Question about Ilco Key blank, YAMAHA X65
How much oil to put in a xj65 yamaha engine put 4
How much oil to put in a x65 yamaha engine put 4 qt cant see in site glass
I NEED TO KNOW HOW MUCH AND WHERE TO PUT IT, OIL CHANGE ON A 1997 YAMAHA ROYAL STAR 1300 AND DOSE THAT OIL ALSO GO INTO THE CLUTCHES.
It has a window on the side of the crankcase and a drain plug on the bottom of the engine. It takes about 4 quarts w/filter, add three then check the level in the site glass, when it is about 2/3 of the way up the glass you are full. It uses 10W40W
Apr 14, 2017 | Yamaha Motorcycles
Oil leak from exhaust
Hi Kevin, many riders are over filling their oil system because they do not know how to properly read their oil site glass. The following procedure works on nearly all 4 stroke engines but to be on the safe side you should always refer to your owners manual. Use your center stand if you have one.
1. Bring the engine up to operating temperature or let idle for 5 minutes.
2. Turn off your engine and let it sit for 2 minutes, this will allow the oil from the top end to drain to the bottom.
3. Hold your bike straight up or on the center stand and wait 2 minutes for the oil in the bottom of the engine to be level in the sight glass.
4. Your oil level should be between the top full mark and the bottom add mark.
5. Never over fill your oil system it will cause problems:
a. oil leaking out of exhaust pipes.
b. oil leaking out of breather pipe/hose.
c. oil carryover into the air cleaner.
6. Your oil site glass must never be completely full drain as necessary.
7. Your oil site glass must never be completely empty add as necessary.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
How Do You Check Motorcycles Oil Level
How To Check The Oil On Motorcycle
Yamaha XJ600S 1992 Service Manual
OEM parts for Yamaha
Yamaha XJ600SF Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 09, 2017 | 1994 Yamaha XJ 600 Diversion S
How to check oil level yamaha xj600
Hi Anonymous, many riders are over filling their oil system because they do not know how to properly read their oil site glass. The following procedure works on nearly all 4 stroke engines but to be on the safe side you should always refer to your owners manual. Use your center stand if you have one.
Oil level window
How to check the Oil Level in your Motorcycle
Yamaha FJ Owners Workshop Manual
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Jan 22, 2012 | 1990 Yamaha XJ 600
How much oil should i add to my 1981 xj 750
Hi Kyle, many riders are over filling their oil system because they do not know how to properly read their oil site glass. The following procedure works on nearly all 4 stroke engines but to be on the safe side you should always refer to your owners manual. Use your center stand if you have one.
Just bought 1981 seca 750 OIL CHANGE HELP
1982 Yamaha 750 Maxim Oil Change with middle gear drain plug location
Yamaha XJ750 Owner Manual service manual
Oct 30, 2011 | Yamaha Motorcycles
How do u check the oil level on a 2009 yamaha raider s
Hi Jevonjames19 many riders are over filling their oil system because they do not know how to properly read their oil site glass. The following procedure works on nearly all 4 stroke engines but to be on the safe side you should always refer to your owners manual. Use your center stand if you have one.
How exactly do you check the oil level on these things
check oil level
Yamaha XV19SW Service Manual
Yamaha ROADLINER XV19SW Owner Manual
Aug 21, 2011 | 2009 Yamaha Raider S
What wieght oil for a 1986 moto 4 225 and how much
The Recommended Oil & Weights are:
Yamalube 4 (20W40) or Yamalube (10W30) you can also use SAE type motor oil 20W40 or 10W30.
The total amounts are:
Dry 1.3L or 1.4 US qt
Periodic Oil Change without filter 1.0L or 1.1 US qt
With oil filter replacement 1.1L or 1.2 US qt
Note: Recommended engine oil classification; API Service "SE", "SF" type or equivalent.
I’m happy to help further over the phone at https://www.6ya.com/expert/al_e83b1941f9c0f302
Mar 02, 2011 | 2002 Yamaha TT-R 225
Can you tell me the tyre pressure on a fjr 1300 2005 also the amount of oil in the beveldrive and the amount of oil in the engine ,thanks
Tire pressure is 36 psi @ front & rear but if the total load is over 198 pounds shuold be 42 psi on rear, always measured when tire is cold. Final gear oil capacity is .21 US qt or .18 Imp qt, engine is 4.23 US qt or 3.52 Imp qt when replacing the oil filter. information is from the owner's manual.
Mar 26, 2010 | 2005 Yamaha FJR 1300
How much oil goes in 2000 yamaha 1100 v-star classic
3.1 US QT W/O FILTER CHANGE
3.3 US QT WITH OIL FILTER CHANGE
Oct 21, 2009 | 2000 Yamaha V Star 1100 Classic
I have a ??? about my 1990 yamaha fzr 1000
Buy four quarts, but plan on using just three. If you actually do change the filter, you will drain more oil. Not all the oil drains out if you leave the filter alone.
Once you drain the oil, your filter is replaced and your drain plug is tight, add two quarts, and check it as you add the third qt. a little at a time. If your bike has a sight glass, make sure you stand the bike up straight and centered, and wait a minute before you take the reading so the oil can get to the glass. (Some glasses require two people to read!)
If your engine just has a dipstick, check it as you add the third qt. Once you think you're in the operating range, put the cap on and run the engine for a minute. Kill it and check oil level once more to see if it dropped.
Have fun, and enjoy your new scooter! Let me know if we can help with other maintenance on the FZR. Later,
TaterTodd
Feb 04, 2009 | 1990 Yamaha FZR 1000
Ilco Key blank, YAMAHA X65 Logo
27 people viewed this question
Top Ilco Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you an Ilco Lock and Locksmithing Expert? Answer questions, earn points and help others
