Question about Samsung Office Equipment & Supplies
CLX3185-FW WILL NOT RECEIVE FACSIMILE. Link Status says not connected and no signal
  • 449 Answers
The wall jack should be plugged into the LINE and not the PHONE jack. Can it send FAXes?
Posted on Mar 19, 2011
Can 10GE Optical Interfaces of a Switch Work upon a Unidirectional Fiber Connection?
10GE optical interfaces of a switch cannot work upon a unidirectional fiber connection. A unidirectional fiber connection occurs between two 10GE optical interfaces when one interface is Down because the Rx fiber is removed, while the other interface is still Up because its Rx fiber can receive link_Up signals from the PHY layer.
A switch determines the status of a 10GE optical interface according to the IEEE 802.3ae standard. As defined in this standard, the MAC layer of a 10GE optical can send local_fault and remote_fault signals. A switch can determine the link status based on only the link status of the PHY layer or based on the link status of the PHY layer and the local_fault and remote_fault signals from the MAC layer.
On a Huawei switch, link status of a 10GE optical interface turns Up only when the link status of the PHY layer is Up and both the local_fault and remote_fault signals are 0. When two 10GE optical interfaces are interconnected and the Rx fiber on one interface is removed, this interface goes Down and the MAC layer of the interface generates a local_fault signal. Meanwhile, the local interface sends a fault signal to the remote interface through the Tx fiber. The remote interface receives the link_Up signal from the PHY layer and the remote_fault signal from the MAC layer. Therefore, the link status of the remote interface goes Down.
S2300 Switch Thunder link com
Jan 22, 2017 | Huawei Computers & Internet
My Samsung facsimile sf40 doesn't receive any fax or sending any fax ok
Dear
I think you need auto receive mode. To do so press repeatedly RCV.MODE/POLL key until the indicator flashes rapidly. this will enable the fax in auto mode and turn to receive mode after 2 rings.
Thanks.
Feb 24, 2015 | Samsung Office Equipment & Supplies
Faded prints samsung clx3185 fw
Got one clx 3185fn printing black only. even press color copy button.
Cartridges are new. Please advise.
Thanks
mearmi@hotmail.com
Oct 26, 2012 | Samsung CLX3185 AllInOne Laser Printer
Apparently there is a problem with Beko refrigeration manufactured between 2000/2006. Please confirm model number in question.
From Beko:-
"The BEKO frost free fridge freezer models affected were manufactured between January 2000 and October 2006. These have a serial number that begins with either 00, 01, 02, 03, 04, 05 or 06. and this information can be found on a label inside the fridge. Beko is making a free of charge modification to all affected models, this modification takes approximately 30mins.
Other Beko branded models and all Beko frost free fridge freezers manufactured after this date are unaffected.
Affected model numbers:
    • CA 5411 FFS/FFW/FFX
    • CA 7014 FFX
    • CA 7015 FFW/FFS/FFX
    • CDA 539 FS/FW/FX
    • CDA 543 FS/FW/FX
    • CDA 645 FW
    • CDA 647 FS/FW
    • CDA 648 FS/FW
    • CDA 653 FS/FW/FX
    • CDA 659 FS
    • CDA 751 FS/FX
    • CDA 752 FS/FW/FX
    • CS 460 FF/FFS/FFW/FFSD
    • CS 461 FFW/FFS
    • CSA 4706 FFX
    • CSB 4606 FFSD/FFS/FFW"
If you find that your model is listed above and is in the correct model year range then you need to click here for further guidance. There is also a freephone number, but it's swamped by callers. Even if you get through you will receive exactly the same advice as you would from the website links.
If you want to know more about what the actual problem is, then click here.
Please take a moment to rate my answer.
Jul 06, 2011 | Washing Machines
How do I set up my Epson Stylus CX4800 so I can send and receive fax's?
Unfortunately, this model of printer does not have the facsimile feature.
Here is a link to Epson for your Stylus CX4800 Users Guide.
http://files.support.epson.com/htmldocs/cx42__/cx42__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Nov 09, 2009 | Epson Stylus CX4800 All-In-One InkJet...
The most often, when I send or a facsimile to RSA
Probably has something to do with the protocol that faxes share. Have you tried any other RSA faxes? It may be that they have an old machine. Most new ones can handle any protocol.
Oct 23, 2009 | HP OfficeJet 6210 All-In-One InkJet...
D-Link Airplus di-524 wireless problem
Hello.
The status light is blinking in all dlink models, so that is normal.
The wireless radio issues have 3 possible solutions.
1. This model has a antenna that screws in the bnc socket behind it see if it's well screwed, or substitute it by another if 2 and 3 don't fix it.
2. On the advaced settings of the wireless configuration you have the ratio of radio broadcast from 25% to 100% check to see if it's on 100%, change channel to 11 if neer and 6 if far, make sure you have SSID broadcast enabled.
3. This models allow you to restart the AP unit and the router unit idependently, so it's always good pratice to restart your AP in the tools and system comands menu.
Hope that helps.
Feb 19, 2009 | D-Link AirPlus DI-524 Wireless Router
No Wifi action, though adapter shown connected
Better to take nearest service center and reinstall the wifi drivers.
Mar 05, 2008 | Computers & Internet
66 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
