Question about Roper RS22AQXKQ Side by Side Refrigerator
I have a Roper Ice machine that i just replaced the water valve. The door when opened spins the tray and raises the arm rotating the tray inside fully with no ice being made. I hope that you do not charge for you're services.
    Guru:
  • 262 Answers
Here is a link for your ice makers part drawings.
Click on the link http://www.searspartsdirect.com/partsdirect/part-model/Roper-Parts/Refrigerator-Parts/Model-RS22AQXKQ03/0893/0165000/W0209025/00012?blt=06&prst=&shdMod=
Now watch the entire video on how a ice maker works and how to test the components
click on the link http://www.youtube.com/watch?v=VCUgA5T5ASw
how to check the water valve
click on the link http://www.youtube.com/watch?v=0PRQWoxTtLg
How to start a manual harvest
click on the link http://www.youtube.com/watch?v=Cx756O2ryWk
If you have checked the ohms on the water valve from the first video and it tested good.....then run the manual harvest in the third video. Watch the the scrapper arms in the ice maker index.....if they reach the 10:00 o'clock position and water will not enter the ice maker and the water valve tested good then you will need to replace the ice maker control module.
Ensure you test the components in video one and run a manual harvest.
Ensure the plastic tube that supplies water to the ice maker is not frozen up.
Please post results.
Keith
Posted on Mar 19, 2011
Freezer wont make ice cubes
This is not difficult to troubleshoot.
  • When the arm is up the ice maker is off
  • When the bucket is full the arm is up the maker is off.
  • If the ice maker has a on/off button in off the ice maker is off
  • If the ice maker internal heater fails the cubes will not release and the white plastic ejector arms will be rotated CCW and pressing against the ice in the tray, Normal position for ejector arms is vertical.
  • If water solenoid has failed or water supply not available the ice maker will cycle. The ice tray will be empty,(hard to see if ice tray is empty). Check and replace water fill solenoid.
  • If ice in tray and ejector arms vertical several possibilities.
    • Freezer not cold enough to trip thermostat in ice maker to initiate release cycle.
    • Check freezer temperature <10 Fahrenheit thermostat in ice maker failure
    • Ice maker motor failure,
    • Internal ice maker electrical connections rotary switch failure,
    The best way to check the operation is to manually lock the arm up into the off retention position. Wait a minimum of one hour. Open door and release arm down. Observe the operation of the ice maker. Is after a minute or so the ejector arm does not rotate then it is likely the ice maker has failed internally. If the ejector turns and no ice than you can assume either the water supply is off external from the refrigerator or more likely the water solenoid located behind the bottom back cover has failed. It is also possible that the hose that connects the solenoid to the ice maker has frozen right where it enters the freezer just above the ice maker. You should see ice built up at the entrance where the water fills the tray if this has occurred.
Ice Maker Repair
Dec 22, 2015 | GE Monogram Side by Side Refrigerator
Ice maker not getting water on new refrigerator
Check if the unit has a cold water dispenser that it will fill a cup. If so than problem is with Ice Maker. If not than problem is with water supply to unit.
If water to machine works make sure that the arm on the ice maker is in the down position. If it is up it will disable the ice making unit. Cycle the am a few times to insure that the switch connected to the arm has not gotten stuck in the off position.
On some ice makers there is a separate switch to disable the Ice maker usually right on the ice-maker not easily missed.
It is possible that the water feed tube into the Ice Maker has become frozen where it enters into the back of the freezer at the top. You can look through to see where the water fills into the cube tray. If ice is present it would be an indication that the feed tube has become frozen If suspected the safest way to fix would be to turn off the unit and allow for a manual defrost.
Next check the operation of the ice maker. Locate the arm in the up position prohibiting the ice maker from cycling. Wait three hours or more. Open freezer door and return the arm into the down position. After a few minutes you should observe the ice fingers rotating to release the cubes into the tray. If the fingers do not rotate I would suspect the ice maker or the connecting electrical circuit. Remember after dropping the arm the Ice Maker has to warm up to melt the ice cubes from the tray before the fingers are told to rotate,
If the fingers rotate then I would expect that the water supply solenoid has failed inside of the unit near to the location the the water supply is made. Replacing this part needs to be done by a qualified experienced technician.
Nov 15, 2015 | Refrigerators
Water is going into the ice tray but once it freezes the cubes dont come out when the assembly rotates. When it cycles again to get more water the water spills into the dispenser & eventually the tray
can b one or two things wrong here
(1) how sure are u that water is not just continuously flowing into tray (at low rate) ??? reason I ask is a leaky solenoid valve is a very common failure on ice makers
(2) is arm that rotates thru ice tray ,not obstructed by anything ? ive seen Frozen pizza's hold a swing arm down and not allow it to raise to shield the ice tray in a dumping cycle (im speaking of "hold" arm ! thin steel arm that raises up in a ice dump cycle )
(3) of course could be a defective ice maker as well ? theres lots of motors and gears and switches inside there that could malfunction and prevent it from working
Jun 29, 2015 | Refrigerators
Jenn-Air Side-by-side Refrigeration not making ice and leaks water underneath when ice maker arm is up
With the arm up in the ice tray, the water solenoid valve should be closed. When the arm drops, that tells the ice maker to open the water solenoid valve to fill the ice maker tray. It sound like the leak is at the inlet side of the water solenoid valve. On some models its not easy to get to, but follow the water line to it. Hope this is it for you. Good luck.
Dec 30, 2013 | Refrigerators
My roper washing machine will not empy out or spin. It agitates alright but stops when it comes to emptying the water and going into the spin cycle.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Replace the lid switch with this part.
Dec 27, 2010 | Roper RAS8445KQ Top Load Washer
My frigidaire stopped making ice
Inside the fzr on the side of the icemaker is a metal wire arm that needs to be down and not raised. (down on raised off) If you manually put water in the tray and the next day the ice is in the bottom your water valve may be bad it is located on the back bottom of fridge where the water line hooks up. Also make sure the motor in the back is not jammed if you have a door ice/water selection. If none of these replace the unit they are held on by two screws and a multiwire plug and they are not exspensive.
Jul 28, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Kenmore Coldspot Model 57577791 S/S Ice Maker Problem
Probably the solenoid (electric valve that opens when the ice maker calls for water ) is leaking and has to be replaced (it's a very common problem ) . To be sure the solenoid is the problem , turn off the ice maker by raising the arm up , and check after a few hours if is any water in the ice tray , if yes the solenoid is leaking , if not , the ice maker control board has a problem , and to replaced it will cost you almost as a new ice maker.
Oct 19, 2009 | Freezers
Jenn-Air bottom freezer ice maker not working
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Cynthia
Sep 07, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Metal ice maker arm is stuck midway. Will not produce ice
The small metal arm that raises as the ice fills in my GE side by side with water and ice in the door is stuck. Will go all the way up but only half way down. No other obvious issues. Have felt inside the little tray to be sure nothing was jammed or frozen.I need help !!
Jan 07, 2009 | GE Refrigerators
Whirlpool Refrigerator Model ED25PW Ice maker tray not filling with water
Just had this issue - after checking all line connections, I pulled the ice maker feed water line from the back of the unit and found the tube was blocked with ice. Melted the ice with some hot water, and all is good once more. I would check for this before getting into the solinoid.
Aug 27, 2008 | Refrigerators
Roper RS22AQXKQ Side by Side Refrigerator Logo
59 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
