Question about MotorGuide Digital Rf Wireless Remote Kit
Remote control does not work. Tried replacing battery... Trolling motor does not respond to any command.
2 Suggested Answers
SOURCE: Wire going to prop of Motorguide trolling motor shorted
Unless you are mechanically inclined, dont attempt this. Take the lower unit apart by removing the prop and removing the two bolts that hold the forward and aft housing to the center housing. Fwd being the cone shaped part. Pull the aft housing away from the motor so you can inspect the connections to the board that holds the brushes and the soldered wiring terminals. You should find the solder missing from at least one of the terminals that connects the wiring from the foot switch to the speed control windings inside the aft housing. Clean up the terminal and wiring and re-solder. Also re-flow the solder on the other terminals. Clean up the seals and the area where the seals meet the housing parts. Replace seals if damaged. Reassemble the lower unit and torque the bolts 45-50 in-lbs and no more otherwise you will fail the seals. This problem is due to a "cold" solder joint that creates a high resistance to elec current flow and heats enough to melt the solder. This is a result of poor quality control at the manufacturer. Good luck.
Posted on Dec 29, 2011
Good battery , good battery in remote 70 lb thrust trolling motor - no go. ?
Hey Rob,, ??? ..Did you have the batteries CCA checked?? Cold Cranking Amps..?.. this is the only check to determine if your batteries are actually "good"...Next, take a volt meter and check the voltage at the trolling motor connection..if you have voltage at the plug, its time to move up to the head of the trolling motor...Since I do not know what brand if trolling motor we are working on.. these guys will take care of you from here...
home
Jul 09, 2017 | Boating
My motorguide x15 trolling motorjust wants to spin around .. it has a remote foot control
Define 'wants to spin around'?
The propeller motor is supposed to spin around :>)
If the whole motor unit is spinning around you need to clamp the motor stem.
For factory support, you can get that from the website.
Xi5 Trolling Motor Xi5 Wireless Trolling Motor MotorGuide
Jul 19, 2016 | MotorGuide FW71 FB Freshwater Series...
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
How do you reset remote for w75 wireless trolling motor
Its very easy:
Reprogramming the Wireless Foot Pedal or RemoteNOTE: This activation procedure applies to the foot pedal and remote.
IMPORTANT: To activate multiple foot pedals or remotes, the motor must be unplugged from the power source and then plugged
back into the power source between activating each control device.
1. Unplug the battery cables from the power source. Wait 30 seconds and then plug the motor into the power source.
2. In less than ten seconds, press and hold the "+" and "-" buttons on either the handheld remote or the foot pedal controller
simultaneously.
May 07, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
TV does not respond to remote commands,
I'm sure you've tried this, remote batteries is most common cause.
Make sure sensors on TV and remote are unobstructed(remote only works if line of sight to sensor is clear) and clean. Windex and Qtip. Damaged/dirty/defective remote, try different if possible (universal). If none of above works(99% chance), extreme longshot is TV circuitry.
Sep 26, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
C180 Auto car doors not responding to remote commands from key
hello,good day,first try to use your spare key,or check your fuse box at the rear,near your battery,if not corrected,send your car to a dealer for proper diagnose by using hht or star,ty
Jul 21, 2009 | 1988 Mercedes-Benz S-Class
Touch screen not responding to any commands
I tried the 2 solutions i was given but it still didn't fix the problem, I ended up calling logitech tech support and they advised me to install the software and download new programs for the remote, after about 1/2 hour and recalibrating the complete software/ firmware the problem was fixed.
Mar 19, 2009 | Logitech Harmony 1000 LCD Touchscreen...
Sony TV no longer responds to Harmony remote
try using some rechargeable batteries. they tend to have more miliamps and last longer.
Jan 14, 2009 | Logitech Harmony 670 LCD Remote Control
MotorGuide Digital Rf Wireless Remote Kit Logo
Top MotorGuide Boating Experts
Mike
Phil Walker
Phil Walker
Angel Joseph Jr.
Angel Joseph Jr.
Are you a MotorGuide Boating Expert? Answer questions, earn points and help others
