Question about Pioneer Deh-1200mp Car CD/ MP3 Player
I have all the wires connected however I have to have the red and yellow wires connected together for the radio to even come on. And once I turn the car off after about 30sec. All the memory is gone like radio station and settings. How do I get the memory to stay? I have a chev. Cavalier 98
    Problem Solver:
  • 9 Answers
I would recomend running a wire with an in-line fuse straight to the batt has always worked for me. good luck and take care
Posted on Mar 20, 2011
My Kenwood KDC-U453 cd receiver displays "PROTECT" on connection and nothing works - any solutions appreciated!!!!
Pull the radio out, tape off all wires but yellow, red and black. Twist red/ yellow together and attach to positive 12 volt, attach black wire to negative 12 volts. Turn on radio and see if it comes out of protect mode. If it does, you will have to troubleshoot all of the speaker wires to find a short.
Apr 11, 2013 | Kenwood Kdc-u453 Car Audio Radio Iphone...
Cant get the power to work on a xd1222
If the radio is correctly installed and, there is no power on the vehicle's accessory wire when the key is turned on, check the vehicle's radio fuse. If you connect the red to constant 12 volt along with the yellow radio memory wire the stereo WILL NOT TURN OFF. There is nothing strange about that.
Oct 14, 2012 | Dual Electronics XD1222 Car USB Player
Radio only works if the red and yellow wires Are Tied together
sounds like you blew a fuse my friend. check it out
Jul 22, 2010 | 1996 Chevrolet Cavalier
Fitting a jvc head unit to a 1990 telstar tx5 does the yellow wire from car connect to yellow from jvc and does red access. wire from car connect to red from jvc. because have tried this nothing happening...
get a voltmeter(multimeter) and check the voltage on the
red wire
and
yellow wire
(from the car)
when the car is turned off and when the car is on
one should be 0V when the car is off
and both should be 12V when the car is on
then you need to match that up with the radio using the manual
but im guessing that you dont have a manual so...
i want ot confirm that
when you connect red to red and yellow to yellow
nothing happens
try the oposite way
red to yellow yelolow to red
May 29, 2010 | Car Audio & Video
DehP6700 mp restet everytime keys is turned on.
first red is ignition or acc (turns off and on with the key) yellow is constant power (always hot keeps memory) orange is illumination (lights up radio) if vehicle doesnt have a seperate illumination wire connect it to the ignition wire. now process of elimination your ground is correct because it worked with all wires to acc your acc works because u had all them connected to it and it worked your problem is in your yellow or constant/memory i suggest u test it again take piece of wire any old thing long enough will do and run the wire directly from the battery under the hood and just run it outside the car through the window and connect it directly to the yellow wire make sure u have a good connection at the battery on the positive side if u have test light or volt meter test the wire before connecting it to the radio if it works then u know there is a problem with the wire from the vehicle (fuse wrong wire bad wire ) if it doesnt work make sure ground is connected tight and that paint is cleaned of the surface where ground connects and that the yellow wire to the radio is tight in the back of the radio.
Nov 13, 2008 | Car Audio & Video
Ok i am putting in a alpine head unit in a 99 neon i can get it to hold the memroy i have to put the red and yellow wire together and do the same on the wiring bracket and when i put all for together the...
The yellow wire must be connected to a constant voltage source. You have the red and yellow connected to a voltage source that only gets power when the car is turned on. The yellow wire is for the memory. Check the fuse box for a fuse that has voltage on it when the car is off and the key is not even in the ignition. That is the type of connection the yellow wire needs. The red wire can stay connected to the place it is at now.
Are you using a harness that is made for installing a radio into a 99 neon? They sell them at most all places that sell car stereos. Go in and ask for an installation harness for your car and then you connect it to the harness that comes with your radio by matching the colors of the wires and you have a nice and easy install. It plugs right into the factory harness with all the connections you need.
Jun 17, 2008 | Car Audio & Video
Vauxhall vectra car radio wiring
car stereo wont come out when using dins keys 03 vectra
Jun 09, 2008 | Car Audio & Video
Won't turn off or on automatically
You must have the yellow and the red wires tied together on a constant voltage source.
Only the yellow wire should be on a constant voltage source.
The red wire should only get voltage when the ignition is turned on or in the acc. position.
You need to rewire the red wire on the radio.
Let me know if it helps.
Jun 07, 2008 | Kenwood KDC-MP4028 CD Player
JVC car radio/cd player wont switch on
As a sanity check run a temporary wire directly from the battery positive to the radio. Twist the red and yellow wires together and connect it to the wire from the battery. If this works either your red or yellow wire connection under the dash or to the harness is not hot like you think. Yellow usually goes to a constant 12 volt source (to keep radio memory) and the red wire to 12volts when the ignition is on. In some radios this is reversed. The test I mentioned will determin if the problem is in the wiring or the radio.
Jun 18, 2007 | JVC KD-S570 CD Player
Pioneer Deh-1200mp Car CD/ MP3 Player Logo
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
