I have a Magnavox Plasma 50mf231d/37 that shows no picture or has no sound when it is turned on. I have already replaced two capacitors to prevent the red blinking light, but when I did that I found that the bottom half of my screen was distorted. I was told it was the lower y buffer board so I ordered a new one offline and now when I power it up I am without a picture and sound.
  • 3 Answers
SOURCE: 50mf231d/37 magnavox plasma
i have the same problem but i play with it by pluging it in multiple times and i hear it click on then off eventually the time between it clicks on then off is longer until i finally get it to stay on .I have to do that everytime i use it . Also the update wont work for me either tried everything. It must be with the power supply becuse once i get it on it stays on, and if i turn it off after its been working for a while it comes right back on perfectly. Only when i leave it off for a few minutes the symptoms start right over.This is what i do for about 5 minutes of plugging it in and out it flicks on and then off about 2 seconds later after that ii finally get it to flck on then off about 6 seconds later. 5 more minutes of pluging it in and out it takes about 10 seconds to flick off this is when i know it is about to work.finnally the green light will stay on and the tv wont flick off you can turn it on and of with the button wait 2 min to see if the picturecomes on repeat last step until it works.This means everything works great exept for the power supply for enitial startup. I beleive its a capacitor . I will check and report back.
Posted on Nov 24, 2008
SOURCE: Red blinking light on a Magnavox Plasma TV
Here is the solution. For less that 100$ your Magnavox Plasma TV. Model # 50MF2310/37 will be running like a champ.
Issue:
Magnavox Plasma TV. Model # 50MF2310/37 screen has no picture. There is no sound, TV comes on and then after a few seconds clicks and screen remains blank.
Cause:
On the main power circuit board to Capacitors are prone to failure from over load. The caps are 3300uf 10v 105+c capacitors located to the left of the AC power input.
Service:
Magnavox will refer you to a service center. They will advise $$$ for an inspection. They will also want to charge upwards of 500$ to replace the entire board.
Solution:
1. Unplug your TV
2. Disconnect all connections from your TV
3. With assistance lay your TV on its face on a non-scratching service
4. Remove the back panel screws.
5. Lift back panel off
6. The central board is your main power board.
7. Remove all wire harnesses from the main board.
8. Remove all screws that are holding the main board in place.
9. Lift the main board out and carefully place it into a non electromagnetic pouch.
10. Take the board to a Circuit Board repair shop.
11. Have them replace the the above mentioned Caps.
12. Re-install the board in your TV.
NOTE: Replace the caps with 3300uf 16v 105+ high temp caps(preferrably Japanese caps)
This fix cost me 80$ and my time to search for other who had the same issue. Try searching for Magnavox Plasma TV. Model # 50MF2310/37 bad circuit board or Magnavox Plasma TV bad capacitors or Magnavox Plasma TV bad ciruit board.
Hope this all help, Magnavox is should take ownership for this problem and recall any tv's that have these caps in them. The worst part about this is that teh **** from the repair center that was paid 100$ to check the TV, stripped out the screw holes and damaged the case for the TV.
Portland Laptop Repair was awesome. They repaired the board and it looked like new. Check them out at http://www.laptopportland.com/
Jeff G
Portland, OR
Posted on Apr 28, 2009
CAYPIANAN
  • 227 Answers
SOURCE: I had two capacitors in my 50mf231d/37 50 inch plasma tv go out.
your problem is in the Y or Z sustain boards i just fixed one of this today with the same exact problem and i replaced  the Y sustain BINGO.
good luck
caypianan@yahoo.com
Posted on May 12, 2009
CAYPIANAN
  • 227 Answers
SOURCE: Philips 42PF7320A/37 blinking red light
hello, amigo if the all the caps are godd then you have to replace the power supply board. don't try to fix it this is not an easy task. you are looking at almost $200.00 with tax an shipping. just go to google and type your tv model # and ask for the power supply board or just look for the part# on the board itself. good luck
Posted on Jul 29, 2009
dave1645
  • 834 Answers
SOURCE: i have a Magnavox 50MF231D/37 plasma tv that won't
you have some bad caps on the power supply board these can like devices will have a puffed up top where it vented the value is written on the side of the part
Posted on Nov 24, 2009
Does the Blinking Light on the Asic Main logic board mean bad Logic Board?
Check all the capacitors one might be bad find out if it is bad it should bulge on top of the capacitors
Nov 04, 2017 | Magnavox Televison & Video
We have a Magnavox, 50 inch plasma TV, model 50MF231D/37. Recently when the TV is powered off and an attempt to power it back on again has been made, we get a red blinking light. The light blinks six...
Your problem is caused by a power supply issue it sounds like a capacitor is leaking or has vented and will need to be replaced if your comfortable you could check the power board for a can shaped electroletic cap that has vented it will be puffed up on the top the value is printed on the side you can or have someone replace it that should take care of your problem the power board is the one where the AC cord plugs to or leads to
Dec 10, 2009 | Televison & Video
good luck
caypianan@yahoo.com
May 12, 2009 | Samsung HP-S5073 50 in. Plasma HDTV
50" Magnavox Plasma TV will not turn on - Red LED blinking 4x
When you have the red light that blinks four times on the 50" Magnavox Plasma Model 50MF231D/37, you should look for the capacitors on the power board in the center of the of the TV. Look for two 3300uf, 10V, 105c capacitors that have a build up of pressure that has caused the top of the capacitor to look rounded instead of the flat top that will be on all of the other capacitors. Changing these two capacitors fixed the problem of the TV not coming on.
I had more trouble finding the capacitors than changing them. I could not find them locally so I went to an on-line electronics supply store where they were $1.65 each and $8.99 to ship.
Jan 03, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Magnavox 50MF231D/37 Plasma tv
The plasma panel in most cases exceeds the cost of replacing the TV. There is also the issue that they tend to use different versions and makes of panels in these sets. Some panels are made by Samsung and some are made by LG. I would start shopping for a replacement TV at this point.
Feb 18, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Issue:
Cause:
Service:
Solution:
1. Unplug your TV
Jeff G
Portland, OR
Feb 10, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Magnavox Plasma HDTV Red light
I had a similar problem with my magnavox tv with the blinking light issue. Eventually it just didn't come one anymore. Looking at other forms they said the problem was a bad capacitor number 2074 located on the power supply board. When I opened my tv, I noticed that the capacitor was bulging and burnt up. I bought a new one labeled 2200uf 35v and did some solder to attach the new piece. Put the tv back together and it works like new. No more blinking light. I hope this helps.
Feb 02, 2008 | Philips Magnavox 51MP392H Rear Projection...
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
