Question about Kenmore Elite HE4 Electric Dryer
I am currently having a problem with my Kenmore Dryer. It is running but it is not heating up to dry the clothes. Someone told me to take the back off and check the heating element but I can't find the heating element. Someone? running but not heating all the time except on high heat
    Scholar:
  • 121 Answers
Hi! pegbrook2
So, is this a gas dryer?
Posted on Aug 13, 2008
2 Suggested Answers
djz83
  • 88 Answers
SOURCE: I am currently having a problem with my Kenmore Dryer. It is running but it is not heating up to ....
I would check your vent if I were you disconnect the vent and run the dryer to see if it works better. also clear the vent line. good luck
Posted on Jan 11, 2009
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Kenmore dryer, the dry runs, but does not heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 11, 2010 | Kenmore 63942 Dryer
No current but light is on in dryer but not on dials.
your dryer is 220 volts. that will have two 110 lines going into it
one of the lines is for the motor & heating grid only
The other line runs the rest
May 31, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elec dryer runs but won't heat up
Can be several problems: the heat element (coil) can be burned out, one of the over-heat sensors could be bad or overheated and did not reset ( this could be caused by poor air movement through the vent ) check your venting for good air flow. Could be a wiring connection that burned and needs repair because of the hi electric current demaned by the heat element. Goodluck, Macgivor
Jan 27, 2010 | Kenmore 64902 Electric Dryer
The fuse for the heat keeps blowing but dryer runs
if its an old round buss fuse that screws in the panel(especially an old 60 amp panel),sometimes the center where the fuse lands the insulation gets weak in this area and lets it arc over when the dryer calls for current to heat the element replace this with a sub box and breaker set-up.the other thing it can be is the element is touching the units case and grounding out causing the same problem
Jan 25, 2010 | Kenmore 82822 Electric Dryer
Kenmore dryer makes no heat
replace the heating element. Or the control panel has weakening capacitor not sending correct current flow to the heating element
Jul 09, 2009 | Dryers
Dryer won't Heat up - Kenmore Elite HE4 Gas Dryer
hi..A poor connection between the wire terminals and the
heater relay causes high current draw and damages the
terminals on the heater relay on the main control board.
check it out..
thank u..
kindly rate my response..
Jun 09, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore series 80 gas dryer will not heat up
Hi. this dryer has a set of coils that sit on top of the actual gas valve assembly. these coils activate the main and secondary gas valves and if the coil assembly is malfunctioning or, the wires and clips are corroded, the coils will not activate the gas valves to open and close. this malfunction will affect the heating process within this dryer unit.
I recommend inspecting the dryer coil assembly. use a mulitimeter to test for Resistance. you should get a reading of some type of current flow through the wires and, if this is the case, the coils are bad and they will need to be replaced.
This test is actually not needed. the non existing heat is a red flag on its own and, it greatly confirms a major failure within the coil assembly. replacing the coils will fix your dryer.
PLease rate and god bless:)
Apr 20, 2009 | Kenmore Dryers
I am currently having a problem with my Kenmore Dryer. It is running but it is not heating up to dry the clothes. Someone told me to take the back off and check the heating element but I can't find the...
Jan 10, 2009 | Dryers
On heat in dryer
Bad coil/may be your 220V is tripped,so reset your breaker and re try dryer.The dryer will run on half the power.The other half supplies the current to the heating coil.I'll be happy to help you through this.
May 21, 2008 | Kenmore Dryers
Kenmore Elite HE4 Electric Dryer Logo
391 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
