Question about Fujitsu Computers & Internet
Hello, I have an Amilo pi 1536 and suddenly all my network adapters stopped working. Windows displays error 31 in all of them.
  • Anonymous Mar 19, 2011
    Hi Vc: I already did the reinstall, but it didnt work. We might have corrupt files at the registry. Ive
    just applied ccleaner .Tks for answering so fast.
    Master:
    Sergeant:
  • 381 Answers
Use an another laptop /pc and download the appropriate drivers from the fujitsu siemens website and then re-install them. possibly corrupt files at the registry?.....
let me know how you get on!
Posted on Mar 19, 2011
Display Error C:31:42
The Sony website trouble code sais your Camcorder has a problem and needs a power reset.
The remedy in the SONY troubleshooting guide is copied below.
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
Nov 05, 2007 | Sony Handycam DCR-TRV110 Camcorder
Hi I have a fujitsu amilo pi 1536 laptop and wish to return it back to factory settings. All i have is the laptop and no recovery disks etc. I've tried pressing F8 which brings up the windows advanced...
OK
You have Vista
EASY
In CONTROL PANEL select RECOVERY
Then "Advanced Recovery Settings"
Then "Return your computer to factory settings".
Be AWARE you will loose all of your files and after market downloads.
May want to BACK-UP!
Aug 02, 2011 | Fujitsu AMILO PC Laptops
Problems with the network adapters in my Amilo 1536... Error 31 in all of them
Sounds like a driver issue here is a link to all the drivers for your model:
http://uk.ts.fujitsu.com/support/downloads.html
Try downloading and installing the correct one you need.
Hope this helps
Mar 19, 2011 | Fujitsu AMILO PC Laptops
AMILO LI 2727 cannot attach to my (or any other) wifi network since upgrading to windows 7
First Try This
Right click on the Computer desktop icon > Manage > Device Manager > Network adapters > right click on your Wireless Network adapter > Update Drivers Software...
If the Windows was unable to find drivers: go to the manufacturer website of your netbook > find your netbook model > download and install drivers for Wireless adapter
OR
You can try this solution:
Copy and paste the below text in to a text editor, save it and give it any filename with the extension .vbs, eg wirelessstart.vbs and copy a shortcut to your startup folder:
Set WshShell = WScript.CreateObject("WScript.Shell")
Set oExec = WshShell.Exec("C:\Program Files\Launch Manager\WisWBSet.exe")
do while WshShell.AppActivate("Wireless Status Option")=False
WScript.Sleep 100
loop
WScript.Sleep 100
It would be better that you restart the system after doing that.
And Thanks.
Mar 31, 2010 | Fujitsu AMILO PC Laptops
Hello, i have a hp notebook which code 31 error on
http://support.microsoft.com/kb/932520
Microsoft says to Ignore the problem, and the adapter will continue to work correctly. If the message is really annoying maybe you can try turning off IPv6.
Control Panel\Network and Internet\Network Connections
right click your network card>properties
uncheck the IPv6 box
that'll turn off IPv6-then just disable the adapter driver
Feb 23, 2010 | HP Pavilion dv6000z Notebook
Fujitsu amilo simens Pi1536 and Pi1556 bios password chip locatio
Hi ,
Replacing the existing BIOS chip with a new one you can buy from your specialized electronic shop or your computer supplier. It's a quick operation if the chip is inserted on a base and not soldered to the motherboard, otherwise you'll have to unsolder it and then put the new one. In this case would be more convenient to solder a base on which you'll then plug the new chip, in the eventuality that you'll have to change it again. If you can't find the BIOS chip specifically made for your motherboard, you should buy one of the same type (probably one of the ones shown above) and look in your motherboard manufacturer's website to see if there's the BIOS image to download. Then you should copy that image on the chip you bought with an EPROM programmer.
Important
Whether is the method you use, when you flash the BIOS not only the password, but also all the other configuration data will be reset to the factory defaults, so when you are booting for the first time after a BIOS flash, you should enter the CMOS configuration menu (as explained before) and fix up some things.
Also, when you boot Windows, it may happen that it finds some new device, because of the new configuration of the BIOS, in this case you'll probably need the Windows installation CD because Windows may ask you for some external files. If Windows doesn't see the CD-ROM try to eject and re-insert the CD-ROM again. If Windows can't find the CD-ROM drive and you set it properly from the BIOS config, just reboot with the reset key, and in the next run Windows should find it. However most files needed by the system while installing new hardware could also be found in C:WINDOWS, C:WINDOWSSYSTEM, or C:WINDOWSINF .
ERNZ
Jan 16, 2010 | Fujitsu AMILO PC Laptops
4to6 adapters 0002/0003 are not working due to
Check out http://acer.com and look for updated device drivers for your computer.
Nov 09, 2009 | Acer AM1610-UD2180A DT E2180 2.0G 2GB...
Error code 31 4 to 6 network adapter
Check these things:
  1. Is you Ethernet adapter Active
  2. Is your Cable the correct one (NOT a cross over)
  3. Refresh your IP Address for your Ethernet Card
  4. Reboot your computer and power down your modem, then power the modem up AFTER your windows is logged on
  5. Verify your modem "really" can connect, use another computer.
  6. Verify the are no network issues with your ISP
Apr 16, 2009 | Acer AM1610-UD2180A DT E2180 2.0G 2GB...
Password when I start up my Fujitsu Siemens Amilo Pi 1536
hi astrid
can u please explain is the password on bios
Jan 07, 2009 | Computers & Internet
Computers & Internet Logo
133 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
