Question about Intel Motherboard
I have just installed XP service pack2 7 changed my hard dive the ethernet controller appears with quetion mark & sound is not working please help .My gigabyte Cd is corrupted
  • 961 Answers
Http://www.gigabyte.us/
This is gigabytes link. You can get downloads ,etc. Try uninstall of software for board and download updated drivers from gigabyte. You might want to save download to file first. If you can give me model # and what system your working with, I can try to help you further. Let me know at "add a comment"
Dave
Posted on Mar 19, 2011
    Brigadier General:
  • 4,044 Answers
Go to the Giga Byte website and download the updated drivers so you can install them. The question mark is telling you it is either not recognized, doesn't have the correct drivers or is not setup correctly. This is most likely the problem with the sound card as well.
I have hp dc7600 i having problem in sound...i installed sound drivers and in device manager ther is no quetion mark means sound driver has been installed but in control panel nd in sound speech and audio...
If you have a soundcard installed it may not be seated properly or if you are using the onboard sound it may be swiched off in the bios, in which case you will have restart the computer and push whatever button is posted on the screen to enter setup (usually F2, F1, ESC, or Delete) and make sur the onboard sound is enabled. The bios setup is a little different for every motherboard so I can't give you specifics but it usually isn't too hard to figure out.
Aug 17, 2011 | HP Compaq dc7600 PC Desktop
My Belkin USB 10/100 Ethernet adapter is detecting as a buetooth device when I connect to my laptop... I am using Windows XP as an operating system. I guess WIDCOMM in windows is causing that...
Wireless Zero configuration is a utility that connects your computer to a wireless network.
If Wireless Zero configuration is not enabled, the following message will appear: "Windows cannot configure this wireless connection."
Note: If you have the Belkin utility installed, you'll need to change the Program Choice in the Options tab so the Windows XP Utility is selected.
Setup steps:
  1. Go to the XP Start menu and select Control Panel.
  2. Change the view to Classic View.
  3. Double-click Administrative Tools.
  4. Double-click Services.
  5. Find Wireless Zero Configuration within the Services list.
  6. Right-click Windows Zero Configuration and select Properties.
  7. Select Automatic from the drop-down menu next to Startup type.
  8. Click Apply and restart your computer.
Jun 06, 2011 | Belkin Ethernet Adapter F5D5050 Network...
The drivers for this device are not installed. (Code 28)
  • if you are having trouble with your drivers
    here is a general look at the drivers and how to update them
    if your computer came with a motherboard disc the drivers could be on it
    click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
    right click to reinstall drivers or
    if you can see your usb but its not working
    ports(com&lpt)right click update driver also
  • Click on "Start."
  • 2
    On the "Start" menu, click on "Control Panel."
  • 3
    In the "Control Panel" folder, click on "Performance and Maintenance."
  • 4
    Click on the "System" folder in the "Performance and Maintenance" folder.
  • 5
    Click on the tab titled "Hardware."
  • 6
    Click on the box that says "Device Manager."
  • 7
    Click on "Sound, Video, and Game Controllers."
  • 8
    Right-click on the device that prompts Windows XP to display Code 28 (it should be Windows Sound System Compatible Driver, also called the WDM driver). A drop-down menu will appear.
  • 9
    Click on "Update" and an Update Wizard will guide you through the installation of a new device driver, which should stop Code 28 from appearing on Windows XP.
  • Read more: How to Repair Code 28 for Windows XP
    Mar 20, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
    Hello i just format my old lab top thorhiba p200 16b and instaled a windows xp profersional fully updated but i cant connect to the internet i get no intenet gaetway and if i connet a lan cable i get...
    go to"my network place" then "view all connections"...den see whether "local area connection" is appearing or nt....if nt dat means u dont ve LAN settings......so 1st get lan . den u will be able to explore de net. for more info see dis... http://www.youtube.com/watch?v=o-kKksYKHR8&feature=related
    Mar 18, 2011 | Computers & Internet
    Motherboard P4i65GV ASROCK. Installed WIN XP service pack 2 , ethernet controller is not installed shows exclamation mark in device manager.Unable to connect to net.
    you must ethernet controller driver first
    goto device manager, right click at exclamation mark, then chose update driver, follow instuction step by step, if it ask for cd driver insert motherboard cd driver, if you did not have cd driver download ethernet controller here
    http://www.asrock.com/MB/download.asp?Model=P4i65GV&o=XP
    wait until process finish and exclamation mark at device manager disappear, and try to connect your computer to internet
    i hope this helpful
    thank you for using fixya
    Feb 02, 2011 | Asrock P4i65GV Motherboard
    No sound from PC, problem with multimedia audio controller
    The yellow mark indicated the multimedia audio controller driver was not installed, therefore the audio won't work/no sounds.
    You need to identify the make and model of the audio card and if you haven't the audio installation CD then you can download the driver from the manufacturer's WEB site.
    Since the repairer fixed your computer, he should have installed the audio driver. I suggest you get the repairer to install the audio driver as it should have been part of the repair service.
    Also if you see any other yellow marks against any devices in the DEVICE MANAGER then these will also need the drivers installed.
    Apr 05, 2010 | Computers & Internet
    Yellow excimation marks under other devices and no sound
    Oh! Sorry.
    Try to search for the XP Drivers for your Laptop or Return the OS to Windows Vista, some Toshiba Laptops does not have XP Drivers if downgraded from Vista to XP.
    Thanks
    Oct 25, 2009 | Computers & Internet
    No sounds:Ethernet controller and Multimedia audio controller is not working
    Hey Hi,
    Please copy paste the link below and DOWNLOAD AND INSTALL the latest drivers and firmware available if any .. Choose the OPERATING SYSTEM carefully.....
    http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=LAT_PNT_P3_C400&os=WW1&osl=en&catid=&impid=
    In case u r having problems in finding which driver to install then visit this link and put in the SERVICE TAG of your dell PC and then click on drivers and download and install the driver for your dell pc.........
    http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
    May 28, 2009 | Dell (8H390) Sound Card
    Ethernet controller
    Go to device manager(right click my computer---Properties---harware tab---Device manager). See if there is yellow mark on ethernet controller or not and upadte ma the same. If there ie a mark over it, install drivers for the same.
    Mar 31, 2009 | Microsoft Windows XP Professional for PC
    Installing xp on acer aspire m1610
    First you want a Windows Xp genuine CD and most of the drivers are built-in in Windows xp, also try to install windows xp with service pack 2 and after installation go the device manager and see how many device required drivers as you can see them with exclamation marks or question marks. go to google and download the device driver run it inside your pc also i recommend before you do got to device manager and indentify all your dirvers like VGA Sound and other devices
    Jul 02, 2008 | Computers & Internet
    Intel Motherboard Logo
    52 people viewed this question
    Top Intel Computers & Internet Experts
    Tony
    Alun Cox
    David
    David
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
