stuck open cant get to free how do i replace chuck
You need to secure the drill - perhaps in a vise - and insert the chuck key (if it is a key-less chuck you may have to use a pipe wrench or something similiar) and give the key (or wrench) a sharp hit to release it. The chucks are screwed onto the drill with a right hand thread. Let me know if this works for you. Thanks
Jan 02, 2011 | Milwaukee 0200 20 Drill 3/8 1200 Magnum
KEYLESS CHUCK WAS JAMMED WITHOUT DRILL BIT. I loosened it but now one of three teeth sticks out further than other two. How do I get them back in alignment? Black and Decker VP825 type 1.
You can't the teeth inside are either broke or it skipped. The easiest thing to do is buy a new key less chuck from your local home center and replace it a cheap one goes for about $9.99.
Jul 24, 2010 | CRL Corded Electric Drill - 3/8" Keyless...
Trying to remove a jacobs key less chuck 500 series fitted to a DS18DL Hitachi drill
It twists off counter clock wise. The best way I have found to remove the chuck is to stick a screw driver into the chuck, tighten the chuck, hold the screw driver in some type of vise and run it all full speed in reverse
Jan 02, 2010 | Hitachi DS18DMR 18V 1/2" Driver Drill
How do you remove the bit
hold on to the key less chuck and put the drill in reverse. if the chuck doesn't release the bit hold on the top collar and twist the chuck
Dec 06, 2009 | Ryobi 18v Variable Speed Right Angle Drill...
3/8 Drill Driver, chuck replacement.
hi friend,
Step 1. Determine what kind of replacement drill chuck you want - a keyed chuck or key less chuck. Over the years, key less chucks have been widely used for handheld power tool drills, due to their improving grip torque and convenience.
Step 2. If you prefer replacement key less chucks, then you have to know what type of key less chuck you will need - a single sleeve key less chuck or a double-sleeve chuck. You can simply determine it by checking your current chuck. If your current chuck is a keyed chuck or a double sleeve chuck, then you will need a replacement double-sleeve key less chuck. On the other hand, if your current chuck is a single sleeve chuck, then you should get a replacement single sleeve chuck.
Step 3. Confirm the threaded mount size (spindle size) on the chuck. 3/8"-24 threaded mount for 3/8" capacity drill chucks and 1/2"-20 threaded mount for 1/2" capacity drill chucks, but there are some exceptions where just the opposite may occur. To be safe, always check the threaded mount before you buy replacement drill chucks.
hope this helps u
please rate me.........................
thank u for using fixya
regards
sivaranjini
Nov 26, 2009 | Craftsman 19.2V C3 DRILL/DRIVER
Hi, I let a friend use my Bosch 5600 PSE key less
you can't drill counterclockwise the bits are setup to drill clockwise and the chuck would become loose. try using two wrenches to free up the chuck then spray a little wd40 in it it is just bound up
Nov 05, 2009 | Microwave Ovens
Drill chuck swap
1. Turn the screw clockwise to take it out.
2. Then you needs 3/8 allen key & insert the short side of the allen key & tighten the chuck.
3. hold the drill at the edge of the table & wack the allen key
counter clockwise & do it again as needed.
4. dewalt keyless chuck will fit but you might add a washer to insure the chuck is not rubbing the clutch collar.
5. putting it back together the other way.
Jun 01, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Drills Logo
Top Drills Experts
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Drill Expert? Answer questions, earn points and help others
