Question about Dell Dimension 4600 PC Desktop
House hit by lightning - Ethernet not connecting to router
Tried a laptop and the connection to the router is good. Tried releasing and renewing IP address, rebooting, the obvious stuff. Any other suggestions?
  • hedemora Aug 06, 2008
    I have got the same problem with exactly the same
    equipment. Happened in the beginning of July 2008.
    Tried testing an replacing everything from the telephone
    connection to the pc, such as router cable.
    Problem Solver:
  • 9 Answers
The problem I had, I've fixed by adding a new network card, as the one
integrated in the motherboard was corrupt.
Posted on Sep 18, 2008
    Scholar:
  • 110 Answers
Most likley the network card is bad. Check if you get any lights on the network card. If there are no lights get a PCI network card for the system. If you get the link lights it could be just corruption on the system. Try uninstalling and reinstalling the drivers.
Posted on Sep 17, 2008
Internet conexionlocal only
Wired or Wireless? If Wireless will not connect, First try a test, using a Ethernet cable connect directly to the ISP modem, Does it connect? Yes or No? If yes, move the cable to the Wireless router, Does it connect, Yes or No? If no, Contact ISP. Check ALL cables to the ISP and Wireless device ,reseat cables. It may be the Laptop Wireless or wired adapter, reboot the laptop and the wireless device. I don't have all the info needed to supply a more percise solution. Try a IP release and renew using this procedure : http://helpdeskgeek.com/networking/release-and-renew-an-ip-address/
Jan 29, 2013 | Acer Aspire 7720 Notebook
Dap 1160 Problem access web admin page
connect device directly to your computer using Ethernet cord. try to release and renew IP from the command prompt
IPCONFIG /RELEASE
IPCONFIG /RENEW
IPCONFIG /FLUSHDNS
then perform ipconfig. From there you will be able to get the IP address of the access point that you will need when accessing web admin page
Dec 22, 2012 | D-Link DAP-1160/B ACCESS POINT, WLESS G,...
Linksys Wireless-G WRT54G Router wifi working but local connection to my computer doesn't work. configuration is working on my computer but it doesnt receive any connectio.
1. check the Ethernet cable
2. check the DNS/DHCP setting ( should be set to Obtain IP automatically) on both.
3. Do an ipconfig / release then renew in the command line in the DOS window
4. if cable is good move it to another port in the router.
5. check the release/renew of the ip in the router con fig window> usually 192.168.0.1 > inputted in the browser<
6. check the light status of the port where the Ethernet ( if yellow then ip needs to be released / renewed.
Oct 05, 2011 | Linksys Wireless-G WRT54G Router
It won't go online but the other laptops in our house is online working fine...I tried rebooting it back to factory settings and it won't reboot what could be the problem it is showing all the...
First thing you can do is a ipconfig /release /renew on the laptop that isn't connecting.
to do that, go to:
Start>All Programs>Accessories>Command Prompt.
Once thats open, type in ipconfig /release
note, there should be a space between ipconfig and /release and renew
your ip address should come up with 0.0.0.0
Now type in ipconfig /renew
remember a space between ipconfig and /renew
You should see an ip address of 192.168.XXX.XXX or 10.10.XXX.XXX something like that, depending on your network settings.
if you do, you should be able to get on the internet.
If you see an address of 169.254.XXX.XXX
Then it would be best if you powered off the Modem and the Router.
First turn off the Router, Next the Modem.
Power back on in reverse order and see if it is able to connect then.
If all that fails, You can reset the router and see if it will connect then.
You should have a reset button on the back of the router.
Remember once the router is reset, you'll have to redo the security settings.
Hope this helps!
Please Rate;)
Gary
May 25, 2011 | Compaq Presario Notebook
The 2701hg-b is not sensing that I have connected my dell laptop. ethernet port on router is not lighting up when I make the connection. When I run cmd/ipconfig on my laptop it is blank. I've already...
1. the command you are using is incorrect it is : ipconfig /release >>> then ipconfig /renew
at the DOS prompt.
2. to get to the DOS prompt you will need to type "cmd" in the search field the hit enter
this will bring you to the DOS screen.
3. unplug the Ethernet cord for 30 seconds then reconnect it
4. go into the router via a browser window / in the address locator enter 192.168.0.1 this
should bring you to the routers GUI ( graphical user interface) then from there go to the
router status page and use the "helps" to lease/ renew the IP address assigned by the
router.
Oct 07, 2010 | 2wire 2700HG-B Router (2700HGB)
Why does my computer say LAN is not connected but my ethernet cable is plugged in?
1. You possibly have lost the IP address from the ISP to your router and you will need to release/ renew the IP or you have a damaged Ethernet cord ( rare) but none the less could be damaged.
2. unplug the Ethernet cord from the connection at the wall for a few seconds and then plug it back in the wall connector.
Then try your connection. Call your ISP ( internet service Provider) and check the line to see if you have proper signal to the router.
Further instructions:
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop/desktop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Jul 27, 2010 | 2wire (1000-400108-001) Router
Not able to connect to desktop with ethernet cord
What is the current IP address?
Can you ping the default gateway?
Did you also do:ipconfig /flushdns and
ipconfig /registerdns
Have you tried uninstalling / reinstalling the network card? (inside device manager)
Hope any of this helps.
Nov 07, 2009 | 2wire (1000-400108-001) Router
Configuring nbg334w router
To configure the wireless router it is recommended the it is connected directly to router.
Please follow these steps to fix your issue
1. Reset the router using reset button on the back of the NBG334W router
2. Configure or change the laptop ehternet adaptor setting to "Obtain IP address automatically.
3 connect laptop and router using ethernet cable. check the ip address using ipconfig command in DOS prompt. If IP address is 0.0.0.0 or 169.X..X..X run command
ipconfig /release
ipconfig/ renew
best way restart the computer
4. if you still have issue in getting ip address double check ethernet cable and try reseting the router again.
5. Still problem persist install new firmware on the router. you can download router firmware from
http://www.zyxel.com/web/support_download_list.php?indexflag=20040906164737&ModelIndexflags=0,420070320142921
Please vote if this information is helpful in resolving your issue
Dec 27, 2008 | Zyxel Prestige 334 Router
Unable to connect to internet
Try going to command prompt and type ipconfig /release
Then type ipconfig /renew after the IP is released. If you like, I could remotely connect and troubleshoot it for you.
Jun 24, 2008 | Dell Dimension 8200 PC Desktop
Netgear WG602 wireless router, Connection Local only !
What I think is you unplgged them at the wrong times.
Do this:
(in this order)
  1. Turn off the router.
  2. Turn off the modem.
  3. take out all the Ethernet cords from the router, EXCEPT the one coming from the modem
  4. Now turn the modem on.
  5. Wait for the lights, then wait about another minute for it to settle.
  6. Turn on the router, make sure the Internet,Lan,Wlan,etc lights are on and functional if it doesn't display a light let me know.
  7. Now depending on what your wireless network (SSID) is called try to connect to it. Go to Start>Network>Click Network And Sharing Center at the top>on the left select Manage Wireless Networks>now click add, if your network is already on the list shown select it and click remove otherwise click "Add" click "add network in reange of this computer" select your network name and click connect.
Now tell me the errors, like if it says connection limited,etc...
Thanks,
Cam
Oct 18, 2007 | NetGear WG602 802.11g/b Wireless Access...
Dell Dimension 4600 PC Desktop Logo
322 people viewed this question
Alun Cox
