Question about Sears Vacuum Shredder Bagger Replacement Bag.806008
I need a bag fro a Craftsman Eager 1,chipper / sherdder
Need replacement bag for sears chipper vac model 9877799601
Call Fred at 651-786-4277 I have used bags and some new bags. I also refurbish chipper vac bags
Oct 22, 2014 | Sears Vacuum Shredder Bagger Replacement...
Can't seem to get my mower to keep running
the problem is probably the carb---take it apart and soak the parts in some solvent. make sure the float valve moves very freely.
May 06, 2010 | Craftsman Push Rear Bag Lawn Mower w High...
Starting craftsman 6.5 hp 4 in 1 leaf vacuum
Check to see that bag is attached correctly as it has a kill switch.
Oct 11, 2009 | Sears Vacuum Shredder Bagger Replacement...
Need a leaf bag for a chipper/shredder/vac
That is actually a good price. MTD wants $225.00
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Oct 04, 2009 | Craftsman 4 Cycle Blower/Vac
Looking for a manual on a Craftsman Eager-1 lawn mower. Model #131.90300. Sears has discontinued the manual
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=131.90300&productCategoryId=1503700&brandId=0247&modelName=ROTARY-LAWN-MOWER&diagramPageId=00001&documentId=00035640&pop=flush
PARTS LIST AND PICTURE.. WHAT DO YOU NEED TO KNOW OR DO??
Aug 11, 2009 | Craftsman Garden
Need 3.5 HP Craftsman vacuum-shredder-bagger-blower manual
Without seeing it I don't know but it should show you in the manual. You can order it from Sears.
They have a great online parts site.
Here is the link
SearsPartsDirect.com
Mar 22, 2009 | Sears Heavy Machinery
Looking for a leaf bag replacement for a 4.5 HP craftsman yard vac model no. 247.770100
Sears has a great online site which you can get parts for almost any make and model equipment.
Here is the link
Mar 21, 2009 | Sears Heavy Machinery
5 HP troy bilt chipper sherdder will not rev up under load
Either or do one of two things if the motor runs pretty well Start the engine and run it full throttle. Once there if it has a high speed jet turn the screw in to start with until the engine stumbles a bit and then turn it back about a half turn. When you turn it in you should here the engine peak out. .If it is blowing black smoke out the exhaust it means the high speed screw is to far out so turn it in until it smooths out.If the engine smooths out then you have cured the problem. Good luck.
Mar 18, 2009 | Troy Bilt 24b - 060f766 5hp Chipper...
#1 I don't know the proper adjustments for the carborator will not run at all unless the choke is partially closed - tried cleaning the carb. Now it won't run at all. my 5HP troy bilt chipper sherdder...
I hate to give you any bad news but if the unit will run with the choke half closed you are looking at another carb cleaning or a new carb depending on the age of the unit. If you are into cleaning carbs very often buy yourself a set ot welders tip cleaners. these are really necessary in a good carb cleaning. I hope some of this will help. donnyb60
Mar 18, 2009 | Heavy Machinery
Sears Vacuum Shredder Bagger Replacement Bag.806008 Logo
454 people viewed this question
Top Sears Heavy Machinery Experts
lnbn1975
Matt Olenzek
Matt Olenzek
Are you a Sears Heavy Machinery Expert? Answer questions, earn points and help others
