Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Put new fuel lines to carb, cleaned carb. and reassembled. Now will start but runs only on half choke at high throttle. Engine will die out if taken off choke or will kill if I press throttle trigger. Any idea what could be the problem...thanks
  • 784 Answers
Check gasket between carburator and cilinder, if ok set newly idle settings on carburator. if its ok but not helping. Maybe cranksaft sealing faulty.
Posted on Mar 19, 2011
MC Dies upon ANY throttle application. HELP!
Odds are that if it sat for a year with fuel in it, the carb may be gummed up. Opening the throttle will cause an immediate engine stop if it is not getting fuel.
I'd recommend a "clean out the carb" project, including using air to blow out allof the small orifices.
Jun 29, 2015 | 1996 Honda VT 600 C Shadow
Ryobi 9600 backpack blower. Starts great. Set to run, continues running. Upon attempt to use throttle, engine dies. Acts like choking out but removed carb cover an choke is no closing.
this sounds strangely like the high speed jet/pathway in the carb is clogged up with something ,
the best way to fix it is dissasmbly and cleaning of carb in solvent , but ive also had some limited sucess in past of using car fuel cleaner (says on bottle "cleans as you drive") too
Mar 09, 2015 | Ryobi Garden
My Weed Eater FL1500LE gas leaf blower will not run beyond the full choke setting. If I move the lever to half choke the engine will stop. Or if I move the throttle from full throttle to a lower speed...
This is a tell tale sign of a lean fuel mixture. By choking the unit you are manually creating a richer fuel mixture. I would purchase a compression tester from a local parts store and check compression. If that's ok, I'm willing to bet the problem is still carb related. Two stroke carbs are tricky to clean because of high/low ports that are one way and sometimes impossible to clean. Did you remove high and low needles when cleaning carb? Another trick is to mix seafoam with your gas, then mix two cycle oil to proper ratio. Use 2 ounces seafoam to one gallon of gas, then mix two cycle oil to proper mix. Hope this helps! Good luck and happy wrenching!
Sep 22, 2013 | Weed Eater Fl1500 Le Leaf Blowers
I have a 96 yamaha virago xv250. It cranks, and idles fine. The problem is, once you start riding and get into first, you get about halfway down on the throttle and it's like the engine is dying out,...
It sounds to me like your main jet or high speed circuits could be plugged up in the carb(s) or you could have water in the fuel. If you are reasonably mechanically inclined, I would suggest removing the carbs and giving them a good cleaning. You might want to give it a fresh set of plugs and a new air and fuel filter while you are at it.
Sep 12, 2011 | Yamaha Vino Motorcycles
Stihl FS81(older style) brushcutter.New Carby dies under throttle
The problems you are having sounds very much like a blocked exhaust port/silencer. On these small two stroke machines it is normally the cause of lack of power or not revving. Happy gardening !!
Stantheman 19/09/2010
Mar 13, 2010 | Oregon Scientific Complete Carburetor for...
Starts full choke dies out runs for a few min at half choke dies out at no choke. noticed tank is full of air bubbles when running
First, you will need to check the fuel lines for cracks/breaks.
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen in the carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
(NOTE: If the carburetor parts are more than four years old, and depending on the use, you will need a new carb. kit if the cleaning doesn't work.)
If you need further assistance, just let me know.
Jim
Jun 17, 2009 | Poulan Pe550 Gas Edger
Starts on choke but dies when moved off choke
If it will start on choke and die when choke is taken off...the carb needs to be taken off and cleaned. The main jet in the carb is probably clogged.
Apr 09, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Engine run @ half choke but will not run in run position
It's starving for fuel. What is it? Sounds like the jets are plugged in the carb. or possibly water in the gas. Remove carb., disassemble, clean and put back together. You should get a rebuild kit for it first so you have new gaskets, etc. when you reassemble. It's a little more complex than I can put in words for you here.
Also empty and clean fuel tank too and start with fresh, clean fuel.
Mar 11, 2009 | Homelite Mighty Lite Lawn Trimmer
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
558 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
