Question about John Deere Garden
~ 1991 STX38: Starter engages, engine cranks but won't start, when key is turned off, engine continues to crank. Disconnected battery to stop engine from cranking. Upon attempting to reconnnect battery engine cranked again without seat safety switch being made up. Also engaged PTO and tried to reconnect battery but it cranked again. Safety switches seem to be bypassed by this problem. Is this an ignition switch the likely problem?
  • 1,606 Answers
The starter solenoid may be stuck in the on-position. To check this, on the starter, remove the small wire connected to the solenoid coil terminal. If the starter still runs, the solenoid is stuck on. If rapping it with a hammer doesn't stop it, the contactor pin is welded to the motor contacts.
Posted on Jul 02, 2017
SOURCE: Ignition does not crank engine
If it is cranking over it should start. If you are just jumping the solenoid then you have a switch problem.If it is just plain not starting then you need a complete tuneup. It a process of elimination, you need air, gas, and a spark. Then it will run.donnyb60
Posted on Mar 23, 2009
  • 389 Answers
SOURCE: Trying to find wiring for safety switches: Brake,
When you turn the key to START does it click? If yes, replace the solenoid, if no, check first for a bad fuse. Usually right behind the engine on the right side of the tractor. Using a test light or VOM meter you could also check to see if it is getting voltage at the small post on the side of the solenoid. Depending on the make and model number of the unit, it could have one or two small posts, one would be ground the other 12 volt positive. If it only has one, it would be 12 volt positive. If you get voltage there when you put the key in START position , then it is definitely the solenoid
You weren't very clear but when you jumped across the solenoid if it started and ran that would verify one or the other of the above.
You don't give a model number and this is NOT a generic problem,every tractor has specific wiring so in order to find a wiring diagram, you first need to know the model number and brand.
Posted on Oct 22, 2009
  • 16 Answers
SOURCE: the pto on my 4 year old cub cadet lt 1042 will no...
check for bent parts try some wd40
Posted on Jun 02, 2010
  • 6468 Answers
SOURCE: pto wont work
try and bypass the safety switch on the clutch/brake pedal
Posted on Apr 13, 2012
  • 126 Answers
SOURCE: Can malfunction of PTO or other safety switches prevent start up of mower
You didn't state the model or brand of tractor, but usually the way the cranking circuit work is, from the "S" terminal of the ignition switch, the circuit runs to the PTO switch, if it's in the OFF position, the circuit then runs to the pedal switch, if it's in the DOWN (or brake on) position it then runs to the solenoid. On other tractors, from the ignition switch, the circuit runs to the pedal switch first. (The seat switch isn't used in the cranking circuit).
Any switch can go bad, but I would more likely suspect the pedal switch or loose connection at either switch. (But it could actually be the PTO switch).
Try tracing the circuit from the "S" terminal of the ignition switch through the PTO or pedal switches to the starter solenoid. You may get lucky and find something obvious.
If you find nothing, try jumping across the pedal or the PTO switch (only two terminals are used in the cranking circuit, trace back to ignition switch for the incoming, outgoing is usually directly adjacent). Jumpering will take these out of the circuit and tell you if either is bad internally.
Lastly, there's always the possibility that the ignition switch is bad. (Doesn't happen all that often, but it's suspect as well). Jumper from "B" terminal to "S" terminal will take it out of the circuit.
Posted on Aug 22, 2012
91 geo metro won't turn over, lights come on, starter doesnt engage
Hi Teresa thats ththhe sign of a battery going bad, how old is the battery? You might want to have it load tested so you can trouble shoot further, there could be more than 1 issue.
Dec 19, 2015 | 1991 Geo Metro
I have 1995 chevy s 10 won' start. I like to try hot wire.crank but will not me??
Won't start how ? no crank - no start , which means when you turn the key to the start position nothing happens , starter doesn't engage. Or the starter turns the engine an it doesn't start an run. a crank - no start ?
Nov 20, 2015 | Chevrolet S 10 Cars & Trucks
No start, no crank
If the starter won't engage, you can't crank the engine. You would only hear the starter operating freely. The replacement starter may have to be shimmed to fully engage the ring gear. Also, did you verify that the ring gear is OK?
