Question about Konica Minolta magicolor 2400 Laser Printer
Status monitor for Konica Minolta 2400w
How do you get this program to work? It shows up on my menu but noting happens when I select it. I have the blinking errow light and can find nothing inside the printer to account for the error.
  • Anonymous Sep 26, 2008
    When I run the status monitor, nothing happens. If I start up in safe mode, then the status monitor runs. But of course the printer is disabled in safe mode so that's not exactly useful.
  • evangelassem May 17, 2009
    The status window will not open. I've tried to uninstall my printer but a message stating "The spooler is unstable" pops up.
  • 3 Answers
The status software does not run when the printer is shared. Whenever I have a problem I have to unshare the printer then run the status and it will show up. I then resolve the problem then turn the share back on.
Pain I now but it works
Posted on Dec 17, 2008
Concerning using the status monitor program for Konica Minolta 2400w Laser Printers. Turn OFF printer sharing. Go to your Minolta 2400 magicolor printer properties, then sharing, and then turn OFF printer sharing, then click APPLY. You can then open the status program for use.
Posted on Jun 16, 2009
    Problem Solver:
  • 3 Answers
Sometimes there is a problem with the registry. For example, sometimes in the Windows Task Manager>processes, we can see the program running but it does not show in the windows or monitor. Sometimes we can end the process by right clicking on it and end the process. then start it over again. I guess if all fails, uninstall it, remove all traces from the pc including inside the registry and folders, and then install it again.
other reasons might be your internal firewall, spybot resident, virus some software blocking it from running.
Posted on Oct 13, 2008
  • 167 Answers
Does this application show up in the task bar? If so, right click to enter the program.
You can turn this off in the driver properties I believe.
The error light can mean a range of different things, which you can alter/customise by right clicking.
Posted on Aug 06, 2008
How do I disable the printer's status monitor. There used to be a box to uncheck after running 'msconfig' that would disable, but I can't remember the name of this check box.
try running a search through the start menu search facility if you are using windows., that might throw up it's location. If not , go into control panel/program management
Printer monitor may be a listed [rpgra,, you can, if it is listed, highlight it and uninstall it
Jun 08, 2015 | Konica Minolta magicolor 2400W
KONICA MINOLTA 2400W PRINT BLANK PAGES
Verify the drive transmission mechanism to developing unit,the image transfer current terminal and the scanner drive transmission mechanism.
Feb 13, 2013 | Konica Minolta magicolor 2400 Laser...
Konika Minolta 2400W can not connect. Clearly Windows XP sees it, and the driver is installed etc. When I plug or unplug the USB cable, Windows plug 'n play notices the difference. And the USB cable works...
Everytime you disconnect and reconnect the USB cable to a different port, unfortunately, Windows creates a new and distinct copy of the printer. You can see this by looking at the Windows Printers folder. The solution is when you change around USB ports, right click on the printer icon that is actually the active one (the other copies will be grayed out) and Set to Default. Then you can delete the other invalid copies. Then in the Minolta status software, go to the Display menu and Select Printer to change which printer is monitored to the correct copy. It's very stupid that Windows Plug n' play does this, but it does. So avoid change around USB ports on your Konika Minolta printer.
Jul 19, 2009 | Minolta magicolor 2400W Laser Printer
2400W error light keeps on blinking even before connected to PC ?
Start the Konica Minolta Status application from your PC, it will give you more details about the error.
Jul 03, 2009 | Konica Minolta magicolor 2400 Laser...
Printing with MAC 10.5 and Minolta 2400W. How can
http://www2.konicaminolta.co.uk/more-information/support.html
Try this link for any help.
Jun 16, 2009 | Konica Minolta magicolor 2400 Laser...
Replaced drum error light blinking
Start the Konica Minolta Status application on your PC and check the error, you should get more info there.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Apr 14, 2009 | Konica Minolta magicolor 2400 Laser...
Error light flashed when trying to print with Magicolor 2400W
Start the Konica Minolta Status application and check the error, you should get more info there.
Jan 20, 2009 | Konica Minolta magicolor 2400 Laser...
Konica Minolta 5430DL error code 111112
I couldn't find the install disks so downloaded the driver from the Konica website, un-installed the software and re-installed it. After calibrating the colours everything seems fine now.
Oct 01, 2008 | Konica Minolta magicolor 5430 DL Laser...
Status monitor
status monitor is a program what monitors your printer and tells you if something is wrong with the printer, since this printer has no menu/display.
download it from www.konicaminolta.eu/support
this program is included in printer driver, you just have to execute the exe, not add the printer from printing manager inside the windows
Sep 09, 2008 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta Magicolor 2400W -- Only Prints on Reboot!
I've had that problem before too, and found out that there were copies of the printer that had somehow installed themselves on my computer. All I needed to do was to choose to print with "konica minolta copy 1" instead of the one that I *thought* was installed and it worked. I then deleted the original printer and just stuck with the copy.
Jul 22, 2008 | Konica Minolta magicolor 2400 Laser...
Konica Minolta magicolor 2400 Laser Printer Logo
1,807 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
