Question about Vacuums
I have an Easy Flow built in vacuum, model:EF 136 Delux. It is old, but works well. I have removed the filter bag and washed it, it is difficult to reinstal. Should I be buying new filters instead? Can you still buy hoses for this machine?
  • 3 Answers
SOURCE: vacuum shuts off
if you want to fix this problem gently pry up the air flow control knob and look down at the plastic hose connected below the control valve. insert a small screwdriver and push off the hose from the valve. this disconnects the bag full indicator but will let the vacuum operate normally at full vacuum. you will change the bag when suction gets low. this will save you at least $100 repair bill.
Posted on Feb 03, 2008
reddevil6
  • 1673 Answers
SOURCE: need help with my vacuum
You didn't state brand and model number. Some of these filters can be washed, make sure it is dry before putting it back on. If it is a year or more old, then replace it. Call around to your local repair shops to see they would have a replacement filter.
Posted on Mar 13, 2008
reddevil6
  • 1673 Answers
SOURCE: miele big blue
Could be a problem with the cord. There also is a circuit board by the motor that could be the problem. Did you drop something in the hose to see if it comes out the other end? Because you could have a clog. Or just unhook the hose and see if it runs that way.
Posted on Apr 28, 2008
SOURCE: HEPA Filter
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618630&thid=730623
HEPA Filter
Posted by jenski66 on Jul 02, 2008
My vacuum came with a sponge over the filter and the directions said I could wash the filter. Do the directions mean to wash the black sponge or the actual filter? Is the sponge part of the filter or is it trash?
Filter F27
Dirt Devil Purpose Cleaner for Pets
Upright Bagless Vacuum
Model #1LY2108-000
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Typically the top filter of which is the sponge is washable but the HEPA filter is not, it can be brushed off and vacuum off with another vacuum, but the best filtration is to replace the HEPA filter and to wash the sponge filter, if the sponge filter get to bad then replace the sponge filter as well. Or, you can check with your local vacuum cleaner dealer in your area or to contact the manufacturer’s website and or phone #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 02, 2008
GoVacuum1
  • 6 Answers
SOURCE: Bosch Vacuum Cleaner: I changed
Greetings from GoVacuum.com,
It sounds like you may have a bad thermal switch inside the machine. Most vacuum cleaners have a switch connected to the motor, so if the vacuum cleaner is running hot, it will shut off to prevent any damage to your motor. You did all the right things by checking the bag, making sure the hose was NOT clogged, and replacing HEPA filter.
Most of the time on canister vacuums, the reason is caused by a clog in the hose, or somewhere in the powerhead. If you're sure that there is no clog anywhere, it is going to be the thermal switch on the motor.
Here's a link to the parts schematic for the Bosch upright vacuum. I hope it helps you in determining how to access the thermal switch. A word of warning to you before you try it, this is a very tough vacuum cleaner to work on, you may want to bring it in to a vacuum repair shop, as this is not an easy repair.
Here's the link;
http://www.essco.net/Customer/SchematicFrame.asp?FileName=Turbo%20jet%20upright.pdf
Please let me know if you have any other questions,
Chris Jones
GoVacuum.com
1-866-468-2288
chris.jones@govacuum.com
Posted on Aug 18, 2008
How do I change twin filters?
Try washing them as a n assymbley. Let tham dry for a long time and see what happens. They can be changed but not usually needed.
Jan 23, 2016 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Tip
Fed up having to buy new filters for your vacuum?
Over the years I've lost count of how many companies stop selling replacement filters for their long deceased production vacuum models or that filter replacements are becoming increasingly difficult to source. There are usually universal "microfilter" replacements which are easy enough to find and cut to size, but if you can't be bothered to do that, there are ways around to renew your existing filter even if the manufacturer or the user manual states that the filter cannot be washed.
You see, any filter can actually be washed - if it is a single cloth filter - as opposed to a micro pleated section of many layers sewn together. If you have such a filter, a single cloth filter which the user manual says cannot be washed, this is a blatant lie. Remove the motor filter as normal (usually found at the bottom where the paper bag goes) if it is embedded with dirt and wash under a hot tap of water with either household washing up liquid or soap. Once the filter has been completely cleaned, place the filter into a pillow case and chuck into an electric dryer on a low heat. Instead of waiting 24 hours normally for a filter to dry to room temperature, you'll cut your waiting time by a day simply by allowing the gentle heat from the electric dryer to circulate around the pillow case which holds your vacuum cleaner filter. Once the filter is completely dry to the touch and does not feel damp in any way, install back into the vacuum cleaner.
I have also done this with HEPA paper filters which apparently are not washable according to the manual, and to stop the plastic cartridges from bouncing off the walls of your electric clothing dryer/tumble dryer put an extra towel or cloth into the pillow case to minimise damage. What is then revealed is a new, dry and clean filter which can be used again instead of spending lots of money trying to source a new one.
