Question about Philips 190SW
My Philips 190SW was powered off for a week. When I powered it back up it fails to operate properly. It will show an image for about 1 second and then go black. Every time I power it off/on I get another 1 second image. What's wrong?
You have to take the moniter apart(the front popc off with clips and one philips screw in the back behind the stand..Remember where everything goes as you rip it apart and access the power supply..You will see a capacitor 1000uf 25 volts in the middle of the board.Chances if you look at it the top is puffed up and leaking..Pick up one for a buck or so and swap it out and you should be fine..I know this for I did it 20 mins ago and using it as I type this...Hope this helps
Posted on Oct 29, 2011
    Genius:
  • 1,189 Answers
Hi worse, when you 'say' "Power-off?
Do you mean:
The computer was "Unplugged, from the [Wall Outlet?].
The Battery was in the Computer?
The "Battery wasn't 'recharged' for a {Week?}.
You 'plugged the computer in, with the battery in the computer?
If any of the 'answer' are {Yes}?
Then more than likely:
The "Battery in the computer has a (0% charged).
With the "Battery in the computer, may be draining the 'resouces' of the "AC Adapter."
The "CMOS Battery" {Is "Dead" The information than it held to "Boot the computer is lost!"}.
The computer cannot "Boot into the Operating System!"
Take the "Lithium Battery" out of the computer.
"Unplug the computer from the "Wall power-outlet"
Press the Power Button for [15-30 seconds].
Plug the computer, back in to the 'wall'.
Do not place the {battery in the computer}.
"Restart the computer."
See: "What happens?
If this didn't fix the 'problem'; then everything (Above = "True").
Worse case "Senario."
Replace the {CMOS Battery}.
"You will have to "Reinstall the Operating System!"
"I hope the computer boot!
!"Take a moment to rate the help."
Thanks paul7of9
Posted on Mar 19, 2011
  • paul7of9
    paul7of9 Mar 19, 2011
    "Thanks for the "Rating" I give alot of "Solutions to people's problems.
    I just wish the ones that get the help "responded" as quick and as enthusiastic as you!"
    I hope you find an answer
LG LED TV has sound but no picture. Went out all of a sudden. Image shows with flashlight. Flashes for split second on power up and power down.
Your screens back light has most likely failed and or the voltage controller for the back light, both should be replaced.
Jan 08, 2017 | LG Televison & Video
RS267LBSH The refrigerator stopped working. The technician came and replaced the compressor. It works for 1 1/2 month and failed again. He came the second time and replaced the evaporator. A month
your getting ripped off try the defrost timer sounds like it is getting stuck, it operates on a 24 hour basis cycling between defrost, and turning compressor on and fan to cool the fridge
Sep 02, 2012 | Samsung Refrigerators
When the monitor is turned on the image shows for only 2 seconds and then the screen goes black. This is during boot up and also during operation. During operation, the monitor can be turned off and the...
You may have power supply or backlights inverter problem, or worst case will be the lamps.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 30, 2011 | HP Compaq WF1907 Monitor
Image blinks off after about 1 second after being powered up. Cut the power off at monitor, then turn back on and it repeats. Full image from computer shows up for about 1 second then disappears. The...
Please look here:
http://www.instructables.com/id/How-to-repair-a-Westinghouse-L1975NW-19quot-LCD-/
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Basic LCD monitor troubleshooting guide:
Oct 13, 2010 | Westinghouse L1975NW Monitor
Philips 170s LCD Backlight turns on only 1 sec and than the backlight off. The indicator lamps still green.... anyone can help me? thanks
Oct 08, 2010 | Philips 170S5FB 17" LCD Monitor
Monitor display shows for about 1 second then goes blank but the green light stays lit. If you turn it off and then on again it does the same thing.
Look for bas DC filter caps with leaking/bulging top/seals.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Aug 11, 2010 | Philips 170S7FS 17" LCD Monitor
Oven shows F2 fault several times a week. The oven is less than a year old and we keep it very clean.
F2 EO Shorted keypad/
key stuck
1. Disconnect power from oven for longer than 30 seconds.
2. Reapply power and observe for longer than 1 minute.
3. If failure remains, disconnect power, replace control, then go back to step 2.
F2 E1 Keytail unplugged 1. Verify that keypad is plugged into the connector on back of control.
2. Disconnect power from oven for longer than 30 seconds.
3. If failure remains, disconnect power, replace control, then go back to step 3.
Nov 19, 2009 | Whirlpool Ovens
Sansa e200 load main image failed
If this happened after updating your firmware, the Sansa FAQ from here http://www.sansa.com/support/sansa_e200/faqs says try this -
03. "Load image failed" appears after updating e200 firmware Applies to the following Operating Systems:
  1. Windows XP, Vista
This error may be caused by the firmware failing to load or the file system is corrupted.
STEP 1 – Reset the player
  1. Press and hold the Power button for approximately 30 seconds.
  2. Turn the player back on.
If the error persists, proceed to steps 2 and 3.
STEP 2 – Connect the player in Recovery Mode
  1. Turn off the player.
  2. Slide the Hold/Lock switch on top of the player so an orange color is showing.
  3. Press and hold the REC button and connect the device to the computer.
  4. A message will appear on the device display screen confirming the connection and a 16MB partition will be viewable in My Computer.
  5. Release the REC button.
STEP 3 – Download and update the firmware
  1. Download the firmware from the Sansa Forum.
  2. Open the zip file
  3. Extract all the firmware files to the 16MB-FORMAT drive.
  4. Disconnect the player.
  5. Slide the Hold switch to the unlock position.
  6. Turn on the player
Dec 29, 2008 | SanDisk Sansa e200 MP3 Player
Computers & Internet Logo
702 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
