Question about Harman Kardon HKTS 14 System
TS14 subwoofer LED stays orange and not functioning. How do I open my sybwoofer.
  • Luan Nguyen
    Luan Nguyen May 04, 2012
    Hi, have you found a solution?
  • 2,574 Answers
Navigate to this page ..on page #13 you have a exploded view of your subwoofer .
Posted on Mar 19, 2011
No wireless connection for laptop. Linksys router - model #wrt160n v2
you can run a direct line to that router and go to the cisco web site and get the information you need to run that router. its a pdf format and is 2.56 Meg. Try this
SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
lights up and will stay orange when the Router is powered on. The color orange indicates that
the Router is not using the SecureEasySetup feature, while the color white indicates that the
Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and start flashing. After the Router has generated
the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
Power (Green) The Power LED lights up and will stay on while the Router is powered
on. When the Router goes through its selfdiagnostic mode during every boot-up, this
LED will flash. When the diagnostic is complete, the LED will be solidly lit.
DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
Internet (Green) The Internet LED lights up when there is a connection made through the
Internet port. A flashing LED indicates network activity over the Internet port.
Good luck
Nov 26, 2010 | Computers & Internet
Tip
Waste ink full on Canon ip2000 series, and service mode
<Service mode operation procedures>
1) With the front cover closed, and the printer power turned off, while pressing the Resume/Cancel
button, press and hold the Power button. (DO NOT release the buttons. The LED lights in green
to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the
Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release
both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed,
the LED lights alternately in orange and green, starting with orange.) During initial operations,
the LED blinks in green.
4) When the LED light sin green, press the Resume/Cancel button the specified number of time(s)
according to the function listed in the table below. (Each time the Resume/Cancel button is
pressed, the LED lights alternately in orange and green, starting with orange.)
Time(s) LED Function Remarks
0 times Green Power off When the print head is not installed, the
carriage returns and locks in the home
position.
1 time Orange Service test print
2 times Green EEPROM information print
3 times Orange EEPROM initialization
4 times Green Waste ink counter resetting Proceed to the step 5), and follow the
Waste ink counter reset procedures.
5 times Orange Destination settings Proceed to the step 5), and following the
Destination settings procedures.
6 times Green Print head deep cleaning
7 to 9 times Orange Not used in servicing
10 times Green Return to the menu selection
5) After the function (menu) is selected, press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu
In the waste ink counter resetting mode, press the Resume/Cancel button the specified number of
time(s) according to the ink counter reset value listed in the table below, and press the Power button.
Time(s) LED Waste ink counter value
0 times Green Reset the main waste ink counter (0%).
1 time Orang
e
Reset the platen waste ink counter (0%)
2 times Green Re-set the main waste ink counter value to 50%.
<Destination settings procedures>
In the destination settings mode, press the Resume/Cancel button the specified number of time(s)
according to the destination listed in the table below, and press the Power button.
Time(s) LED Destination
0 times Green No change
1 time Orang
e
Japan
2 times Green Other than Japan (A4)
3 times Orang
e
Other than Japan (LTR)
on Jun 30, 2010 | Canon PIXMA iP2000 InkJet Printer
Tip
Dell Portable Battery LED flashes Orange 4 times then Green once
This LED flash pattern, Orange, Orange, Orange, Orange, Green (Repeats) indicates a internal failure of the Battery. Pressing the charge indicator button on the battery (If equipped) will give a 1 3 5 LED on indication which also indicates a failure in the battery.
The battery may still function, but at less than optimal performance and will have a progressively shorter functional life until it dies.
The only way to resolve the issue is to replace the battery.
on Dec 23, 2009 | Computers & Internet
Canon IP 3000 - ink absorber full
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the
Power button. (DO NOT release the buttons. The LED lights in green to indicate that a function
is selectable.)
Power button.)
4) When the LED lights in green, press the Resume/Cancel button the specified number of time(s)
Times LED Function Remarks
0 times Green Power off When the print head is not installed, the carriage
returns and locks in the home position.
1 time Orange Service test print See APPENDIX 1, SERVICE TEST PRINT.
2 times Green EEPROM information print See APPENDIX 2, EEPROM INFORMATION
PRINT.
Jul 02, 2010 | Canon PIXMA iP1300 Printer
Hello - My Canon Pixma iP2000 won't print anymore as I get a dialogue box advising me that the ink absorber is full. How do I remedy this? Heather Knittel goodriddance@telus.net
Power button.)
position.
1 time Orang
e
Jun 23, 2010 | Canon PIXMA iP2000 InkJet Printer
SONY DCR-PC100 The video control panel should illuminate orange so you can see the buttons. Now this only illuminates when you open the cassette door to remove a tape. As soon as the door is closed, the...
The camera has in fact 2 leds built-in, so it rather looks like one led is out, I had same problem, and sad to say stripping it down to put a new led in is,,, shall we say an eye opener, o yes a wallet opener too.
Jun 12, 2010 | Sony Handycam DCR-PC100 Mini DV Digital...
Audio control pod
I have a similar issue too, but my problem is that the sub has green light, and my control pod has an 'off' light, but it won't turn on :(
Jun 16, 2008 | Creative Labs Gigaworks S750 Computer...
Subwoofer
Repeated fuse blowing generally indicates a blown power supply, or blown output stages or both. One thing to do is be sure that you have replaced the fuse with the correct type. A T stamped into the metal of the fuse near the rating, indicates sloblo or Time Lag fuse. A fast blo fuse, may work once, or more times, but will never replace a sloblo fuse in this type if unit. Good Luck, hope this info helps, don't hesitate to hit me back here for more help :)
regards
Graeme
Feb 13, 2008 | Harman Kardon HKTS 7 System
Harman Kardon HKTS 14 System Logo
257 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
