Question about Pentax 6x24x 50mm LS30 Matte Scope
I have a pentax scope, 6x18x pentax mc. made in usa. the problem is the horazonal will adjust but the vertical will not adjust it turns but will not change. i bought this from a used gun dealer. who said it was a good scope. it shoots straight but cant adjust height.
2 Suggested Answers
  • 117 Answers
SOURCE: I have a Pentax lightseeker
If it has a cracked lens it obviously took a very hard shot at some time or other.I would send it back to Pentax.They are not cheap, so I would attempt to get it repaired by the manufacturer.
Good Luck
Posted on Mar 25, 2009
I have a Simmons Model ATV 4515 rifle scope. other
Your scope has 5 adjustments:
1. Eye piece focus - used to focus on the reticle.
2. windage adjustment - should be on the R side of the scope, adjusts lateral impact point.
3. Vertical adjustment - the top turret. Adjusts vertical point of impact.
4. Power ring - adjusts the magnification of the scope.
5. AO ring - Parralax adjustment - used to focus the scope at specific distances. Most markings are not exact, you should set it at the range you are shooting and fine tune focus when you look through the scope.
Sep 06, 2013 | Optics
Locating the horazonal hold control button on a magnavox 19inch tv modle number 19pr14c225
old models had small Pot for adjustment the horizontal+vertical etc
Newer model doesnot.By that reason you will NOT find it.
I am sorry.
if you have some problem you must go to the repair shop TV.
God bless you
Jul 31, 2012 | Televison & Video
How do i use a tasco 28A
1. Insert the Bore Stud into the Stanchion while aligning the arrows as shows. Insert the assembled scope guide into the muzzle of your rifle with the grid pattern upright. 2. Select the Aperture Cap that fits your objective rim. Place it over the objective end of your rifle scope and press until it fits flatly against the rim. 3. Using the Adjustable Scale measure the top of your rifle scope tube to the center of the rifle bore as follows: Open the rifle breach. Rest the upper arm of the scale on the scope tube before or behind the windage and elevation turrets. The scale markings should be facing towards you reading vertically and ascending from bottom to top. Slide the lower end of the scale up or down until it is touching the center point of the bore. On center fire rifles the center point will be the firing pin. On rimfire models the center will be the shell extractor. Read the number that corresponds to the indicator marked "CF". Make a note of the reading. 4. Aim the rifle toward a light, flatly lit area such as a wall or open sky. Caution: Do Not Look At The Sun As Permanent Eye Injury Could Result. 5. While keeping the riflescope at the right distance to see the full field of view, sight through it on the grid pattern. Move the stanchion right or left until the bold centerline is parallel to the vertical reticule wire. Turn the windage dial right or left until the vertical reticule is aligned with the grid centerline. 6. Use the reading from the scale to align the horizontal reticule wire. Find the numbered horizontal grid line that corresponds to the number on the scale. Turn the elevation dial right or left until the horizontal reticule wire aligns with this corresponding grid line. 7. To make your final zeroing adjustments remove the scope guide from the bore of your rifle. WARNING: FIREING YOUR RIFLE WITHOUT REMOVING THE SCOPE GUIDE MAY CAUSE DAMAGE TO YOUR RIFLE AND OR CAUSE YOU INJURY At a range or other safe area test fire a group of three rounds of the same type ammunition at a target at least 50 yards away. Refine your scope alignment by adjusting the windage and elevation dials. Move to your desired distance from the target and test fire another group and make your final windage and elevation adjustments. 8. Restore the stud tension by pressing the end of the spring.
Feb 13, 2011 | Tasco Scope Guide Quickly Zeroing Rifle...
Windage adjustment will not adjust to the right - clicks but does not move the shot groups to the right.
if you have forsed the scope turrets you may have broken your scope,,,if the turret turns to the left set it to the center and change the scope mounts or pack out the scope mount with some strips of 35mm camera film 3 strips should do you,
pack out the eye end mount on the left side of the scope
Aug 28, 2010 | Pentax 4-12x40 Gameseeker Rifle Scope...
To adjust the vertical on a Bushnell Banner scope, which way do I turn the screw and how much. I am 6 inches high
The top turret should be the one you need. You should see an U or D with an arrow pointing in one direction or another. Your scope should move the point of impact 1/4 inch at 100 yards for each click. Moving the adjustment 24 clicks in the down direction should fix you up if you are shooting at 100 yards. The movement will be linear for other distances.
Sep 29, 2009 | Bushnell Banner 3-9x40 Riffle Scope, Matte...
New Zeiss 2.5-8 Conquest MC Riflescope. Elevation clickstop adjus
Tried google for zeiss rifle scopes I just did and see they have a suport division...try there and get it from the horsies mouth!!!
Jun 07, 2009 | Conquest Zeiss 3.5-10x50 Mc Rifle Scope :...
Crosshairs on pentax 4.5x14x42 don't move
With modern rifle scopes the crosshairs do not move.They are designed so that the crosshairs are always centered.I have not seen a scope with crosshairs that move for about 40 years.If your scope has 1/4 minute clicks, then the strike of the bullet moves 1/4 inch at 100 yards for every click.1 inch for 4 clicks and so on.If you rifle shoots 6 inches high at 100 yards you should turn it down 24 clicks to strike dead on.Many hunters and shooters adjust their scopes to strike 1 1/2 inches high at 100 yards.Then it will be accurate to about 300 yards without further adjustment.
Feb 15, 2009 | Pentax 4.5X-14X 42mm Pioneer Matte Rifle...
I have a Pentax lightseeker scope and I can not get it adjusted and it has a cracked lense. The adjustments turn but nothing happens, I still shoot the same direction no matter what...
Good Luck
Jan 28, 2009 | Pentax 4X - 16X 50mm Lightseeker-30 Matte...
I need a scope guide instruction sheet for the Tasco 28a
Dec 14, 2008 | Tasco Scope Guide Quickly Zeroing Rifle...
Turn my screen vertical again. i accedently hit the wrong button
CTRL+ALT+UP / DOWN / LEFT /RIGHT to rotate screen (only works on certain versions of vista)
Nov 18, 2008 | Computers & Internet
Open Questions:
Pentax 6x24x 50mm LS30 Matte Scope Logo
80 people viewed this question
Top Pentax Optics Experts
Steve
jasbo
jasbo
Are you a Pentax Optic Expert? Answer questions, earn points and help others
