Question about Microsoft Windows? Vista Home Basic Edition Full Version for PC (882224181112)
My Vista will not even open- I tried on Safe mode- did the repair- and the message is Root cause- a patch is stopping the start of Vista- How can this be fixed?
  • claytongatti Mar 19, 2011
    I had already tried safe mode ands restore to a former date--it didn't work. Thanks any way.
    I did the restore and did the repair action restore- it failed code 0x490 and the System Files integrity 0X17. The root cause "a patch is preventing the stystem from starting. log stated all was ok with the exception of the info I just listed. I would appreciate help as I know it is not an easy task. Thanks
    I totally feel you are correct about this. I plan to try it and see if it will work. Sad but I have had this system for several months and no problems until recently. I do apprexiate your response. Thank you, Thank you.
    Guru:
  • 767 Answers
According to the Microsoft Tech center, the "root cause patch is stopping the start of Vista" is a problem whereby a Microsoft auto patch did not install correctly and has corrupted your boot sequence. They say it can be fixed by the repair, but many people have complained that the repair made no difference, like you found. The best advice I can give you is to take out that hard drive, put it into another PC, back up your stuff, format and reinstall Windows. That's currently the easiest way.
Posted on Mar 19, 2011
    President:
  • 3,278 Answers
Researching your problem ...
  • NinaE Mar 19, 2011
    Hello.
    Go back to Safe Mode and choose System Restore. Select a date before this problem occurred. Hope this helps.
Why does my laptop lose Homegroup connection every few minutes then reconnects? the other computer in the Homegroup however does not lose connection. I am using windows 7 home premium.
Method 1:
Step 1: Start your computer in safe mode with networking and check the functionality.
Starts Windows in safe mode and includes the network drivers and services needed to access the Internet or other computers on your network.
Advanced startup options (including safe mode)
http://windows.microsoft.com/en-US/windows7/Advanced-startup-options-including-safe-mode
If it works fine in safe mode with networking, perform clean boot to find the root cause.
Step 2: If it works fine in safe mode with networking, perform clean boot to find the root cause.
To help troubleshoot error messages and other issues, you can start Windows Vista or Windows 7 by using a minimal set of drivers and startup programs. This kind of startup is known as a "clean boot." A clean boot helps eliminate software conflicts.
http://support.microsoft.com/kb/929135
NOTE: After you check the functionality in clean boot configure Windows to use Normal startup using the step 7 suggested in the link mentioned above.
Note: Do Not disable wireless services, if any.
Method 2:
You may try the steps from the following link and check:
How to reset Internet Protocol (TCP/IP)
http://support.microsoft.com/kb/299357
Oct 12, 2014 | Computers & Internet
Firefox doesn't start
Have you tried it in safe mode? Click Start > All Programs and select Mozilla Firefox (Safe Mode). If it will open then it may be corrupted theme that is causing problem.
Apr 11, 2010 | Microsoft Windows Vista Home Basic Edition...
Vista boots just Black screen with cursor even in safe mode
Yes, this is a known issue with Vista. You need to back-up your data, format your hard drive and re-install Vista from the beginning.
There is really no use trying to repair it: it is damaged.
After you re-install Vista, do not forget to install service packs from microsoft.com.
Sep 19, 2009 | Microsoft Windows Vista Home Premium with...
Paint shop pro x2 ultimate upgrade wont rum on Vista Home
I havent actually solved the problem but I did get PaingShopProUltimate to run by starting up in "SAFE MODE" I tried it out and everything seemed to work ok. but of course this is not very convenient.
Sep 05, 2009 | Corel Paint Shop Pro Photo X2 Full Version...
Doesn;t boot even in safe mode
if is not start in safe mode you must need to winxp recovery disk to repair windows xp.
Boot your computer with winxp disk then repair it.
Please let me know.
Jul 27, 2009 | Acer Aspire One PC Notebook
MS Vista patches broke my Desktop on my HP PC
after switching on the computer press F8 & Choose safe mode to boot the system & Restore the system in previose state & Before doing this make sure u backup the C Drive.
Don't Forget to Vote
Max
Jun 29, 2009 | Computers & Internet
MS Vista Windows patches broke my desktop
reboot the computer and then press f10 this should get you a screen with a text line that says safe mode,with net or command scroll down to last settings that worked and try that ps. you really need to make a recovery disk. its that important.