Nov 21, 2013 | 2004 Ford F150
1995 Taurus. Starter will not disengage. Engine cranks, but will not turn over.
Find the starter relay under the hood. It may be bad and stuck so power continues going to the starter. Try a new relay Or try pulling off the small signal wire on the relay (it is from the switch), and hook battery up. If starter continues to run, the relay is bad. If starter is stopped, put the signal wire back on relay. If starter now starts operating, and key is still off, then switch may be bad .Location of relay may be at left front fender apron, in front of shock tower (like on earlier taurus models).
May 27, 2012 | 1995 Ford Taurus
Hi, have a toyota avalon, tried starting the car , it won't start, but then the starter engaged and won't turn off evenwithout the key, disconnected the battery and it stopped , when the batte
It sounds like you have a bad actuator. This is attached to the starter and has a solonoid that pushes the starter motor gears into the engine gear. If the solonoid is faulty this may happen. Also check alignment of the same.
Mar 18, 2012 | 1999 Toyota Avalon
1991 Subaru Loyale Wagon. Fuel injected. Whern car gets warm from running, or sitting in sun and cabin temps get above 70F or more, car cranks but won't start. Been 3 years or more of this. Replaced...
did you check out the battery cables,some times they can get corrosion inside where it cant be seen and cause a short, and lack of output and sonetimes will mess with the charging happend on my 87.
May 12, 2011 | 1991 Subaru Loyale
1988model starter does not engage more often than it does engage
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} What is the difference in the sound when it engages and when it does not?
What does engage mean to you.
To me it means a loud click sound followed by the engine cranking.
Actually engage is just the click sound.
Cranking is the small electric starting motor forcing the engine to move as if it were actually running. Once it moves just a bit a spark plugs fire and the resulting explosions makes the engine keep going until one of the following happens.
Loss of air/fuel mixture (i.e. run out of gas or air intake blocked)
Loss of spark (i.e. battery low or dead, bad coil, bad plugs)
The two above do not come together at correct time (timing)
Something physically stops the engine from continuing to operate (engine seizes, too much load)
If battery is low starter will not engage or crank.
If electrical connections are bad (usually loose or dirty) current will not flow properly and starter will not engage or crank.
Both can be checked with a multi meter.
Measure battery voltage when attempting to start.
It should be 12-13.2 volts and should not drop below around 10 volts
If it is not dropping but still not engaging/cranking, continue to take voltage readings move from battery toward the starter. When you find a sudden voltage drop, investigate wiring just before that point upstream toward the battery.
Nov 14, 2009 | Harley Davidson FLSTC Heritage Softail...
Cranks fine, won't "catch"
From what u describe, I believe u have a starter and possibly a flywheel problem. When u turn the key to start the car, the starter gear engages w/ the flywheel, turning the flywheel, which turns the engine over. It sounds like the teeth of the flywheel and starter are worn, (they should mesh together smoothly) which would make the grinding noise u describe. If this is the case, the flywheel and starter would need to be replaced, and its a labor intensive job, as engine and trans. have to be separated to remove/install the flywheel. The rrrrrrr sound could be the starter gear spinning but not engaging. The starter gear extends on a shaft, then engages the flywheel. It is possible the gear isn't moving forward on the shaft, just spinning w/out engaging, making the rrr sound. So, I would recommend u remove the starter and have it tested (many parts stores will do this for free) and check the teeth on the gear to see if they are worn or broken. U will also be able to see a portion of the flywheel after the starter is removed, and u should check the teeth on it also. Let me know what u find, hopefully it's just a starter problem, and the flywheel is ok.
Dec 30, 2008 | 1991 Buick Skylark
95 F150 wont crank
the starter should be replaced. The solenoid is kikcing the pinion out but there is no contact being made to turn the starter motor. I have the exact same truck and before i changed the starter used the old starter tap trick. Tap the starter casing with a hammer and it should start turning again. hope this was helpful for you. Good luck.
Sep 16, 2008 | 1995 Ford F150 Styleside Regular Cab
Garden Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
