Question about Nokia 7020 Cell Phone
Phone doesn't charge, when charged, battery dies quickly.
  • 492 Answers
Defective battery or excessive power drain caused by liquid damage. Hopefully just a bad battery.
Posted on Mar 19, 2011
4 Suggested Answers
zeusfaber
  • 247 Answers
SOURCE: Phone dies quickly after charging
It would be helpful to know just how quickly the battery is going flat, and I'm assuming there's no history of the phone having been damaged, but... Try swapping the battery for one from a friend's phone. If that cures the problem, you need to buy a new battery (they don't last forever). Otherwise, try charging the battery fully in a friend's phone using their charger, then see how long it lasts. If this lasts much longer, the problem is that the phone/charger combination isn't charging the battery properly. Mix and match chargers and handsets (mark which are yours before you start, or you will get mixed up) to identify where the problem lies. If the battery isn't old and tired, and the phone is charging it properly, then the problem must be that the phone is drawing excessive current. This could be because you've got it set up to do some power-hungry thing (backlight continuously on, playing MP3s or FM, promiscuously Bluetoothing or IR communicating, etc). Shut down all the functions you don't actually need at the time and see if that makes any different. Once you've eliminated all those, you're left with the liklihood that the phone has a fault which is making it draw excess current. Not good news, but at least you've eliminated all the other possibilities. A.
Posted on Jul 25, 2007
k roll
  • 30 Answers
SOURCE: my phone battery died the
try take out the battery n put it back.n then try charge.
Posted on Jun 22, 2008
  • 318 Answers
SOURCE: htc hd2,phone battery died,put on charge and turned it
take a look at this link i found, it shows you how to do a soft reset on your htc hd2:
http://www.htc.com/europe/howto.aspx?p_id=297&id=181
HOPE THAT HELPS.
Posted on Jul 07, 2010
My samsung sch-u450. will not charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sep 30, 2012 | Samsung SCH-U450 Cell Phone
My Nokia E73 won't charge
First Option:
Second Option:
Sep 15, 2012 | Nokia E73 Mode Cell Phone
Nokia 5800 not holding charge
First Option:
Second Option:
Sep 13, 2012 | Nokia 5800 XpressMusic Smartphone
Phone won't charge
First Option:
Second Option:
Jul 28, 2012 | Pantech Pursuit Cell Phone
MY CORDLESS PHONE BATTERY KEEPS DYING
You could try leaving it on charge a bit longer but if it keeps happening it either means dock doesn't charge the battery any longer (check for the charging symbol on the phone when in dock), or the battery in the phone has had its days.
Jun 05, 2012 | Vtech ia5870 Analog Cordless Phone
Battery dies too quickly
Did you fully charge your battery when you first opened the phone? If not, the battery will never hold a full charge. it tells in the booklet that comes with your phone. Not giving your phone at least 16 hours on the first charge might cause battery trouble later. You may need to replace the battery. I hope this helps.
Mar 21, 2012 | Samsung Behold Cell Phone
Battery is dying after 10 min talk time
Normally when a battery does that it has to do with it's very first charge. If the phone was turned on at all before the first charged reached it's full capacity, one day out of no where it will just die very quickly. You should also notice that when it charges it reaches a full charge more quickly than it did before. If that is not the case then you just got a defective battery. I can tell you for sure it doesn't have anything to do with the memory card.
Dec 28, 2009 | LG Dare VX9700 Cell Phone
Bought my phone yesterday...Battery was losing charge quickly.. battery was down to half charge after about 15 minutes of fully charging.. Was trying to let the phone die completley then fully charge it,...
Ok first of all you should never let a phone die out of charge at all.IF it dies out of charge there are chances it might charge again once you charge it but in some cases it wont, you need to boost your battery just like jump start your car.It cannot be done anywhere except some service centre. If you are not taking to your service center , then you need to buy a new battery.
Oct 08, 2009 | Cell Phones
Battery life dies out quickly on Nokia 6301...
if you have had your bluetooth on or have been listening to music for a long time that can drain the battery very quickly . the other problem could be if you are not lettting it die of totally then charging it the battery remembers so when you do charge it the battery dont last long . try turning your bluetooth off or just lettin your battery die off totally then charge it fully
Aug 07, 2009 | Nokia 6301 Cellular Phone
My K800i battery dies very quick
Dear Friend,
                 U are saying that u have bought this mobile 2 yrs back so check wither ur battery has been expired and change it.Otherwise switch off ur mobile and put it in charge and check it out the normal standby for any mobile is 2 to 3 hrs.Kindly check it and revert back
Regards,
Aysaam
May 06, 2009 | Sony Ericsson K800i Cellular Phone
Nokia 7020 Cell Phone Logo
115 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
