Question about Skagen Watches
SALVE VIVO IN ITALIA CITTA BARI. HO UN OROLOGIO SKAGEN SWISS SLIMLINE 583XLSLC.MI SI E' ROTTO IL VETRO.COME FACCIO A TROVARLO? E' POSSIBILE FARLO ARRIVARE PROPIO DALL' AZIENDA. MI DATE UN AIUTO UN CORDIALE SALUTO.
Torgoen - T27105 n'est marche pas,je vient juste de l'acheter mais il marche pas
Lis les instructions de mise en marche de la montre. Lis aussi la section en cas de probl`eme. Si elle refuse de se mettre en marche, retourne au magasin et demande un remboursement. La prochaine fois que tu veux acheter une montre demande au marchand de v'erifier le bon 'etat de marche.
Jan 28, 2014 | Torgoen T27105 T27 Pilot Watch
How do i adjust the band on the slimline mesh skagen watch
Step 1. On the reverse of the strap you should see a succession of ridges. You will also notice a corresponding ridge on the clasp. Sounds obvious, but once you have decided where the clasp should reside on the strap, you need to align these two ridges.
The reverse of the strap
Step 2. Get a piece of string or ribbon and wrap it around your wrist. Snip the string so that one end meets the other and measure this diameter.
Step 3. On the other end of the strap you will see the hook which goes over the clasp - you will see the next picture. From this hook the measured distance will be where the end of the string lies.
The clasp mechanism - the watch is to the right of the picture
Step 4. This is the tricky bit! Insert a small screwdriver into the hole on the main clasp part, from the right hand side and bend it down towards the strap thus opening the clasp. Do not insert a tool from the left side, under the clasp and use the bar as a fulcrum; you will bend this rod and the watch strap will not hook over it. Move the clasp to the desired position and gently locate the ridge nearest the position. Once located, press down on the open clasp until it clicks into place - voila!
Related posts:
Dec 26, 2012 | Skagen Slimline Mesh 358SGS Wrist Watch
Como porfabor puedo descargar o obtener el manual de instrursiones de mi relo Citizen eco driver e310 pero no se cual es el modelo aqui le dejo porfavor alguno de los datos que tiene en la tapa y en la...
HOLA YASSERDIDIE !!!!!!!
ENCONTRE UNA PAGINA DONDE VIENE UN MANUAL PARA EL RELOJ CITIZEN E310, ES UN ARCHIVO EN PDF Y VIENE EN ESPA?OL
EL LINK ES: http://sumanual.com/instrucciones-guia-manual/CITIZEN%20WATCH/E310-_S
ESPERO SEA EL MISMO MODELO QUE TU RELOJ Y QUE MI INFORMACION TE SIRVA PARA RESOLVER TU PROBLEMA. :)
Apr 29, 2011 | Citizen EcoDrive Calibre 3100 BT000007E...
I removed the back of my Skagen watch to replace the battery and cannot get it to snap back on.
you need a special tool to press the back back on. you should take it to a watch repair shop or send it into skagen to be repaired. it wont cost much if anything.
Dec 27, 2009 | Skagen Slimline Mesh 358SGS Wrist Watch
Second hand is moving in 4 second increments.
When watch act like this most of the time its required new battery.
AmFix Jewelry & Watch Repair
203 N. LaSalle Street,
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Sep 24, 2009 | Swiss Army Wenger Standard Issue 70609...
Nedd a new band
Any Store who carry skagen Watches can order for you , or you can order your self as well but you may have difficulty to put it on the watch ,, if you are in chicago we carry skagen watches & we are happy to order for you
Chicago, IL 60601
Ph: 312 641 7000
Sep 15, 2009 | Skagen 355LGSC Wrist Watch
How to fasten a Skagen watch?
Hi there. Insert the mesh strap inside the hole and secure with the hook and clip fastening with a foldover security clasp.
Hope this one helps.
May 16, 2009 | Skagen Slimline Mesh 358SGS Wrist Watch
Skagen died
try sending it to skagen they can fix your watch and you will still be covered under there lifetime warranty! they have a great customer service department.
http://www.skagen.com/service/watchWarranty.fx
Good luck! thanks!
Apr 03, 2009 | Skagen Slimline Mesh 358LGS Wrist Watch
Can't open the wrist watch case
Use a Testor's razor knife with eye protection. Use as much of the blade edge as possible. The Testor's blades are fairly strong and thin and I have used them on many Skagens before. I have had some Swiss cases with no gap or tab and the tightest tolerances and the Testor's hobby knife blades were the only hope and solution. Please use care and eye protection for any repairs or service of this nature. Things break and fly off with great force. Including the blade of a knife or razor knife.
Dec 03, 2008 | Skagen Watches
Watches Logo
Top Skagen Watches Experts
Jerry Greenberg
Jerry Greenberg
Gary Nitowski
Are you a Skagen Watch Expert? Answer questions, earn points and help others
