Question about Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive
I've downloaded documents & pictures on my passport yesterday. Everything seemed to work OK. I did however, have to plug it into the USB port twice to get a connection. I'm quite sure the downloads were copied. Today, I plugged my passport into the USB port on my computer there is no connection. Nothing appears on the screen indicating the passport has been plugged in no matter how many times I try and regardless of which USB port I use. I have an old jetflash memory stick which I tried plugging into the USB port and the computer recognizes it instantly. No problem there. I don't undrerstand why the computer won't recognize my "Passport Essential" when I plug it in. I've been given a service number: 031811-8446802 Thanks, Jack
  • 449 Answers
Sometimes, portable drives need more power than a USB port provides. If this is a laptop, be sure it is plugged in to power and not running off battery. Also, if you have TWO usb plugs on the end of the wire, plug them BOTH in. This provides the extra power needed.
Posted on Mar 20, 2011
I have a WD Passport External Drive. (WD1600ME-01) I know it works but all the wires I have that fits the Drive don't seem to work. When I connect the wires, I can hear the Drive go on and shortly aft
You may first want to try disconnecting any other USB devices, to guarantee that the drive is the only power-drawing device. Drives typically need all 500 mA that a USB port normally provides.
Cables do wear out, especially those handled often. Mini-USB cables are pretty common and can easily be replaced.
WD Support Downloads My Passport My Passport Essential
Dec 02, 2014 | Passport Computers & Internet
Need driver & software
The Driver and software are built in, Stored on the WD it's self..
all you need to do is plug it in. It is a plug and play device.
WD Passport is not supported on XP or Vista 64bit
Xp and Vista do not put enough power to the usb ports to fire up the drive.
there is a cable you can get from WD that plugs into 2 USB ports to solve this issue.
Jul 02, 2011 | Western Digital WD Passport 250GB Portable...
The computer doesnot reconigze the disk in the usb port
Unplug your drive and then head over to:
http://support.wdc.com/product/download.asp?groupid=209&level1=&prodid=&modelno=&lang=en
and download the drivers and software for your hard drive.
Then plug in your drive and your PC should then read your drive.
May 24, 2011 | Western Digital My Passport Essential SE...
How do i use this. to backup my files. were to plug it in to my dell laptop.
Open "My Computer", and look at each icon, e.g,. 'A:' and 'C:' and 'D:'.
The cable from the Passport will only fit into a 'USB' port on your computer. Your computer may have more than one such port.
Just pick one, and connect it.
Once it is connected, look again at that 'My Computer' window.
There should be another drive-letter, assigned by Windows to your Passport.
Open 'My Documents'.
Click 'Edit'.
Click 'Select All'.
Right-mouse click on one of the selected objects.
Point at 'Send To'.
Click the drive-letter assigned to the Passport.
The selected files will be copied from your 'My Documents' folder onto the Passport.
Oct 30, 2010 | Western Digital WD Passport 250GB Portable...
I purchased the unit and plugged in. Is there something else I should have done. It doesn't seem to be working.
If you plugged it into an unpowered USB hub, it may not be getting enough current. Try plugging it directly into a USB port on the computer. It requires 2 amps to spin up and unpowered hubs only provide 500ma for all connectors, just a quarter of the required power. Or you can buy a powered hub, which relieves the strain on your computer's power supply.
Aug 05, 2010 | Western Digital Passport 320GB External...
MY PASSPORT ESSENTIAL WD1600ME-00 is not recognized by plug-and-play in either of my HP Desktop Windows computers (One with XP, one with VISTA). Power light comes on when attached to any USB port. Device...
You run MS Windows Update to download and install the latest OS updates. Your WD external HDD should be detected after OS update.
For non updates system, try to connect WD to the USB Port where it worked before. If you have 4 USB ports for instance, try to connect it to these ports one try at a time. Windows XP might have assigned one USB port for your device before when it was working just fine.
Feb 02, 2010 | Western Digital WD Passport 250GB Portable...
Keyboard not working after being unplugged & used on another comp
Close down computer and reboot and pray. I mean to close down not reboot, not hibernate, not sleep.
Why? The electronic chips chatter before the operating system boots up. BIOS asks who is here? Any Keyboard, and other internal bits.
For readers... Cold rebooting fixes a multitude of problems with not working. OK, it does not fix everything, but it is a good first try
Sep 08, 2017 | Dell Computers & Internet
I have a WD passport 320gb, at first it worked one of my usb. then all of sudden, it stop recognizing my WD Passport with one usd port, so i plug it in another usb then it works. and after a couple of days...
Are you using an external power supply for the disk? If not, you might be overloading the USB port. It should not happen, but USB ports are limited in the amount of power they can output. Especially laptops might face such problems.
Do other USB devices still work on those USB ports? If so then the port is at least not broken.
Sometimes you can uninstall and reinstall the USB hubs and controller devices in the Device Manager to fix USB problems.
For other ideas on troubleshooting external hard disk issues, you can check: www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Jun 13, 2009 | Western Digital Passport WDXML800UE...
My computer does not recognize WD Passport WD2500XMS-00
I use a USB extender cable so I do not have to get down on the ground and plug stuff into my USB ports behind my computer. Everything that I own works through this cable except the WD passport drive. (It is a 2.0 USB cable at that so that is not the issue, plus 1.0 should theoretically still work, just not at 2.0 speeds)
SO...I tried to plug it directly into the USB port on the back of my computer and it worked instantly.
Other people have reported a fix after finding that their cable was loose. This USB cable that comes with the drive seems to be picky for some reason. Perhaps these are faulty cables somehow. Hopefully this will help some people.
lefteris from greece
Mar 26, 2009 | Computers & Internet
My PC is not recognizing my WD Passport 120GB USB external drive. I used just few days ago and connected the usb cable to my computer and the WD Passport drive and not recognized on my 2 laptop and 2 other...
I had the same issue. Its not a power issue because it shows up in device manager. Heres what I did.
Right-click on my computer and click Manage>Disk Management
Your drive should show up there. Right-click on it. If explore is not grayed out, assign a drive letter to it and you should then be bale to see it in my computer.
In my case explore was grayed out. I had to click on the option to format the drive. After re-formatting the passport explore was available. I then assigned a drive letter to it and I have access again.
I guess somehow using it on multiple computers srcewed up the file-system on it. I was using it between windows and linux.
This fixed my problem.
Oct 28, 2008 | Western Digital Passport WDXML800UE...
Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive Logo
103 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
