Question about Yamaha 12V Air Pump
Have an FX140 jet ski. Attempted to start thia am. It attempted to start twice then no longer turned over. Thought is was the remote lock-out attempted to unlock ..no good. Purchased a new battery for the remote loc/lock out still no good.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 118 Answers
Sounds like you have either a dead battery in the ski or a loose batt cable that has arc'd. Check both pos and neg cables at both ends and make sure bathas a good charge. if all good there you ccan rule out the security system by simply rapidly pushing the starter button as fast as you can for about 5 sec, if your lock is on you will get a small kick from the starter and may need to get your remote reprogramed. could also be your solenoid and real easy to check, follow pos batt cable to elec box, remove 4 phillips head screws and put a meter or test light on that side to verify power, then do the same on the other side while pushing start button, if its getting 10 or more volts its going to be your starter but highly unlikely. if no voltage its may be solenoid which 99 times out of 100 is the guilty part. or a bad start stop switch assy. you can jump solenoid to rule out starter with a pair of pliers on each post of the solenoid . but before u ddo all this check the fuses!
Posted on May 18, 2011
How do I repair the antitheft system after jump starting my 2003 Pontiac Montana?
try using a fault scanner to reset the CPU program in the ECM
Jan 26, 2015 | 2003 Pontiac Montana
Won't start
Fuses in the electrical box?
Jul 18, 2013 | Yamaha 2006 WaveRunner FX Base
1998 altima key fob won't lock doors and alarm doesn't work
More than likely the battery is dead or the remote has lost programming.
Jul 16, 2013 | Cars & Trucks
This morning when I attempted to start my 2006 Hummer H3, nothing happened. I thought I may have a dead battery but the lights and radio work fine. I then noticed the Passlock security lock light was on...
Hello:Try this procedure: turn key on, turn to start, let key come back to on wait ten minutes, turn key off wait 10 seconds turn key back on wait 10 minutes. turn key off wait 10 seconds turn key back on wait 10 minutes turn key off wait 10 seconds NOW try and start. In addition you might try tapping on switch assembly while trying to start. There is not any way to disable passlock. You might try having the engine control system codes read
Feb 01, 2011 | 2006 Hummer H3
I have a 2001 ultra 130 di jet ski and with two people on it that do not weigh much the jet ski will roll over at idle speed if you are not really carefull. Please help, it is a great jet ski for one...
Many hulls when turned sharply below planing speed will flip when riding two up. When wearing a neoprene suit you need to jump in periodically just to cool off. Make sure you have drained all the compartments in the hull of water every time you take the boat out of the water. I purchased a ski once that would not plane off and had a dry engine compartment. When I pulled the plug at the back several gallons of water came out. It made all the difference in the world losing all the ballast.
Oct 12, 2009 | kawasaki Full Suspension Mountain Bike Men
Jet ski wont start, no lights no nothing,, battery is new and been tested twice
Check your ground wire, and also check to see if you have a fuse/fusible link that went out.
Jul 14, 2009 | Encore Software Kawasaki Jet Ski...
Yamaha 12V Air Pump Logo
236 people viewed this question
Top Yamaha Water Sport Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Craig Butler
Craig Butler
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
