Question about Polaroid PDM-0743 Portable DVD Player
Off and on the players says bad disc
Sometimes the DVD player works sometimes it does not. It will load disc and say bad disc. It is very temperamental
I turn it on and all i get is a blue screen. It will loading disc and say bad disc.
Posted on Dec 30, 2009
It says loading for a while then cannot read disk...sometimes it will work out of nowhere and then it goes bad again
All the disc u trying to play are original DVD disc and no scratches or dirt layer on it?Laser eye reader could be going bad.Tries websites like Amazon.com,Ebay.com buy a DVD laser eye cleaner and used it might help might not but the the only choices u have.
Aug 26, 2011 | Sony DVPFX970 9 in Portable DVD Player
Just Loading - Bad Disc
Normally I would say clean the laser lens, but I actually had the exact same model with the exact same problem, and that didn't work. I was able to get mine to work sometimes by turning it off and on and unplugging it, but even after opening it up, re-lubricating the gears, and replacing a few capacitors near the reader, I never did find a permanent solution.
I guess this isn't what you wanna hear, but I think its an untraceable problem with the motherboard.
Mar 25, 2010 | Cyberhome CH-DVD 300 DVD Player
Screen says loading.Then says (no disc)
There are a lot of reasons why that could happen. Sometimes when a DVD player needs to be cleaned it won't read a disk.Sometimes when you try to play a NTSC disk on a PAL DVD player or visa versa it won't play. Region coding could be another issue. And sometime home burned DVDs won't play in certain players.
Mar 03, 2010 | TruTech DV288B3 DVD Player
My N600D DVD shows wrong disc after loading
hi sometimes some dvd players will only play either -dvd or + dvd check your dvds and see what works best
Dec 18, 2008 | NexxTech N600D DVD Player
DVE not loadong
try cleaning your lens on the dvd player
Oct 03, 2008 | Memorex MVD2042 DVD Player
DVD players not always beinvg able to load DVDs
You have bad filter caps in the power supply c10 and c11 need replaced and unplug unit when not using as power supply stays on always,,,,as long as its plugged in its on(P>S>) that is
Jan 02, 2008 | Cyberhome CH-DVD 300 DVD Player
RCA DVD player "No Disc"
Cleaning the eye CAN work, especially if every disc your trying is failing, and the discs work on another player. Some links from reputable sources:
http://www.techlore.com/article/10478/
http://www.ehow.com/how_2036277_fix-error-dvd.html
After all that fails, it's probably time to change the DVD drive inside the player. Sometimes this is easy, sometimes not. :) I haven't been inside a 6300 but from looking at pictures, it's probably got a fully removable unit.
Of course, if you have a valid warranty, then when you're left with no solutions that don't void the warranty, you have to decide whether to try to pass it off to the warranty holder for repairs.
Dec 19, 2007 | RCA DRC6300N DVD Player/VCR
DVD cannot read DVD's anymore
Have you tried cleaning lense with soft cloth and alcohol? Sometimes cd or dvd cleaners do not work well for some systems.
Aug 30, 2007 | Durabrand DUR-1700 Portable DVD Player
Bad Disc
First determine where the problem lies. This can be done by analyzing what is happening. Is the disc spinning. Is it spinning erratically? If the disc is not spinning, the spin motor is probably defective. But sometimes you can be fooled, if the laser does not detect information of the disc, it will not issue a start spin motor command. If you can get the unit to work with the door open by defeating the switches,(Do not under any circumstances look directly into the laser)If you see the laser then the spin motor is bad, In either case the unit is is probably cheaper to replace than to repair. Scrivitron
Jun 20, 2007 | Polaroid PDM-1058 Portable DVD Player
Polaroid PDM-0743 Portable DVD Player Logo
1,572 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
