Question about Exercise & Fitness
My healthrider h120t turns on and the console lights up with the magnetic key inplace but when I push any of the funcions buttons, it beeps and nothing else. Even if I leave it on and do not puch any buttons, it beeps every few seconds. What is the problem?
    Genius:
  • 1,196 Answers
I will suggest you try reset it, Press POWER to turn off the treadmill, At the same time, press and hold the +, -, and POWER keys. Continue holding all keys until their is nothing on the screen display. Release the keys. insert the key properly and see what happens.
Posted on Mar 19, 2011
Healthrider 15.5 won't run,motor makes alittle grunt,turns alittle but won't run,incline motor works
hi Geoff,
if it is contain belts please check.and try to move running belt it must run freely.sometimes it must stuck because of long idle time.
in electronic circuit the large smoothing capacitors can be damage because of long idling time too.
let us know the status,
regards.
nuwan
Jan 10, 2014 | Exercise & Fitness
Healthrider 14508 tv is upside down
please reset the machine.use another magnet, you can buy from any hardware like home depot, and replace and try again. Disconnect the power by 15 minutes, and the batteries. Reset too the button to the side from power button.
And try again.
Then RUN the software calibration for diagnose, troubleshooting, and fix it. go under the Hood Motor and follow the steps
God bless you
Sep 02, 2012 | Exercise & Fitness
Tx 2.5 is on 7
To reconfigure the controller to factory setting:
1) Hold both the "Mode" and "Stop" buttons down while removing the magnetic key.
2) While continuing to hold both buttons down, replace the magnetic key. All the lights will light up and "beep".
3) Whille continuing to hold both buttons down, press the + button.
It should now be reconfigured.
I hope this helps
May 28, 2012 | Sportcraft Tx2.5 Tx 2.5 Treadmill Motor...
Vfit pst 04 problem ---- (dashes) on display
1) you must replace the key by smal magnet, since the key is magnet, you can buy from any Hardware.
2) Adjust the reed switch, see the diagram, clean, tight the connector very well.
God bless you.
May 14, 2012 | Exercise & Fitness
My treadmill will light up an make a beeping nose when a button is pushed. The treadmill is pluged up and the red cord magnet is on when the buttons are pushed. However it just does the same beep for...
If the screen is lit and the screen shows that the belt is moving then it’s the motor controller. If the screen does not show that the belt is moving then it’s the console.
Oct 20, 2017 | Horizon Fitness T82 Treadmill
UNIT DOES NOT POWER UP. I CHANGED THE POWER BOARD WITH NO RESULTS. POWER BOARD 120 VOLT LIGHT IS ON. 9 VOLT DC LIGHT IS ON. PWM & TACH LIGHTS ARE NOT LIT. CONSOL DOES NOT LIGHT UP
If its a Icon Health and Fitness branded treadmill (proform,image ,healthrider etc.)The safety key activates the on off switch for the console. (micro switch activated by safety key)Check for 9-12v going to console. Unless it has a magnet switch. What brand and model ?
Sep 11, 2010 | Reebok Acd1 Treadmill Motor Control Board ...
I have HealthRider model HRTL71830. Was using it for about 3 years. A few days ago I moved it a bit and afterwards the console stopped responding. I'm not really sure if that's the cause of the problem or...
Unfortunately, you need to replace the entire console. HealthRider's consoles are notorious for this behavior. The company that manufactures them only sells the console as a whole unit so you can get individual parts. Depending on the age of the machine you'll be looking at between $300-$800.
Jun 18, 2017 | HEALTHRIDER Exercise & Fitness
Exercise & Fitness Logo
623 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
