Question about Dayton (3UG73) Electric Utility Heater
I NEED TO REPLACE THE THERMOSTAT WHERE IS THE
I NEED TO REPLACE THE THERMOSTAT WHERE IS THE NEAREST PARTS SUPPILER
    Brigadier General:
  • 4,736 Answers
Dayton is a product of Grainger Industrial Supply. Here is a link to their website. You can order parts online or search for the location nearest you.
http://www.grainger.com/Grainger/wwg/start.shtml
Posted on Mar 19, 2011
I need a manual to replace a thermostat where can i get one for a well f-67
Hi there.
You can visit http://www.wells-mfg.com and look for the nearest authorized parts and service dealer.
Regards.
Jul 27, 2011 | Wells F-67 21167 Deep Fryer
AMANA G37025 need to defrost the frig evry three days
Replace the defrost heater,defrost thermostat and defrost timer.
Jul 17, 2011 | Refrigerators
Oven gets to hot
Hi j_hallinan,
The Thermostat is most likely defective.
I'd suggest taking the thermostat out, and showing it to your nearest Appliance Spares outlet. They should be able to give you the correct thermostat to replace it with.
Regards :-)
* If you found this solution helpful, please rate it.
Jul 08, 2011 | Ovens
Need a new thermostat
Hi there.
For your Cecilware Fryer, you can find the nearest authorized parts and service dealer on your area when you visit http://www.grindmaster.com
Regards.
Jan 11, 2011 | Cecilware FMS-40 Deep Fryer
The power light is not on & it is not becoming hot & not working for which we wre not able to make rice
Replace the thermal fuse! check the thermostat setting! If u don't have knowledge on such parts and service, bring it to ur nearest dealer or electronic technician! taah!
Nov 13, 2010 | Black & Decker RC550 10-Cup Rice Cooker
The therostat bulb broke off the end of the wire in the fryer can this be fixed or is there a place to buy a second hand one Frank D
Hi there.
You need to replace the thermostat and I suggest you replace it with a brand new and original part. The operation of your fryer will be compromised sooner or later when you use a second hand part.
You will be able to find the nearest Cecilware parts and service provider when you visit http://www.grindmaster.com
Regards.
Sep 22, 2010 | Cecilware Kitchen Appliances - Others
Need to replace thermostat, and new radiator cap. Have any instructions?
Assuming you have the Northstar engine.....
The thermostat in the northstar engine is located at the bottom radiator hose (unlike most conventional cooling systems), the hose connects into the housing where you will also find the water pump.
You will need to remove the air filter housing and air duct to gain easy access to the thermostat.
Remove the hose from the housing,then remove the two bolts on the flange,the thermostat can then be pulled out.
Take note of the orientation of the thermostat as you remove it.
The thermostat in the Northstar engine is a duel action device.
One end of the stem is the Thermostat(obviously) and at the other end is a spring loaded pressure valve(the thinner end).
Make sure the thermostat end is nearest the rubber hose and the pressure valve end is in towards the engine.
Don't forget the new gasket when you install your new stat, you may have to order this separately.
There is no radiator cap.The only cap is on the purge tank and these are quite cheap to buy and easy to replace.
Jun 14, 2010 | 1996 Cadillac DeVille
I was not getting heat in my electric dryer, i replaced the heating element, it worked for a few minutes, then i lost heat again
If you've already replaced the heating element, you need to check the Thermal Cut-Out (TCO). The TCO works in conjunction with the Hi-Limit Thermostat to regulate and protect the heating element. Both of these components are mounted on the outside of the heater box. The TCO is located at the end opposite the heating element terminals, while the Hi-Limit Thermostat is located adjacent to the heating element terminals.
The following link explains how to troubleshoot these components and what the resistance readings should be:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
If the TCO is found to be defective, it is recommended you replace the Hi-Limit Thermostat as well. Failure to do so can result in premature failure of any parts you replace. These two components are commonly sold as a set.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, you can use the part numbers from the Sears website and go to your nearest appliance parts retailer. These components are commonly sold as part of their in-store inventory.
If you have any questions about this repair, please post back and let me know. I hope you find this information helpful.
NOTE: Make sure you verify the power at the wall receptacle before you begin. If you are missing half your input voltage (due to a tripped breaker or bad power cord), the dryer may still run, but won't heat.
Feb 25, 2010 | Kenmore Dryers
Install programmable Carrier thermostat
you'll be needing an assistance from an A/C technician, If this a progammable you want, some configuration need to be done and a technician can only do that.
You can search the web for a local carrier dealer nearest to you
Nov 05, 2009 | Carrier Heating & Cooling
Dayton (3UG73) Electric Utility Heater Logo
371 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Tim Whalen
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
