Question about Stoves Kitchen Ranges
Our Wedgewood stove suddenly started acting up. We have to use the Reset button often to get any oven lighting at all. The pilots are fine. The broiler (separate compartment) is fine. But the oven lights up only to a low level, not a higher flame the higher you set the temperature. Your ideas?
It sounds like the problem is either the safety valve (the reset button) or the oven thermostat (the assembly behind the oven temperature knob). Both parts can be rebuilt (if they are original parts) and replacement parts are still made for 1940's and 50's Wedgewoods.
Posted on Mar 21, 2011
Old wedgewood oven in home...very low pilot light in oven...how do I adjust it?
The oven pilot is usually located at the back of the oven; turn a screw on the pilot ignition unit to adjust the pilot flame height.
here is a link, pretty much all older ranges operate the same.
Gas Oven Pilot Lights Shutoff Valves and Ignition Systems HowStuffWorks
Feb 05, 2015 | Kitchen Ranges
Can't light oven in Wedgewood caravan oven
Do you have manual for proper lighting procedure? Do top burners have good flame?
Feb 27, 2013 | Atwood Mobile Products Atwood Wedgewood...
1950 Wedgewood stove safety valve instruction
maybe this might help you?
http://answers.yahoo.com/question/index?qid=20061130165913AAMHKsW
Oct 24, 2008 | Kitchen Ranges
Pilot light
When you smell gas...is it all the time? If so, this is dangerous. If it only happens when you're trying to start the oven, no problem. Push the red button and hold it while lighting the pilot. Hold for 30 REAL seconds more. Release. The pilot should stay lit. If not, get a service tech.
Jun 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Gaffers and Sattler vintage stove oven pilot 1956 W54 series similar problem
My mother had the same problem with her Gaffers-Sattler range. No one could figure out what was wrong with it. Her local new appliance repair people said to contact J.E.S. Enterprises, Inc at www.theoldapplianceclub.net. Whew; thank God for that tip. They knew exactly what the problem was and repaired the unit for her. The stove is running again like a workhorse! Here is their number - 805-643-3532.
Bob Allen
May 07, 2008 | Garland H283 Gas Kitchen Range
Oven pilot light won't light
Part of the problem was my own ignorance about this particular Kenmore gas oven. It doesn't even have a pilot light. Instead, there is an electric heating element close to the burner which gets so hot that it ignites the gas. It seems that the heating element also doubles as a temperature sensor, so that it opens the gas valve only when the heating element is hot enough to ignite the gas. This heating element, called the "ignitor", no longer gets hot in my oven even though there is 120VAC applied to it when the oven knob is turned on. Therefore, the ignitor is defective. I ordered a new one on-line from "Appliance Parts of America" for $31.50 plus shipping, and this should fix the problem. If it does NOT, I'll add to this post.
Apr 21, 2008 | Kitchen Ranges
you must push and hold the button on the bottom fo the safety valve until the thermocouple is warm enough to keep the safety valve open. @ 25 - 30 seconds
Dec 13, 2007 | Garland H283 Gas Kitchen Range
Lighting a pilot light in a 30 year old roper gas range
Lift the top lid and look for a cylinder or something similar with tubing going into it there should be a button of some sort on the side. if you are lucky the button will have a red cap on it. press the button in and light the pilot inside the oven. hold the button for a minute or so until the pilot stays on. kind of like lighting a water heater.
Oct 31, 2007 | Ovens
Kitchen Ranges Logo
522 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
