Question about Health & Beauty
While taking the head apart to clean it I accidently pulled everything apart. Now I can't seem to figure out where the spring goes. Can you tell me where it should be
  • Health & Beauty Master
  • 1,626 Answers
What is the make and model number???
Posted on Mar 21, 2011
Brushes won't spin anymore
There is a spring that goes on an arm, #32 in the picture. It actuates the turbine so the brushes will turn when the handle is tilted back, and stopped when upright. This might be where that spring goes. You may have to take the top cover off to put in on. After you get it on, and the brushes still don't turn, look up in the square hole where the shaft on the brush block goes into, turn the unit on and see if it is turning, if not then the turbine either needs to be taken apart and cleaned or replaced. The turbine is what drives the brushes.
Mar 14, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
I took apart my Eureka 71B hand held vacuum and a small spring fell out. I don't know where it goes and can't find a manual anywhere. Help?
Lonny,
I have a 71-B2 model myself and if you can take a picture of the spring, I can try to take mine apart and see if I can figure out where your spring goes and get back with you.
Aug 09, 2015 | Eureka 71B Easy Clean Hand Vacuum Yellow
Delta shopmaster manual
if you want to remove the whole assembly take off the spring and tap out the lowering shaft. once that is done your spindle assembly will drop down,, with a little help.
Oct 07, 2013 | Drills
Cant figure out what is wrong
Take apart the carb and clean it with carb cleaner. Be careful when you pull off the bowl some of them have springs that are tricky to put back in. Drain all the fuel that was in the tank. Check the plug and make sure it's still good if it hasn't run in 5 years then it's probably still good a visual inspection should tell. After the carb is clean put it back together and it should start right up.
May 01, 2013 | Garden
The pull cord froze up. I tried to take it apart and rewind the coil spring but can't figure out how it attaches back to the pull cord housing to retract the pull cord. Any help with pictures would be...
I'm afraid you put yourself in a corner. You need to take your chain saw to a repair facility. Make sure to gather all the parts to go with. I know how to install a coil spring, but it's something you have to be shown in person how to do it. It can be pretty tricky.
You could be hurt by the spring uncoiling by accident.
Incidentally, I doubt if the coil was the original problem.
Why do you think that is the problem?
Jim Hart
Jun 20, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I accidently pulled out a piece of white strip with tow blue ends. Now my printer wont turn on....I took it apart but don't know where this white strip goes...
Sounds like the encoder strip. There's a hook on one side, itgoes through a slot in the printhead, near the top in the back, and a spring to hook it on the other side. Hard to put back without taking the covers off.
Jul 03, 2009 | HP Officejet 5510xi Printer
Large rubber door seal came apart
Yes it can be put back on without taking the drum apart. The larger end goes on the drum side. Fit larger end around drum lip make sure it seals all the way around, install spring around seal. Smaller end goes around door opening. Install seal around outter lip and install spring around seal.
Mar 05, 2009 | Kenmore 44102 Front Load Washer
Put back togather
Well I did it. It's not exactly easy to describe. I accidently took mine apart trying to clean the roller ball and out popped the 2 springs. I sort of put it back together in "reverse". In other words, I put it together without the scroll device and then looked through the hole. By doing this, I figured it out -- when you know it's simple but to describe it without pictures is almost impossible. Mine works fine now but I don't know how to help you.
Jan 13, 2008 | Logitech Cordless TrackMan Optical...
Health & Beauty Logo
27 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