Jun 29, 2009 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
KDS product 17s, model 700p. I am getting the follwing message "mode not supported H 82.8khz V77.7hz" whenever I boot the computer. I cannot escape from the message. The computer it is attached to is...
Start in SAFE mode (press F8 wile booting) and choose SAFE mode from the menu to see if it works in Windows DEFAULT setting. Then reboot and reset to 32Bit, and 78Hz max.
My guess is that MSoft pushed a patch or SP to your box and IT replaced the dll your monitor was using.
Good Luck!
Let me know if this fixes it
Mar 26, 2009 | KDS Radius RAD-7c 17" Flat Panel LCD...
Computer windows will not come up
Try This:
To repair your computer using Startup Repair follow these steps:
  1. Boot into Vista installation DVD
  2. Choose your language settings and click Next
  3. Click Repair your computer
  4. Choose your operating system and click Next. This should bring up System Recovery Options.
  5. Click on Startup Repair
Startup Repair should now start diagnosing your system to identify the root cause of the failure. Once it has identified the root cause, it would automatically start repairing your computer. If you are curious to know what Startup Repair did, you can click on the details link and see which tests Startup Repair ran to diagnose the problem.
After Startup Repair has finished the repairs, click Finish to reboot your computer.
Your computer should now be able to boot normally into Vista!
Feb 20, 2009 | Acer Aspire 5500 5570-2609 Laptop
Pinnacle Studio Plus version 10 Keeps Crashing
If you are getting any type of error message or warning message (except a fatal crash message), then , click here to see the FAQ titled "Studio Launch error/warning messages" to resolve these issues. For a fatal crash or any type of lockup/freezing while launching, continue with this FAQ, below.
If Studio was launching for some period of time and then it stopped launching, it is best to try to determine what changes have been made to the computer recently and undo the changes to see if it has an affect on the problem. Here's a short list of what could affect Studio's ability to launch:
  • A Studio patch was applied but it didn't install properly
  • The graphics driver was updated
  • Hardware was installed
We recommend using Windows XP System Restore. You can obtain more information on how System Restore works from the Microsoft web site at:
http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/systemrestore.mspx
Troubleshooting steps for Studio hangs or crashing while launching (starting)
1. RESTART THE COMPUTER. Try restarting the computer
2. WAIT A FEW MINUTES: If Studio still won't launch, wait a few minutes to let it finish launching. We have noticed on some computers that it may take a little while for Studio to completely launch. Studio 10 users click here to see the FAQ on this.
3. LATEST VERSION OF STUDIO. There was a launch problems in previous versions of Studio 10 that are now fixed in the latest version. When troubleshooting any problem, it is always best to be on the latest version of the software.
If you have Studio version 12, download the latest version here.
If you have Studio version 11, download the latest version here.
If you have Studio version 10, download the latest version here .
Note: Studio 11 patches will only patch a previous install of Studio 11. Studio 10 patches will only patch a previous install of Studio 10. Etc.
If you have an older version of Studio (Studio 9 or 10, etc), it is advised for you to update to the current Studio software. The current version is Studio 12. Click Here to go to the Studio 12 Upgrade page.
How to download and install a patch:
  • When downloading the patch make a note of where it is being saved to. We recommend saving the patch to the desktop.
  • Before installing the patch, make sure that you do not have any other programs running. Studio must not be running.
  • Once it is fully downloaded, double-click on the patch to begin the installation.
  • Follow any on-screen prompts to complete the installation. Reboot the computer after applying the patch.
4. SAFE MODE: Try launching Studio in Safe mode. In Safe mode, many device drivers and applications do not load. If Studio will launch in safe mode, then the issue is most likely a configuration problem with your computer. NOTE: We do not recommend using Studio in Safe Mode. This step is for testing purposes only. To start in Safe mode:
  • Shut down the computer
  • When you turn it back on, tap the F8 key every couple seconds until a menu pops up. (If the XP splash screen appears, the F8 keys was pressed too late so restart the computer and try this step again)
  • On the menu, choose Safe Mode, and then press the Enter key
  • Launch Studio
If you need help starting in Safe mode, you can click here to get information on Microsoft's web site
If Studio won't launch in Safe mode, then Studio many not be installed properly or the install may be corrupt. We recommend uninstalling and reinstalling Studio.
Click here to see the FAQ on how to uninstall, then reinstall Studio 10.
Oct 22, 2008 | Pinnacle Computers & Internet
Microsoft Windows? Vista Home Basic Edition Full Version for PC (882224181112) Logo
74 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
