Question about Archos 104 MP3 Player
Screen lights but is blank will not respond to any keys
My lenovo idea pad G405 is not responding when I turn it on
You need to be a bit more specific, is it a blank screen?, no lights at all?, not responding to keyboard or mouse? Each has different answers. Check your power supply first and that lights come on when you power on.
Sep 14, 2014 | Computers & Internet
Ti-83 won't turn on
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If the screen remains blank then please respond to this post and we'll go from there.
Jan 28, 2014 | Texas Instruments TI-83 Plus Calculator
Red light flashes blank screen
I have the same problem on 2 of my IP's - did you manage to sort it out?
Mar 27, 2013 | Saitek Pro Flight Instrument Panel...
Phone switches on but screen is blank
blank screen
if the phone can make out going call or receive call
maybe the problem come from lcd or the flex cable/ribbon inside the phone.it may come from upper board too.
if the phone blank screen and not responding any key pressed. it may come from the software.
note : broken upper board can make fault on software.cause the phone will detected as K700 on third party tool like setool, after replace the upper board it will detected back as w850.
Sep 23, 2009 | Sony Ericsson W850i Cellular Phone
IBM T30 screen ramdomly goes blank and computer freezes.
Reset your bios settings to "Bios defaults", then disable power management.
In Windows, go to device manager and try to detect new hardware. Follows screen instructions.
Mar 27, 2009 | IBM ThinkPad T30 2366 Notebook
Blank screen laptop
Your SONY should respond to the following:
Look for the blue FN key, hold it down (use it like a shift key)
While holding it, look for a key, also printed in blue with a picture that is half sun/half moon. On my laptop is the F8 key. As you press the key watch the screen to see if gets lighter.
Good Luck!
About Me:
Carl DeAlto
DeAlto Computer Solutions
http://www.dealtocomputer.com
Jan 17, 2009 | Sony VAIO K45 Notebook
My toshiba m35x-s111 laptop screen goes blank
According to the description of the fault and the symptoms that your equipment presents, you must replace the FL inverter, that is the one that gives the turn on of the screen of your equipment, if your you replace this piece that one finds behind of the mask of the screen in the low part and that is similar to a pen I assure you that your equipment it was working in perfect conditions
Dec 23, 2008 | Toshiba Satellite M35X-S111 Notebook
Toshiba TE2100 blank laptop screen
You have a either a bad inverter (which lights the screen's tube) or a broken tube. that'd be my guess.
Try this: shine a bright light on the screen from the side - if the light is hot be sure not to be too close or the screen will melt - and see if there's any image on the screen. There should be...
May 30, 2008 | Toshiba Tecra 8100 Notebook
Archos 104 MP3 Player Logo
22 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
