My acer laptop shows a charge {admitadly it seem slow to charge} but when I disconnect the power cable the laptop shuts down immediately, can you help. Thanks
    Prodigy:
    An expert who has answered 500 questions.
  • 674 Answers
Replace battery to solve this problem.
Speed Up Laptop
Posted on Jul 27, 2011
    Master:
  • 344 Answers
Sounds like your battery is going bad on you. Especially if you charge it and as soon as you unplug it shuts down.If you have a volt-meter you could test it for voltage AND amperage. You may even be able to find a local store that might be willing to test it for you.
Posted on Mar 19, 2011
Laptop power light comes on , fan starts then laptop shuts off
Laptops (and PCs) have sensors to kill the power when overheating takes place, particularly the CPU. You should take it to a local repair shop and let them look at it for you
Oct 03, 2017 | Acer Genuine Aspire 5250 5333 5733 5733z...
My john deere la125 seems to be drawing power wile shut down, it take a week for the batter to go dead, i've pulled the batterer and it stays charged up , I've checked the charging unit and i
What you do is power off the machine, and disconnect the negative battery cable. Put a test light or volt meter between the battery negative terminal and the disconnected negative battery cable.
You will likely have a light or voltage reading...Then you start disconnecting things....I suggest the alternator.
When you have the correct component disconnected and the test light or volt meter shows no current.
If this component is the alternator, they have diode sets inside (or somewhere else in the charging circuit) Typically one diode fails and this causes the draw that you describe. The system often still charges, but at a slightly lower capacity with the failed diode.
Doc
Nov 23, 2012 | Garden
Medion E1210 notebook. Battery has suddenly stopped charging. Didn't get a fall. Laptop works fine when power supply connected, but if plugged out laptop shuts down immediately. When power plugged in...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 21, 2011 | Computers & Internet
I bought acer aspire AO531h one few months back. For last few weeks its battery not charging.With AC(plugged in),notification icon says"plugged in,charging",however "0% available"even...
Feb 04, 2011 | Computers & Internet
I own an Acer Aspire 5810-TZ. The battery seems to be 100% charged but if I unplug de ac cable, the computer shuts down.
Battery is expired. Get new one or get yours rebuilt (about half the price and the cells are better than new) They are on the internet, look up Laptop battery refurbishing. Or outside chance that the charging circuit in the laptop is bad.
Oct 19, 2010 | Acer Computers & Internet
C500 Laptop won't come on power button just flashes
Have you tried attaching an external monitor when the LCD screen is disconnected from the motherboard? this connector is located under the keyboard strip – a piece of plastic just above the keyboard.
If it works, this way, then the video cable isn’t seated properly in the connector on the back of the screen. Plugging the video cable back in should fix the problem.
I don’t know how comfortable you are with taking apart laptops but I think that this information could be useful for you.
Source: http://www.asklaptopfreak.com/laptop-notebook-help/2006/08/08/laptop-powers-on-and-shuts-off-immediately/
Sep 28, 2009 | Compaq Computers & Internet
Acer 3100 laptop lights on fan on slow but no screen
Remove the battery and disconnect the Ac adapter from the laptop. Press the power button and hold it for 10 seconds.Reconnect only the Ac adapter and power on the laptop.
Post back if the above solution doesnot work , it could be bad video card driver.
Thanks for using fixya
proton
Aug 12, 2009 | Acer Aspire 3100-1405 Notebook
Acer Aspire 2920 won't turn on, although plugged in with battery
First of all, what I'm about to tell you are general troubleshooting techniques - I make no claim that they will fix what you describe, but they may help lead you to a solution.
  1. Unplug the AC adapter and remove the battery
  2. Plug in the AC adapter and attempt to power on the laptop
  3. If it doesn't power on, see #6 below. If it does power on, but doesn't boot the OS, restart - pressing [SPACE] as the first Windows splash screen appears. When prompted, choose to delete the hibernation file and start a system boot.
  4. Shut the system down, disconnect the AC adapter, reinsert the battery, and attempt to power the laptop. If it doesn't start we know, at the very least, there's a battery problem.
  5. Plug in the AC adapter. If it shuts down immediately, or won't power back on after a shutdown. . .
  6. . . .there's a problem with the system board, probably the ciruitry associated with charging the battery.
I hope you 'see the light'. Good Luck!
Jun 15, 2009 | Acer LXA3706003 Notebook
BATTERY NOT CHARGING
Try replacing the battery, i think the battery is defective.
May 09, 2009 | Acer Aspire One PC Notebook
Laptop will not power up
you may have inadvertently killed the power module of the laptop. that has happened to me a couple of times, so far, and repair has always been in the hundreds of dollars. I hope that is not the problem in your case. Have you tried using a universal power supply to make sure that your power supply is not the issue? Anyways, the best of luck to you.
Dec 24, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