At the same time, if your vacuum cleaner has a soft bag, take it off and put it into the washing machine to give it a clean lease of life - but you won't need to put it into a pillow case to dry in the electric dryer - simply chuck the bag in to ensure it gets dried properly before putting it back onto your vacuum cleaner.
on Nov 16, 2007 | Sebo Automatic X1 Bagged Upright Vacuum
Check bag light on and bag fine. also seems like it is shooting stuff out of vent on top
Hi!, It's Jim with Crucial Vacuum,
Often times when your vacuums bag light remains on even after installing a new bag there is an air flow problem within your vacuum, or clog. This would explain why there is debris shooting out of your vacuums top vent.
Remove your vacuums bag and check to see if there are any clogs where the bag would attach normally. Clear out any noticeable debris.
While you're looking for clogs, check your vacuums hose, brush roll and filters. Stretch your vacuums hose out completely to unearth any debris. Manually spin your brush roll to help release any clogs, and wash your filters, but be sure to allow them to fully dry before re-installing them.
This should undo any clogs in your vacuum and cause your bag light to turn off.
You can purchase replacement parts for your Hoover vacuum direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=Hoover&order=relevance&dir=desc&limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
http://www.CrucialVacuum.com
Jan 14, 2015 | Hoover U6437-900 / U6439-900 Windtunnel...
Why is there no air blowing into the dust bag ?
You can purchase the replacement kenmore ef1 filters from Govacuum with an exclusive 11% discount coupon for Fixya.com readers, use code: FIXYA11. We also offer free shipping over $35.
https://www.govacuum.com/products/kenmore-ef-1-exhaust-hepa-filter-2-pack-similar-to-86889-40324-ef1-panasonic-part-mc-v199h-by-zvac
Jeethu
Govacuum Team
Sep 22, 2014 | Kenmore 31913 Progressive Direct Drive...
Why won't my hoover u6434 900 turn on?
Hello! The vacuum has a thermal protector sensor that will automatically shut off the vacuum when it is overheated. The vacuum should turn back on once it has cooled down. This can take up to an hour. Overheating is usually caused by a clog or a filter that needs to be cleaned or replaced. Below are steps you may follow to check your vacuum for blockages.
1. Locate the primary filter behind the side grille. Wash the filter, squeeze it out and allow 24 hours to air dry outside of the vacuum. It should be washed about every other month.
2. Locate the secondary filter located in the vacuum base under the paper bag. The secondary filter can be washed in the same manner as the primary filter.
3. Replace the bag if it is full.
4. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
5. Remove the bottom plate and brush-roll. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose.
Hope this helps!
Jun 14, 2014 | Hoover U6434-900 Bagged Upright Vacuum
Loss of suction o=with hose tool
Hose or tool is probably clogged. Is this an upright? Bagged or bagless? Have you changed the bag and filters? Cleaned out the brush and hose that goes from the brush area to the collection bag/cup? The only reason for a vacuum cleaner to lose suction but still work is a clog or dirty filter which blocks the air flow. Follow the air flow from the brushes to the bag/dirt cup. If the machine is bagged, change the bag. I use another vacuum cleaner to do this.While your at it, might as well change the belt.
Nov 15, 2011 | Hoover Vacuums
Kenmore canister vacuum will not turn on
No, the only effect of not cleaning them would be decreased air flow and consequently . The time between changing filters depends on how much the vacuum cleaner is used. Common failures are damaged cords and a damaged or failed power switch
Mar 29, 2010 | Kenmore 23513 Progressive Bagged Canister...
Electrolux Model 2100 vacuum won't work
hi from uk may i suggest you remove cover and the new dust collection bag then if you look in the bag compartment there is a gauze filter fitted usually grey in colour ? at opposite end of compartment where bag connects this gauze filter is the outlet from bag compartment that the air exhales when vac is operating ie as vac **** up dust into bag the bag has microscopic holes that allow sucked up air and dust to collect but keeps dust from passing into bag chamber but allows air to escape thro holes and so enter bag chamber then escapes via the gauze filter to outside of vac hope you follow this ?? now if this filter is blocked/never been cleaned/changed ? then the symptoms of indicator bag full light will come on you can remove and wash filter if it is gauze typ? dry and refit then try vacuuming ? or replace filter they are not expensive usually in pack of 3 in uk DO NOT RUN VAC WITHOUT THIS FILTER FITTED ! or you will have some dust in the room ? hope this helps?
Feb 27, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Hi, I have a canister Kenmore vacuum with power head. Everytime I use it, it smells sour. Its strong and like FEET with bad odor. My old Kenmore did the same thing but I used it anyway...because the power...
Never heard of this odor but if you have had it in both vacs it might have something to do with a disintegrating rubber backing on a carpet.
Arm and Hammer makes a baking soda based vac powder that will help eliminate some odors.
Do several things , get the powder and pour a tablespoon of it or baking soda into a fresh bag. Keep your filters fresh. If you use washable filters be certain they are thoroughly dry before reinstalling. And use a Mutli ply filter bag.. and NEVER pick up anything wet or vacuum a damp carpet
Sep 10, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Hoover U5468-900 WindTunnel Supreme suction is suddenly poor
The other possibility is there is a blockage in the foot. these models have dual channel air flow (windtunnel) and become blocked when not cleaned depending on use. under the roller there is a cavity that can be removed for cleaning. a hot motor can be caused by poor air flow.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Mar 15, 2009 | Hoover U5453-900 WindTunnel Supreme Bagged...
Vacuums Logo
127 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
