Question about Cameras
How do i know my vivitar camera X029 is charging? because when i plug it into the charger the red light sometimes doesn't come one.
  • 604 Answers
You may have a bad charger connection at the camera, try wigglig it when you plug it in and see if the red light comes on. this problem is difficutt to fix, and expensive. If the light comes on and off while you are wiggling the cable near the camea, then that is your problem
Posted on Mar 19, 2011
Camera, the charger cord broke, got a new one, not sure if it's charging cause it always shows the MSDC on the screen when I turn it on. What has happen to my camera? It is a Vivitar ViviCam x029
Are you charging it by connecting to a computer? The MSDC message says that the camera is connected to a computer. What happens if you disconnect it and then turn it on?
Oct 14, 2016 | Vivitar ViviCam X029
What does the charger for a vivitar vivicam X029 look like? And where do I plug it in on the camera
You can use any USB charger, such as used by some cell phones. Or you can connect the camera to a computer's powered USB port. In either case, it plugs into the camera's USB port.
Jun 30, 2012 | Vivitar ViviCam X029 Digital Camera
I have this dig camera but have no cabels and would like to know where to buy them and if I need a separate cabel to charge or is that done on the computer
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as iPhoto and Windows Photo Gallery.
The X029 uses three standard AAA batteries. You may use either disposable or rechargeable batteries. If you choose to use rechargeables, you must charge them outside the camera using a separate charger.
Dec 04, 2011 | Vivitar ViviCam X029 Digital Camera
My camera has been plugged into the computer for 24 hours now and the battery still isn't charged. How long does it take to charge and how will i know when it is done charging? i have a Vivicam X029
The manual merely says "a few hours." The LED on the back of the camera lights up while charging and goes off when finished. Not all computer USB ports put out enough current to charge batteries. If you're using a hub, bypass it and connect the camera directly to the port. If that doesn't do it, try another port if available. If that doesn't do it, use the supplied AC adapter and plug it into a wall outlet.
Aug 05, 2011 | Vivitar Cameras
I just bought the camera and am trying to charge it. I am not getting an LED light but instead a blue screen that says "MSDC" in white letters. I have checked the battery and storage disk...
Are you charging it by plugging it into a computer? The "MSDC" you see usually means "Mass Storage Device Class", which basically means the computer is using the storage on the camera as a removable drive. This would usually happen when plugging a camera into the computer via USB. There is usually an AC adapter that comes with a camera, or a separate charger for just the battery. If there was no charger that came with it, the camera is probably still charging. If the camera is on, try turning it off and plugging it in. Remember, even if it shows "MSDC", it is probably still charging. Hope this helps!
May 19, 2011 | Vivitar ViviCam X029 Digital Camera
My camera wont turn on after being charged all night and day. i checked it repeatedly to see if it was done charging and all i got was a blinking red light the whole time. it wont turn on!
The battery itself could have gone bad. If the cells within the battery are damaged, it can refuse to charge or power the camera, which would explain the blinking red light.
You'd need to purchase a replacement lithium ion battery.
Mar 12, 2011 | Vivitar ViviCam X029 Digital Camera
I need to know what the charger looks like. does it take batterys? where do they go? how do I charge the camara?
You can purchase a charger for this camera at http://www.amazon.com/Wall-Charger-Adapter-Vivitar-Vivicam/dp/B003M6BXBO/ref=pd_sim_e_1
Feb 28, 2011 | Vivitar ViviCam 8025 Digital Camera
How to charge a ViviCam X029
I trying charging my vivitar vivicam x029 and the camera wont turn on? The red light was blinking while plugged in and did stop blinking after awhile... not sure if camera is broke or not , any ideas?
Jun 18, 2010 | Vivitar ViviCam 3915 Digital Camera
Battery wont charge
This camera not charged via PC, you can charge the battery only with wall charger(comes with box).When camera is plugged to PC, you can´t use it as a camera, only as a memory card.You can watch your stuff in PC( PC recognise a camera as a flash memory, no more).
So, this is normal..Charge your camera with wall charger(Full charge Red light not flash!, if light flashed camera is charging) Unplug and use as usually!
Regards
Alex
Vivitar 7300X
Nov 22, 2008 | Vivitar DVR 7300x Digital-8 Camcorder
Cameras Logo
42 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
